How to know which engine tins I am missing?
khalimadeath
khalimadeath is offline
PostPosted: Sun Jul 27, 2014 6:45 pm    Post subject: How to know which engine tins I am missing? Reply with quote
I searched but to no avail I was not able to find a list WITH pictures of all the engine tins so I can order the right ones. I have found a lot of them in the classifieds but I dont want to order what I already have..
engine in question..
Thanks for any helpful links.... or just an answer would be great!
Danwvw
Danwvw is offline
PostPosted: Sun Jul 27, 2014 6:51 pm    Post subject: Reply with quote
What year? Looks like the ones that can be seen are all there! Often the Heat-Riser-Covers are missing. See Item "K" on the Bus Boys site.
1971 VW Bus Sundial Camper, 1960 VW Beetle, 1988 Porsche 924s
Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? And 1960 Beetle Original 36 Horse And Porsche 924s.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 27, 2014 7:09 pm    Post subject: Reply with quote
Before you get too carried away with tin you may want to look into some fuel line clamps Wink
Noting looks too awful from here as far as the tin goes, how about some more pics from above and below?
Tcash
Tcash is offline
PostPosted: Sun Jul 27, 2014 7:11 pm    Post subject: Reply with quote
http://www.awesomepowdercoat.com/Original_German_Engine_Tin.html
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-1.html
http://www.thesamba.com/vw/archives/info/chassisdating.php
khalimadeath
PostPosted: Sun Jul 27, 2014 7:58 pm    Post subject: Reply with quote
Haha yea, well PO just put new lines on it apparently, I am not driving it. The motor and trans will be coming out soon so I will begin collecting all the things I know I need now, then order more as they come up. I will get some more pics..
Also its a 1970, 1600 I believe.. Also having trouble finding a thread that describes the differences between a type 1, type 2 ect.. most of them have pictures but nothing particularly labeled. I have been lurking the site apx. 6 hours a week and I find that most threads people are referenced to fail to answer the question and end up leading to no answer at all. When I search I just find thread of people asking questions and people telling them to search..
Danwvw
Danwvw is offline
PostPosted: Sun Jul 27, 2014 8:14 pm    Post subject: Reply with quote
Your engine photo shows it is a Type 1 1600 based Single port engine which is what came in the 1970 VW Bus, In 1971 they Went to the Dual Port, Still a Type 1 engine then in 1972 the buses for the USA got the Type 4 engine which went from Dual Carbs and 1700cc to a full fuel injected 2 liter engine. The Type 1 engines are up-right the Type 4's are flat on top.
Photo of the Type 4 Engine:
Tcash
Tcash is offline
PostPosted: Sun Jul 27, 2014 9:08 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?p=6635854#6635854
Wildthings
Wildthings is offline
PostPosted: Sun Jul 27, 2014 9:51 pm    Post subject: Reply with quote
There isn't really a Type II engine in 71 and earlier Bay, just a Type 1 with some slight modifications to the case for the rear support bar. As others posted the later Bays had Type 4 engines from the 411/412 cars.
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Mon Jul 28, 2014 5:40 am    Post subject: Reply with quote
I do not see a breast plate tin in the photo...
I Corinthians 4:3
Pictures from my cross-country road trips are at: http://instagram.com/jeff.pop.geisen
I actually drive my bus, and I maintain it myself, it runs fine. I don't merely own a bus.
I travel all over in it. Really, check my instagram link.
71 Westy rag top, 69 single cab
khalimadeath
PostPosted: Mon Jul 28, 2014 10:35 am    Post subject: Reply with quote
Ok great thanks guys that will be very helpful when I start ordering parts. i will get some more pics of underneath and above today..
skid
skid is offline
PostPosted: Mon Jul 28, 2014 1:55 pm    Post subject: Reply with quote
x2
'71 Westfalia
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Mon Jul 28, 2014 2:04 pm    Post subject: Reply with quote
The link to Awesome Powdercoat that Tcash posted is pretty comprehensive. Check out this numbered guide:
Like Jeff and skid said, you're missing the breast tin, which is number 15 and on the right center of the picture.
You're missing the #10 left lower rear air deflector, and I'd guess you're missing the #9 (right rear lower) tin as well.
Once you have the breast plate in, you'll want a "stovepipe" preheat tube to go under the breast plate and pull warm air from near the #9 tin (and #2 cylinder head.) You'll need some fresh-air heater hose to connect the "stovepipe" to the air cleaner's lower pipe intake.* Then when it's cold/humid outside, you can flip the valve on the air cleaner to pull in pre-heated air which helps in drivability and fuel economy when the engine is cold.
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=1089220[/img]
*You should straighten out the kink in your left hose. Maybe cut the excess out and use it for the preheat/stovepipe setup?
www.facbeook.com/airschooled - Live Volkswagen Q&A - Sunday evenings 6pm Pacific/9pm Eastern.
khalimadeath
PostPosted: Mon Jul 28, 2014 4:43 pm    Post subject: Reply with quote
Thats a lot of tins ^^ lol I am gonna have to try and figure out where each one is and mark them so I can narrow it down more. With that many I can see how hard it could be to identify them all.
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Mon Jul 28, 2014 7:13 pm    Post subject: Reply with quote
Many of the tins you can see from the pictures. Things like the fan shroud, upper cylinder tins, and backing plates (4, 5, and 6) are obvious. The thermostat and flaps (14 and 24) are nice to have, but some people run without them. They help the engine get up to operating temp quicker, which is healthy for oil life on short trips and engine life in the long run. Sled tins like 11, 12, and 13 you can easily see from underneath the engine.
One of the most common mistakes new engine builders make is using a bug front (front of engine is front of bus. Technically, you're always looking at the back of the engine from the hatch,) firewall tin instead of a bus tin. We're talking about #7, and technically only came 1971 buses with the exit hole for the doghouse oil cooler. Up to 1970 it was the same shape with no hole. Even then, it looks like a bug firewall with extra metal tacked on. That is a common way of making a bus firewall tin out of a bug tin.
Remember, these cars are about 45 years old, so just because it came from the factory a certain way doesn't mean it's still that way. Check, check, and recheck.
Do you have a doghouse shroud or non-doghouse shroud? We're feeling behind the shroud for parts 1, 2, and 3 here. The red line is where the firewall tin goes:
Here are the bus firewall tins. See the exit hole for the doghouse oil cooler now? Also, take a look at the arched bead running roughly horizontally through them. That's the shape of a bug tin, the bus tin is larger. Which do you have?
Tcash
Tcash is offline
PostPosted: Mon Jul 28, 2014 7:29 pm    Post subject: Reply with quote
busdaddy:how about some more pics from above and below?
khalimadeath:i will get some more pics of underneath and above today..
Popcorn
khalimadeath
PostPosted: Mon Jul 28, 2014 8:40 pm    Post subject: Reply with quote
want sure exactly where or what to take the pictures off so I just kinda stuck my phone under there and got a couple. If there and area in specific you suggest I can get more pics..
Brian
Brian is offline
PostPosted: Mon Jul 28, 2014 9:44 pm    Post subject: Reply with quote
Glad to see the sled tins are there. But holy oil sump batman.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
khalimadeath
PostPosted: Mon Jul 28, 2014 10:00 pm    Post subject: Reply with quote
Thats what i was thinking! Is that thing gunked up or what?! ha
Ill get some more pics tomorrow, there seems to be more to all these engine tins than I thought. Kinda strange why they would use so many..
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Tue Jul 29, 2014 7:43 am    Post subject: Reply with quote
Just pretend the tins are like coolant hoses on your watercooled cars. Actually, that's exactly how they work, and that's why I'm happy to help you not "spill your coolant" everywhere. Wink And VW didn't put unnecessary parts on their economy cars...
A pressureized car wash or even a pressure washer with some engine degreaser will work wonders on your underside. It looks like regular neglected VW oil mist plus ten years of sitting in a dusty barn or something. Clean engines are fun engines to work on.
Wildthings
PostPosted: Tue Jul 29, 2014 9:25 am    Post subject: Reply with quote
Don't know how you are intending to use your rig, but if you are going to be going off the pavement much, I would ditch the enlarged sump. To vulnerable to rock damage in my book.
