Caspdstr Samba Member
Joined: January 08, 2014 Posts: 5 Location: Orange County Ca
Posted: Fri Aug 01, 2014 1:54 pm Post subject: Bay Window Tire Size |
Hello. I have a 1970 Bay Window with stock 14" wheels. Which Tire size works best? ...and where do I get them? Im having a hard time finding
Thank you!!! |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Aug 01, 2014 7:23 pm Post subject: |
Or read the tire sticky.
Or read your manual: 185R14C is what you want. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
WestyPop Samba Member
Joined: February 08, 2005 Posts: 1732 Location: SoCal
Posted: Fri Aug 01, 2014 10:10 pm Post subject: |
jtauxe wrote: |
Or read your manual: 185R14C is what you want. |
Yep, that's the current size designation to replace the "7.00-14" called for by the 1970 Owner's Manual. Many bay owners here use slightly larger sizes to good effect, usually with a C or D load rating.
Didn't get a manual from the seller? Try http://www.thesamba.com/vw/archives/manuals/manuals70.php Then say, Thanks, Everett!"
And if you've got a 3-day weekend to kill... the Tire Sticky actually does contain a whole lot of good info... as well as opinions.
Have fun with your bay. _________________ Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others) |
Vest Failure Samba Member
Joined: February 05, 2014 Posts: 15 Location: Suffolk, UK
Posted: Sat Aug 02, 2014 2:20 am Post subject: |
OK, I'll stick my head above the parapet: Hankook RA18's are the ones I got. |
Brian Samba Moderator
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Mon Aug 04, 2014 7:17 am Post subject: |
Just click here and select whatever tire you can afford.
Many like the Hankook, although lotsa companies make our tire needs and size. |
bruehoyt Samba Member
Joined: April 08, 2008 Posts: 180 Location: Columbus, OH
Xevin Samba Member
Posted: Mon Jun 07, 2021 11:25 pm Post subject: Re: Bay Window Tire Size |
bruehoyt wrote: |
It is soooooo annoying when I read responses on the Samba that simply say - do a search or read the sticky. It happens way too often.
Just give the answer. Or give the answer and add info about stickies and searches. Or just don't say anything. |
Are you looking for tire recommendations, spec OEM tire size, or just venting? I can provide you with OEM tire info and tires that work for my driving needs currently available. As a bonus I can show you pictures of me driving in various terrain with stock style tires. It’s also in the stickies
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Tue Jun 08, 2021 12:05 pm Post subject: Re: Bay Window Tire Size |
Xevin wrote: |
bruehoyt wrote: |
I was searching for tire sizes. I did search first -which is how I came upon this thread
I vented first - then forgot to post a more useful reply.
My bus came with aftermarket rims. I don't know the width or offset.
The Tires are 195/65R15
My speedo/odo are way off I assume due to tires size.
The stock tire is 185R14. Is the unlisted aspect ratio 80?
If it is, the circumference would be about 80.6" 810.80 rev/mile
My circumference is about 78.5". 832.66 Rev/mile
My speedo is more than 10% off. I would expect it to be closer.
Could this be just tires? Or has the transmission been altered?
I am fortunate to have received a bus with all of its service records through the years. But there was one owner, George Harris in California, around 15 years ago who did work himself. (same guy who put the tires on it). He did keep parts receipts.
_________________ Current VW's:
71 Westfalia https://www.thesamba.com/vw/forum/viewtopic.php?t=633955
74 Super Beetle Convertible Sun Bug https://www.thesamba.com/vw/forum/viewtopic.php?t=748008
Past VW's:
71 Karmann Ghia Autostick. 17-21. https://www.thesamba.com/vw/forum/viewtopic.php?t=727596
70 Karmann Ghia driven 00-03, 67 Karmann Ghia 91-97, 74 Karmann Ghia 92-94, 71 Karmann Ghia 87-92, 74 Super Beetle 86-87, 71 Karmann Ghia 85-86 (my avatar) |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Tue Jun 08, 2021 12:08 pm Post subject: Re: Bay Window Tire Size |
185R14 tires have a diameter of 25.7", a section width of 7.3", and a wheel diameter of 14". The circumference is 80.4" and they have 788 revolutions per mile.
Transmission shouldn't be a factor, the speedo drive is off the left front hub. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Tue Jun 08, 2021 12:32 pm Post subject: Re: Bay Window Tire Size |
ImAddicted wrote: |
Transmission shouldn't be a factor, the speedo drive is off the left front hub. |
I knew the speedo cable went to the wheel. I've replaced a couple over the years. I should have known better than to suspect gear ratios. I changed the rear end gearing in my '83 Mustang in the 90's. But that was a different animal.
with a 15" rim the closest I can get to stock revolutions is
195/75R15 784 r/m
185R14 788 r/m Stock
205/70R15 790.9 r/m closest - but is my rim wide enough? I'll have to check.
195/70R15 807.9
185/70R15 825.5 r/m
195/65R15 832.6 r/m My current tires _________________ Current VW's:
Past VW's:
samwise Samba Member
Joined: May 04, 2010 Posts: 611 Location: North Salt Lake, Utah
Posted: Thu Jun 17, 2021 10:12 am Post subject: Re: Bay Window Tire Size |
bruehoyt wrote: |
195/70R15 (in the right load range for a bus) is a near perfect match (circumference, anyway) for 185R14 - put it into here to compare sizes. _________________ Ben
1979 7-passenger bus
Harvee the Wonder Bus' pics |
