vwible Samba Member
Joined: January 02, 2005 Posts: 160 Location: East Windsor, NJ
Posted: Tue Aug 19, 2014 6:16 am Post subject: What size oil pump do I have? |
I'm trying to determine the size of the oil pump in my engine.
The pump body extends about 12.5 mm from the case to the oil pump cover plate. Any ideas as to what size pump it is?
1600 dual relief case, 74 mm stroke, 90.5 pistons.
I did not build it, but am trying to get back to solid running condition.
Oil cooler is a Type IV, using doghouse fan shroud extension kit. _________________ 1970 Tin Top Walk Through Bus |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Tue Aug 19, 2014 6:19 am Post subject: |
Measure the gear inside in MM and there's your answer _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
vwible Samba Member
Posted: Tue Aug 19, 2014 6:32 am Post subject: |
Unfortunately, the engine is assembled and in the bus. _________________ 1970 Tin Top Walk Through Bus |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Tue Aug 19, 2014 6:37 am Post subject: |
vwible wrote: |
Unfortunately, the engine is assembled and in the bus. |
You're SOL. Only way to know is to measure the gears. _________________ Glenn
Member #1009
#BlueSquare |
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Tue Aug 19, 2014 8:13 am Post subject: |
According Schadek catalog:
8 mm flange = 21 mm pump
12 mm flange = 26 mm pump |
