Smurf Samba Member
Joined: January 20, 2004 Posts: 914 Location: Colmar, PA
Posted: Tue May 28, 2019 3:35 pm Post subject: Re: Upgrade to dual master cylinder |
Which grommets are you using for the direct reservoir mount? _________________ 1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work |
Smurf Samba Member
Posted: Mon Jul 08, 2019 7:30 pm Post subject: Re: Upgrade to dual master cylinder |
I'll be using the WW German Master Cylinder w/ the 15mm inlets on the MC. Which grommets are you using for the direct reservoir mount?
The CIP1 reservoir dimensions are 85mm apart and the nipple part is only 13mm. I cannot find a 13mm grommet/plug for the master cylinder. I only see 7mm and 11mm inlet grommet/plugs.
I'm lost...can anyone point me in the right direction?
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D611%2D301%2DDCC _________________ 1962 Beetle
-Men at Work |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Jul 09, 2019 7:02 am Post subject: Re: Upgrade to dual master cylinder |
This same answer is on page four of this topic.. but... the general rule of thumb for master mounted reservoirs are
German Master Cylinders use the Rabbit reservoir
https://www.thesamba.com/vw/forum/viewtopic.php?t=705868
Non German use the Empi or common reservoirs now available or a Volvo 240 reservoir.
It really all depends on the grommet size and spacing your current master cylinder needs. ..
You cant use the Rabbit grommets on the Beetle German Master. The OD of the grommets are different
Other option.. use a remote reservoir and brake pipes and tubing to make the transition .. like Vw did ...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
jsclarkfl Samba Member
Joined: October 25, 2007 Posts: 13 Location: Tallahassee
Posted: Sat Aug 01, 2020 11:26 am Post subject: Re: Upgrade to dual master cylinder |
My friend JB's solution when adding a dual-circuit MC to a '64 Sedan but keeping the stock reservoir: a brass t-fitting.
_________________ Joe Clark
'65 Cabrio
Tallahassee |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Sat Aug 01, 2020 12:13 pm Post subject: Re: Upgrade to dual master cylinder |
jsclarkfl wrote: |
My friend JB's solution when adding a dual-circuit MC to a '64 Sedan but keeping the stock reservoir: a brass t-fitting. |
Problem with the "T" so close to the MC is that when one circuit goes bad, it can rob the still working circuit of fluid. Move the "T" as far uphill to prevent that. _________________ In Stereo, Where Available! |
Posted: Sat Aug 01, 2020 1:00 pm Post subject: Re: Upgrade to dual master cylinder |
Good point! I'll pass that along.
Eric&Barb wrote: |
Problem with the "T" so close to the MC is that when one circuit goes bad, it can rob the still working circuit of fluid. Move the "T" as far uphill to prevent that. |
'65 Cabrio
Tallahassee |
Denny B Samba Member
Posted: Sat Aug 01, 2020 5:26 pm Post subject: Re: Upgrade to dual master cylinder |
I would use a "Y" fitting close to the reservoir.
Just my 2 cents. _________________ I wish I knew as much today as I did when I was 18........
"I wouldn't want to belong to any club that would have me as a member" (Groucho Marx)
"Life is like a roll of toilet paper.....the more you pull off the faster it goes" (unknown)
“Life is tough, but it's tougher when you're stupid.” (John Wayne)
“One accurate measurement is worth a thousand expert opinions” – Adm Grace |
VeeDee Samba Member
Joined: February 02, 2020 Posts: 212 Location: Wolfsburg, Germany
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Sun Feb 14, 2021 2:46 pm Post subject: Re: Upgrade to dual master cylinder |
grandpa pete wrote: |
I was asked to show how I changed my single circuit master cylinder to a dual circuit master cylinder
Pink arrow points to where I attached the blue brake fluid supply lines to an existing clip on the tunnel with tye wraps
Thinking of plumbing my reservoir to MC like this and eliminating the steel tubes. I would use a brass reducing coupler to connect the small diameter hose from the reservoir to the larger diameter blue hose. I like your idea of securing the blue brake hose to the original factory clip with zip ties to keep the hoses away from the steering components.
Curious as to why the new blue brake hose is looped at the bulkhead and then turned back to the MC inlet rather than a straight run to the MC. _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
vwsplitvan Samba Member
Posted: Sat Dec 18, 2021 2:16 pm Post subject: Re: Upgrade to dual master cylinder |
Just planning installing all new hard lines and dual mc in our 62 bug.
Very helpful thread thanks
Ordering parts and noticed there is a dual circuit spacer kit. Why is this needed?
Is it needed?
Bought 67 hard lines and 67 reservoir to place in og location. Better to have a visual on fluid levels. _________________ SBS #20 UK
RHD 62 Ragtop Beetle Beryl Green
LHD 69 Squareback Peru Green
LHD 63 Splitscreen Highroof Pearl White |
Posted: Sat Dec 18, 2021 2:22 pm Post subject: Re: Upgrade to dual master cylinder |
vwsplitvan wrote: |
Is it needed? |
Check the description. Guessing it is for the bus... _________________ In Stereo, Where Available! |
Posted: Sat Dec 18, 2021 3:36 pm Post subject: Re: Upgrade to dual master cylinder |
Weird as listed for 1960-79 Beetle
Says for use when fitting a high performance mc. _________________ SBS #20 UK
BSheldon Samba Member
Posted: Tue Mar 08, 2022 1:32 pm Post subject: Re: Upgrade to dual master cylinder |
Very grateful for this thread, using it as my guide for converting my '66 to dual circuit drums. Thanks to everyone who's contributed over the years! _________________ "Betty" - 1966 L41 Sedan |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Wed Mar 09, 2022 5:07 am Post subject: Re: Upgrade to dual master cylinder |
Found this on a You Tube video ;
Use duct tape to hold master in place while fitting screws from inside;
put in brake light switches AND hook up wireing BEFORE bolting in unit
Easier solution - put the bolts on from inside, then go under the car tie wire ties once around each bolt as close to the body as possible. These will prevent the bolt pushing back in. Probably a plastic closure for your loaf of bread would work too. Get the mc on and start threading the nuts on. Then take off the wire tie or the plastic closure. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Wed Mar 09, 2022 7:46 am Post subject: Re: Upgrade to dual master cylinder |
bnam wrote: |
Easier solution - put the bolts on from inside, then go under the car tie wire ties once around each bolt as close to the body as possible. These will prevent the bolt pushing back in. Probably a plastic closure for your loaf of bread would work too. Get the mc on and start threading the nuts on. Then take off the wire tie or the plastic closure. |
I almost always do such job by myself. I start the line fittings by hand a few turns to eliminate chance of crossthreading. Then I stuff rags under the master cylinder to prop it in place while I get the bolts started from the driver compartment.
However, I think that the duct tape technique is clever, and may try that in the future. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Wed Mar 09, 2022 7:48 am Post subject: Re: Upgrade to dual master cylinder |
bnam wrote: |
kacook3 Samba Member
Posted: Sat Mar 12, 2022 4:59 pm Post subject: Re: Upgrade to dual master cylinder |
I was going to do the same thing you mentioned below to add a dual master cylinder conversion to my 61 bug. I am having a hard time finding the proper sized brass or stainless steel barbed reducer. The small diameter brake fluid hose attaching to the metal reservoir tubes is 4.5mm ID and the larger blue hose that connects to the master cylinder is 7mm ID. Where can I find a proper sized reducer to connect these and what did you use or does it work just as well to use hose clamps to hold the blue hose onto the smaller steel tubes of the reservoir.
FL-Frank wrote: |
Curious as to why the new blue brake hose is looped at the bulkhead and then turned back to the MC inlet rather than a straight run to the MC. |
SparksLP Samba Member
Posted: Sat Feb 25, 2023 5:37 pm Post subject: Re: Upgrade to dual master cylinder |
I don't think it got referenced directly, but some have posted similar ideas to this JBugs video from a few years ago:
https://youtu.be/CorjjxZ7gRM
My question about it relates to the way he routed the OG reservoir to the dual cylinder reservoir. He basically poked a hole in the tip and used a grommet to plug the old reservoir into (1:30 into the video). Any concerns with doing it that way? Seems like it would seal up and not spill out to me... _________________ Tom
1966 VW Beetle Sunroof Sedan |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Sat Feb 25, 2023 6:53 pm Post subject: Re: Upgrade to dual master cylinder |
If I were to do it that way, I would only be using the original reservoir above as a fill-funnel to run the fluid down to the new dual-chamber reservoir, and visually ensuring that the new reservoir below is NOT overfilled. The new grommet that the hack hacked in there MAY hold fluid under gravity pressure (aka "head" or "static" pressure), but what the hack didn't tell you in the video is that if you fill up your O.E. reservoir up above, fluid WILL leak out of the vented cap below until the level above is exhausted, and be lying spilled all over your pan. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Feb 25, 2023 6:54 pm Post subject: Re: Upgrade to dual master cylinder |
SparksLP wrote: |
My question about it relates to the way he routed the OG reservoir to the dual cylinder reservoir. He basically poked a hole in the tip and used a grommet to plug the old reservoir into (1:30 into the video). Any concerns with doing it that way? Seems like it would seal up and not spill out to me... |
To answer your question a leak at the grommet won't matter because the thing is the reservoir they put on the M/C has a vented cap so it is going to leak there if the stock reservoir is filled up. As he mentions the stock reservoir is just a funnel now.
For certain not the way I would do it. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
