GoWesty starter vs. a cheap one.
TonyInSoCal
TonyInSoCal is offline
PostPosted: Sat Jul 26, 2014 11:57 pm    Post subject: GoWesty starter vs. a cheap one. Reply with quote
Why is their starter twice (if not more) expensive than anyone else? Is it twice as good?
I need a starter. I have to rap on mine just about every damn time in order to get it to work.
I've bought a LOT of stuff from GoWesty.com. Everything has been spot on. I've even got a sticker on my back window. But do I spend $75 on a USA Industries Refab? Or do I spend $280 at GoWesty?
Advice?
'87 tin-top Vanagon
thatvwbusguy
thatvwbusguy is offline
PostPosted: Sun Jul 27, 2014 2:42 am    Post subject: Reply with quote
You don't need to go with either of those options. Check out the starter adapter from Karl @ Westy Ventures instead.
http://www.westyventures.com/parts.html
The adptor allows you to use the Bosch SR0408X/409X, a more powerful starter from the 1996 - 2003 manual-trans VW TDI (diesel) cars. This starter has ~2.4HP vs ~1.3HP for the stock Vanagon starter.
The SR0408X/409X is a high torque gear-reduction type starter with a self-supporting shaft, so it no longer requires the bronze pilot bushing to position the shaft end if you have a manual trans Vanagon.
The adapter is $75 shipped and you can usually find the starter for about $120.00-$150.00 with a lifetime warranty. This gets you out the door cheaper than the GW starter and doesn't tie you to a single supplier if you do run into problems with it in the future as long as you buy it from a national chain that offers a lifetime warranty.
When my starter needs to be replaced, this is the only choice I will consider.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
insyncro
Banned
insyncro is offline
PostPosted: Sun Jul 27, 2014 5:50 am    Post subject: Reply with quote
There is a used adapter and starter in the classifieds currently as Jay pointed out.
I have used many of Karl's adapters and purchased the TDI starters brand new....all working flawlessly.
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Jul 27, 2014 6:28 am    Post subject: Reply with quote
I went with what you call 'a cheap one' and have had no problems with it for many years now. What I like is that it came with a lifetime warranty from a parts chain with stores almost everywhere (Checker then, O'Reillys these days).
I have twice swapped alternators in an Autozone parking lot under their guarantee, I suppose I could change a starter in O'Reillys' lot if I was far from home (I do carry an 8mm Allen wrench on board).
I have no experience with the hi-torque but again (as Jay points out) you will have the comfort of a lifetime guarantee.
kalispell365
kalispell365 is offline
PostPosted: Sun Jul 27, 2014 7:49 am    Post subject: Reply with quote
The other option that seems to have disappeared nowadays is to disassemble it, diagnose the problem and repair it. I often replace starter contacts on Japanese starters for under five dollars, and replace worn alternator brushes (which is all that's ever wrong with these) for around the same amount.
I find the piece of mind knowing my repair was done properly and completely worth the time. Even the Bosch branded items are often rebuilt half hearted by a factory worker in some other country.
There are a bunch of resources to learn this, including the internet as well as your Bentley manual.
1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l
shadetreetim
shadetreetim is offline
PostPosted: Sun Jul 27, 2014 10:13 am    Post subject: Reply with quote
I just recently added the Karl/WestyVentures adapter and TDI starter to my van, (along with a few other modest changes). The TDI starter cranks the motor over fast. Very satisfying upgrade.
Or, if you wish to go the rebuild route without tackling it yourself, there's a good alternator/starter rebuilder shop in Riverside. I've used him for my work trucks.
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5
JudoJeff
JudoJeff is offline
PostPosted: Sun Jul 27, 2014 10:25 am    Post subject: Reply with quote
I purchased the GW gear reduction starter in May and I failed on the first startup. Shorted internally. GW gave me a refund, BUT I still paid shipping two times, so it cost me $50. POS.
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout)
slobrewer
slobrewer is offline
PostPosted: Sun Jul 27, 2014 11:03 am    Post subject: Reply with quote
I installed the GW gear reduction starter a few weeks ago and have been very happy with it so far. It's not a remanufactured unit so it's all new parts.
White 1988 Vanagon Westfalia (Automatic, A/C, solar, aux battery, 15" GW wheels, 8' Fiamma awning, 63 qt. Edgestar fridge, homebrew on tap)
rlamb
rlamb is offline
PostPosted: Sun Jul 27, 2014 11:50 am    Post subject: Reply with quote
Was the starter you speak of a rebuilt stock Vanagon one, or a rebuilt diesel Jetta starter for use with Karl's adapter plate?
I installed Karl's adapter plate with a rebuilt O'Reilly 408x Jetta starter (interestingly, the starter housing had a part number for a Eurovan Starter; I think rebuilders can match different motor housings with different motors and mounting plates). Works awesome with my 2.8L V6. Spins the engine fast. All together, I spent $190 ($115), and any future starters are under a lifetime guarantee. Free shipping from O'Reilly if there isn't one in your area. I'm really happy with the upgrade too, and the price was really nice.
1984 Westfalia - Ford Cologne 2.8L conversion
2003 Passat GLX Wagon (4Motion)
Syncro Jael
Syncro Jael is offline
PostPosted: Sun Jul 27, 2014 12:21 pm    Post subject: Reply with quote
We went with the GW starters on both Syncro's.
About 8 months on one and a year on the other.
Both have worked flawlessly on a WBX 2.1 and EJ22.
I like the TDI starter and when this one goes, I will probably go that route. It is easier to get a replacement and a lifetime warranty that GW does not have.
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Jul 27, 2014 12:55 pm    Post subject: Reply with quote
rlamb wrote:
Was the starter you speak of a rebuilt stock Vanagon one, or a rebuilt diesel Jetta starter for use with Karl's adapter plate?...
It was a rebuilt Vanagon starter. It starts the engine -- that's enough for me.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sun Jul 27, 2014 2:11 pm    Post subject: Reply with quote
I bought a rebuilt Bosch SR401 (I think - the later OEM starter) on Amazon and its been great. Spins my 2.5 Subie like a champ.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
whynotvw
whynotvw is offline
PostPosted: Sun Jul 27, 2014 4:44 pm    Post subject: Reply with quote
Karl's adapter with TDI Bosch starter is the way to go. A lot more power then GW starter and more reliable. Less money also. IMHO.
Gauche1968
Gauche1968 is offline
PostPosted: Sun Jul 27, 2014 5:40 pm    Post subject: Reply with quote
What's the best tool to use to get that lower bolt as you can't get a typical socket on it due to interference from the body of the starter?
1984 Vanagon GL
1984 Vanagon Westy
snwbrdr435
snwbrdr435 is offline
PostPosted: Sun Jul 27, 2014 5:52 pm    Post subject: Reply with quote
I just used a box wrench
thatvwbusguy
PostPosted: Sun Jul 27, 2014 6:00 pm    Post subject: Reply with quote
Yes, a standard open end box wrench will definitely do the trick. I think a Gear Wrench might be able to sneak in there to make the job a little bit quicker as well.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
SteelB12
SteelB12 is offline
PostPosted: Sat Oct 11, 2014 7:46 am    Post subject: Reply with quote
So swapping out the starter is a pretty simple process?? As in, do it in my driveway without anything special
If its described in the Bently I need to wait for the rain to stop. Not in the mood to go out and get it from the van.
1987 Westy
thatvwbusguy
PostPosted: Sat Oct 11, 2014 8:29 am    Post subject: Reply with quote
On a 2WD it is a simple job, just two bolts to remove the starter. The gas tank on the Syncro makes the job a lot less fun due to limited room to work.
You will need an allen socket (6mm I think) for the top bolt, so if you don't have that, a trip to the tool store is going to be necessary.
Be sure to disconnect the ground cables on any batteries before you start working.
If you are installing a new stock starter, be sure to inspect/replace the bushing while you are in there. A 7/16" bottoming tap is a common way to remove the old one.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
SteelB12
SteelB12 is offline
PostPosted: Sat Oct 11, 2014 8:53 am    Post subject: Reply with quote
Cool, thanks
Yes, its just a 2wd Manual that I need to do this on. Will probably just get one from Bus Depot.
1987 Westy
gears
gears is offline
PostPosted: Sat Oct 11, 2014 10:13 am    Post subject: Reply with quote
This. The single best upgrade I've performed on my car in a long time ..
aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com
