My 1973 Thing project
Page: Previous  1, 2
seilerj
seilerj is offline
PostPosted: Wed Aug 20, 2014 7:04 pm    Post subject: Reply with quote
Shoyrtt wrote:
seilerj wrote:
I want to try to do the front end myself but I'm afraid it may be a little beyond my comfort level ....I'm thinking I may need just to jump in and go for it but holding off for now.
I would start with the rockers and then the parcel tray before the nose. Wink
What are your plans with the pan?
I have a set of full pans
HUGO bOSS
HUGO bOSS is offline
PostPosted: Sat Dec 27, 2014 6:19 pm    Post subject: Reply with quote
Any news?
http://www.thesamba.com/vw/forum/viewtopic.php?t=538182
seilerj
seilerj is offline
PostPosted: Sun Dec 28, 2014 8:06 am    Post subject: Reply with quote
Everything got put on hold temporarily until I build my new shop it's almost completed hoping to get started again in earnest in the spring
seilerj
seilerj is offline
double
seilerj
seilerj is offline
PostPosted: Sun Dec 28, 2014 8:07 am    Post subject: Reply with quote
Double
seilerj
seilerj is offline
Double
GI Joe
GI Joe is offline
PostPosted: Sun Dec 28, 2014 8:11 pm    Post subject: Reply with quote
Seilerj,
Are you posting from an IPad, by chance?
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
3Duckdaddy
3Duckdaddy is offline
PostPosted: Mon Dec 29, 2014 1:58 pm    Post subject: Reply with quote
Seilerj,
What part of IL are you in? I am near Springfield. I may be interested in any body parts you replace. Mine is crustier than yours. Sad
Good work on the restore.
George
Jenny'sThing
Jenny'sThing is offline
PostPosted: Wed Dec 31, 2014 2:26 pm    Post subject: Reply with quote
That trunk sheet metal is awesome! My thing has a hole where the trunk is. Any chance there is more of that sheet metal where yu found it?
Thanks!
seilerj
seilerj is offline
PostPosted: Sat Jun 18, 2016 10:04 am    Post subject: Re: My 1973 Thing project Reply with quote
Ok... The captured nuts on the inside rocker were spinning... I knew I already had rocker rot at the rear of the rocker. I know I will need to open up the rockers to weld in new nuts on the inner rocker. I cut access holes to keep the captured nuts from spinning and get the pan bolts out.
With the exception of the captured nuts the inner rocker looks to be good shape..
I have a NOS outer rocker... The question is ... Where is the best place to cut the outer rocker??
I need to be able access the inner rocker captured nuts and weld in new ones.
I want to clean /POR as much of the inside of the inner rocker as possible while outer rocker is opened up.
I want to maintain the original seams.
I was thinking a straight line across the rocker horizontal would be easiest.
Any input would be greatly appreciated
Ron Domeck
Ron Domeck is offline
PostPosted: Sat Jun 18, 2016 2:36 pm    Post subject: Re: My 1973 Thing project Reply with quote
Center of rib. Easiest to work and best for welding without warping.
seilerj
seilerj is offline
PostPosted: Sat Jan 28, 2017 9:15 am    Post subject: Re: My 1973 Thing project Reply with quote
Rear body mount rubber appears to be a 181 part number ....it's part #3 on the parts list
.... that differs from the parts list... it seems thinner then the body mount rubbers on front... any ideas?....
Not having any luck finding the 181 part
seilerj
seilerj is offline
PostPosted: Thu Feb 02, 2017 10:50 am    Post subject: Re: My 1973 Thing project Reply with quote
I think I found a solution… I found some thinner rubber pads part number 111899119B. I will have to cut them down and enlarge the hole they are the right thickness and width
JayC
JayC is offline
PostPosted: Fri Feb 03, 2017 9:22 am    Post subject: Re: My 1973 Thing project Reply with quote
Interesting catch on the part number. I hadn't noticed that before. I am almost positive when I mounted the body back to mine, I used part number 111 899 115A from the Thing Shop all the way around (front and back). There didn't seem to be any issues.
jay
Ron Domeck
PostPosted: Fri Feb 03, 2017 10:37 am    Post subject: Re: My 1973 Thing project Reply with quote
We use the ones that are about 1/2 in. and cut to fit. You can put the wrong size in an change the rear door gap. I have taken cars apart that has 1/4 in. to 1/2 in. from the factory.
seilerj
seilerj is offline
PostPosted: Fri Feb 03, 2017 12:39 pm    Post subject: Re: My 1973 Thing project Reply with quote
Jay
The ones you mention from the thingshop are the mounts that I got for the front body mount.....and they seemed right... im sure they would have been fine to use on the back as well...but I think the other ones I found will work better.
seilerj
seilerj is offline
PostPosted: Tue May 15, 2018 3:42 pm    Post subject: Re: My 1973 Thing project Reply with quote
In the process of rebuilding my distributor. (113 905 205 AN)… Are all these replacement parts correct? I've seen a few different part numbers that contradict these in another location
Page: Previous  1, 2
Page 2 of 2
