insyncro Banned
Posted: Sat Aug 09, 2014 8:33 am Post subject: |
alaskadan wrote: |
So if you grease the seals prior to going back in that would mean you dont get to put any window sealant on it right? If you use linseed oil it will lube the seal for easier install and cures to create a mild sealant.
Properly installed seals do not need sealant.
Linseed may be a good move but Ive never tried it. |
shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Sat Aug 09, 2014 10:21 pm Post subject: |
Has anyone just removed all that vinyl and left bare metal around the windows? I realized that this is how the sliding door window is, and it looks fine to me. _________________ 1989 Bostig Syncro Westy |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat Aug 09, 2014 11:47 pm Post subject: |
I'm sure it would look fine, but consider the work to get it done. You'll have to remove a lot of vinyl, and a LOT of dried on glue. The glue's gotta be hours and hours of spraying adhesive remover, scraping and finally wiping. And if all that scraping and solvent damages the underlying paint, then you've got yet another cosmetically compromised surface to deal with. Then there's the issue of what to do with the edge? You'll have to pick a line somewhere to cut and stop removing headliner - what then? Just leave a raw vinyl edge or purchase some type of edging molding. And I think you'll also find there may be screw holes and other things under there for various other van versions that you weren't aware of but won't want to look at.
So, I'd strongly consider the spray on dye route. Piece of cake compared to removal of the vinyl. I also considered the painted metal since I did a complete body repaint at the same time that included paint on the inside of the doors and slider, etc. But the above issues made me reconsider. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sun Aug 10, 2014 8:30 am Post subject: |
Thanks for the info, and good points. I should have mentioned that I actually have the interior completely stripped out right now, so it's not hard to access the vinyl.
In terms of the cut off line, the only really awkward place is at the drivers side B pillar. On the passengers side, the vinyl ends at the sliding door.
Here are some pics of what the vinyl and interior look like right now.
However, the points about having to remove the glue without messing up the paint, and dealing with screw holes, is a good one.
It seems like the best option for my situation is to replace the vinyl with new vinyl from gowesty, or maybe even home depot or joann fabrics or something... _________________ 1989 Bostig Syncro Westy |
vanagon1991 Samba Member
Joined: August 18, 2007 Posts: 152 Location: Spring Grove, IL
Posted: Sun Aug 10, 2014 3:43 pm Post subject: |
Thanks, these are great shots!!!! Will help me a lot. Here are a few ideas i was playing around with. Found a place with some really cool fabrics here
http://www.fabulessfabrics.com/
These are just graphic ideas:
_________________ 1991 Tornado Red Vanagon Carat
(2003 Subaru 2.5 conversion/Smallcar kit) |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Mon Aug 11, 2014 10:14 pm Post subject: |
Send me about 6 yards of #3 and I'll sew you up a whole headliner out of it! oh the vertigo! |
Posted: Mon Aug 11, 2014 11:45 pm Post subject: |
I have a shirt made out of something like #3. It's one of the coolest shirts I own. Finally, it is back in style. I think I bought it around 25 years ago and it's made of long fiber Egyptian cotton and still looks brand new.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
kuecker2 Samba Member
Joined: September 13, 2019 Posts: 71 Location: Kansas City
Posted: Tue Dec 01, 2020 5:47 pm Post subject: Re: Removing glue stains from wallpaper fabric |
I have been trying to figure this out myself. Applying Salon 40 or 50 developer does the trick. Don't let it dry and wear gloves when you apply
megamau Samba Member
Posted: Tue Sep 28, 2021 3:38 am Post subject: Re: Removing glue stains from wallpaper fabric |
Did you use an UV light with the product? |
datsnice Samba Member
Posted: Mon Oct 31, 2022 4:04 pm Post subject: Re: Removing glue stains from wallpaper fabric |
kuecker2 wrote: |
Hey there - is this Salon 40 Developer a beauty product you used to get those stains out? And what do you mean by "don't let it dry"? Thanks! _________________ 1989 Vanagon 2WD Full Camper
EJ22 Subaru Conversion
"Greyboy" |
Posted: Mon Oct 31, 2022 10:03 pm Post subject: Re: Removing glue stains from wallpaper fabric |
I'm curious as well, but it looks like he was last on 5 months ago so your answer may be awhile. Also, to the OP: I don't mean to offend, but could you show before/after pictures of the same spot, please? I could be wrong but studying the window and the corner wrinkles, it looks like you're showing us two different locations. I could be wrong and it's just the skeptic in me. Thanks!!
Doug
PS - update on my dye application. After all these years, it looks as fresh and clean as the day I sprayed it on. I would absolutely do it again if I had the same situation. The overall light and clean headliner look really improves the interior's sense of freshness. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Bambus Samba Member
Posted: Tue Nov 01, 2022 12:13 pm Post subject: Re: Removing glue stains from wallpaper fabric |
Is yall's Googler broken? https://www.google.com/search?client=firefox-b-1-d&q=Salon+40+developer
So it is a hair-bleaching thing and the 40 and 50 refer to lower to higher % of peroxide. Looks like it's readily available at beauty supply joints.
BUT: knowing that it's just strong peroxide makes me want to give normal household peroxide a trial on those vinyl stains-- after all, people do lighten their hair with straight OTC peroxide from the grocery/drug store. |
Posted: Wed Nov 02, 2022 8:56 am Post subject: Re: Removing glue stains from wallpaper fabric |
Bambus wrote: |
Um yeah. That's exactly why I asked him about it, because I Googled it and saw it was beauty supply product. The bleach thing made sense but not a typical product for van work so just wanted to doublecheck. _________________ 1989 Vanagon 2WD Full Camper
"Greyboy" |
