Brian Samba Moderator
Posted: Sat Aug 23, 2014 8:14 pm Post subject: |
scrivyscriv wrote: |
(Picture of make shift blasting box)
Well, thank you for that inspiration. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sat Aug 23, 2014 9:30 pm Post subject: |
Brian wrote: |
Well, thank you for that inspiration. |
Don't laugh, it cleaned the heck out of those heads! Pretty sure I have less than $50 in it. Works great. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1065 Location: Fair Oaks
Posted: Sat Aug 23, 2014 10:03 pm Post subject: |
Brian wrote: |
Don't laugh, it cleaned the heck out of those heads! Pretty sure I have less than $50 in it. Works great. |
Looks great to me! thanks.
Will be watching your progress... I have a 1914 that is near finished for my 69 baja... Lots of help from Vallero's machine shop to correct all the bad that was done to this engine by a prior owner. Fly cutting every where to get things straight uggg...
Jim _________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sun Aug 31, 2014 8:37 am Post subject: |
What's the best way of contacting DPR? Email or phone? |
http://dprmachine.com.s152704.gridserver.com/contact-us/
call him,his name is Jose..their shop is a real working machine shop..buckets of reground lifters,cranks and cams standing everywhere..no fancy ass showroom.. |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Sun Aug 31, 2014 8:39 am Post subject: |
johnnypan wrote: |
You wont be sorry! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
Posted: Sun Aug 31, 2014 9:07 am Post subject: |
I shot him an email yesterday (holiday weekend) but I know some guys are so busy with the shop they don't email much.. Thanks.. Giving him a call Tuesday.
I was reading up on cast cranks; just couldn't stomach using this one. Every thread asks the same question over and over.. "Should I use this cast crank?" I have yet to see a positive reply to that question... Hopefully I won't take a loss on my impulse buy with the SCAT I got.
When Jake Raby says he builds his 1,000+ engines on DPR cranks... I'm getting a DPR crank. _________________ Robert in Memphis
Posted: Sun Aug 31, 2014 12:11 pm Post subject: |
When Jake Raby says he builds his 1,000+ engines on DPR cranks... I'm getting a DPR crank. |
re ground german with welded on counterweights,he wont take a crank that's been cut as a core..check out the w100 regrind cams and re surfaced lifters too..
like everything else on these cars,used german parts (in this case with quality machine work) are best. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Aug 31, 2014 2:42 pm Post subject: |
johnnypan wrote: |
I remember some woman on some forum going on and on about how sexy Jose's voice is on the phone. |
Posted: Sun Aug 31, 2014 7:28 pm Post subject: |
Here we go:
I'm not sure about this welded area. I will be looking pretty hard at it once the case halves are clean.
The heck?? These grooves don't go all the way through, but I don't like them. They will be radiused to help prevent future stress cracks.
Crankshaft is ground .010" under on all journals. #2 main bearing was showing copper, and the #2 cam bearing halves had some corrosion-type damage that I'm not familiar with.
Lifter faces are worn out - flat. The cam looked pretty good though. I'll hang on to the crank and cam gears to go on the rebuild; the cam is a +1. Distributor gear and drive both looked pretty good.
Planning on doing the alternator stand stud-removal mod for a bolt-down stand; same with the fuel pump, I'm planning on using stock T4 fuel pump triple-square drive bolts, but probably just going straight into the case and not an insert. Mock-up will tell!
Case specs coming after the halves get done pickling in degreaser.. they nasty. _________________ Robert in Memphis
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 31, 2014 8:03 pm Post subject: |
Grooves are just from the engine tin and nothing to worry about.
If you are going to remove engine case studs for bolts, install steel inserts like Time-Sert to prevent the threads from being worn out all too soon....
Interesting weld spot, too bad not also welded in the lower pocket that tends to crack if bored for bigger cylinders. _________________ In Stereo, Where Available! |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Mon Sep 01, 2014 5:38 am Post subject: |
I ceased use of DPR cranks in 2012 after using them for almost 20 years.
That's all I am willing to say on the subject. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Mon Sep 01, 2014 7:19 am Post subject: |
-edit- duplicate _________________ Robert in Memphis
Posted: Mon Sep 01, 2014 7:29 am Post subject: |
Jake Raby wrote: |
That's all I am willing to say on the subject. |
My, this rabbit hole is just getting started now.
If you could recommend any crank from any rebuilder, for a stockish rebuild... What and who would it be? _________________ Robert in Memphis
Posted: Mon Sep 01, 2014 8:12 am Post subject: |
iowegian wrote: |
johnnypan wrote: |
She doesn't have any friends..
Lets see,Jake quit using him after 20 years..could be a number of reasons for that,not just workmanship...but hey,there are other folks out there welding up and balancing Vw cranks if Jakes comment makes you hinkey..Ive used a couple of DPR cranks with great results and would use them again.
1.Tin wearing into the case...ok
2. weld behind no.3,no problem, inspect
3. rods didn't get hot,but Id swap'em out for a balanced set if you go with the balanced crank.. |
Posted: Mon Sep 01, 2014 8:48 am Post subject: |
I'll drop a supplier that's unwilling to meet my requirements for quality and consistency faster than any other reason. I'll give them several chances to remedy the issue and I'll even write them a formal letter to explain the conditions and corrective actions that I require.
If they don't conform, they are not given any further chances. _________________ Jake Raby
Posted: Mon Sep 01, 2014 9:38 am Post subject: |
You did just fine saying you dropped him as a vendor without saying why Jake.. |
Posted: Mon Sep 01, 2014 10:02 am Post subject: |
My most recent post was a blanket statement. _________________ Jake Raby
Posted: Mon Sep 01, 2014 1:38 pm Post subject: |
Sounds like a little sand in the vagina to me.. whatever it was it still burns huh..ya gotta let shit go Jake...Hell Im sure he wont have any problem with one of Jose's counterweighted 1600 crank's for the bucket he's working on ..that engine wont see 90 horse or 5000rpm.. |
Posted: Mon Sep 01, 2014 1:52 pm Post subject: |
johnnypan wrote: |
When my name is brought up as an endorsement for a product, and isn't accurate- I must set the record straight. Thats exactly what I did in this thread. _________________ Jake Raby
