"Gravity/air pressure" flooding those at altitude?
Page: Previous  1, 2
BarryL Premium Member
BarryL is offline
PostPosted: Wed Aug 13, 2014 7:00 pm    Post subject: Reply with quote
A tiny piece of rubber calved off the hose? Sometimes when hose is first pushed on any fitting a tiny chaff-shave bit will get inside.
Fredrok
Fredrok is offline
PostPosted: Wed Aug 13, 2014 8:15 pm    Post subject: Reply with quote
Thanks Barry, I considered some form of debris as a possibility and removed the barbs to inspect at the time. I was unable to see anything however, after sitting on my bench for a few hours, it now works much better (but not like it did new). I'm thinking a thermal issue now.
BarryL is offline
PostPosted: Thu Aug 14, 2014 7:35 am    Post subject: Reply with quote
Without rereading all the past discussion on the valve, is it rated for continuous duty?
Fredrok
Fredrok is offline
PostPosted: Thu Aug 14, 2014 8:28 am    Post subject: Reply with quote
Great question Barry and unknown. I did find some specs but I've seen no confirmation for continuous duty. (mine was stamped for 12vDC)
http://www.seekpart.com/product/water-valve-2W025-08-3362084.html
http://www.tradeindia.com/fp1173234/Solenoid-Valve-2w-025-08.html
http://www.chinapropneumatic.com/products/2W025-08-Solenoid-Valve-827797.html
kreemoweet
kreemoweet is offline
PostPosted: Fri Aug 15, 2014 10:21 am    Post subject: Reply with quote
Needle valves, such as the ones in the carb, are really not to be thought of as shutoff valves, they are mainly
flow regulating devices. That's why, at least since the early '60's, VW either incorporated a cutoff valve in
the fuel pumps or used a separate external cutoff valve. Tank pressure does not affect the operation of
those cutoffs. It seems you either don't have one (many aftermarket pumps are lacking this feature) or the one
in your pump is defective. There are "rebuild kits" available for some early VW/Pierburg fuel pumps, but the
quality is unfortunately very questionable.
'67 bug: seized by the authorities
Fredrok
Fredrok is offline
PostPosted: Fri Aug 15, 2014 11:17 am    Post subject: Reply with quote
Thank you for the suggestion. Here's the pump, looks like a cleaned up original?
I see WW offers a rebuild kit for $30, however my question would be if that was the cause, why not all the time instead of just full? Thank you!
mandraks
mandraks is offline
PostPosted: Fri Aug 15, 2014 11:52 am    Post subject: Reply with quote
well it looks like a brosal pump without a hose clamp on it. Smile
regards
Uli
Fredrok
Fredrok is offline
PostPosted: Fri Aug 15, 2014 12:26 pm    Post subject: Reply with quote
Cute. That's because I took it off to pry the hose off on the side of the road to troubleshoot before scorching on asphalt and bathing in fuel, thus leaving it off and in pieces once I got it home to investigate (see earlier posting).
So, would the Brosol (as stamped on the side) be an original?
I'm learning VWs are A LOT like Jeeps. Better be mechanically adept and carry AAA for the back up.
mandraks
mandraks is offline
PostPosted: Fri Aug 15, 2014 12:28 pm    Post subject: Reply with quote
mine were all Pierburg ones. I think the other ones are newer replacements
regards
Uli
Fredrok
Fredrok is offline
PostPosted: Fri Aug 15, 2014 12:33 pm    Post subject: Reply with quote
Thanks, I'll start yet another search to see what the TS collective deems trustworthy pumps!
BarryL is offline
PostPosted: Fri Aug 15, 2014 2:54 pm    Post subject: Reply with quote
kreemoweet wrote:
... since the early '60's, VW either incorporated a cutoff valve in the fuel pumps or used a separate external cutoff valve..
Do you have any pictures or links to these valves?
kreemoweet
PostPosted: Fri Aug 15, 2014 3:43 pm    Post subject: Reply with quote
The Bentley and Haynes manuals have photos and diagrams of them.
From thesamba gallery, an external cutoff valve:
According to the Haynes manuals, the pumps like the OP's with the inscription "PE 20000" have internal cutoff valves, but the earlier ones with
"VW, 15" do not. That's talking about VW pumps (with VW logo, etc), I don't know whether that would apply to similar-looking Brosol pumps.
Fredrok
Fredrok is offline
PostPosted: Sat Aug 16, 2014 8:14 am    Post subject: Reply with quote
Good stuff, thanks. The confusion on what I should have stock continues.
Page: Previous  1, 2
Page 2 of 2
