HerrMahnenschmidt Samba Member
Joined: July 22, 2011 Posts: 94 Location: WY, NoCO, NoCA, here, there, elsewhere...
Posted: Thu Aug 21, 2014 2:25 pm Post subject: stock oil pump question |
I have searched for and read nigh every thread on the topic of T4 oil pumps, stock and aftermarket. No mention of this problem that I have found.
In this photo, the drive tang on both pumps has noticeable wear (red-circled). The clean pump is from a GE engine being rebuilt; the dirty pump from a spare GD engine. The wear spot is present on the same side on both ends of the tang. Both engines had stock cams/gears in them. I do not see any corresponding wear on the cam drive slot on either cam.
Is this wear normal and acceptable? Is there a known cause and fix? Should I be concerned, or perhaps up my dosage of Lexapro?
42?
Has the CB Performance 1829 Maxi Pump 1 for 914/T4 application proven to be a reliable replacement?
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1829
_________________ 1977 Westfalia --
- rebuilt stock-spec 2.0l FI engine; 002 tranny w/stock gearing with 215mm flywheel/clutch/pp |
SGKent Samba Member
Posted: Thu Aug 21, 2014 2:29 pm Post subject: |
they all wear there. The more the wear, the longer it has been in use. Usually the more wear there is there, the more freeplay there is in the gears. There is a spec in Bentley for acceptable wear limits. Phil - Whip 618 can tighten up some of the play but not all of it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Aug 21, 2014 2:39 pm Post subject: |
Thanks. Of course while continuing to search after posting this I was able to find a pic posted by TCash showing the same symptom --
Fair enough... _________________ 1977 Westfalia --
Last edited by HerrMahnenschmidt on Thu Aug 21, 2014 4:30 pm; edited 1 time in total |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Thu Aug 21, 2014 3:18 pm Post subject: |
Yep...thats the pump whose engine died due to contact with the cam gear bolts.
Classic mark on the aluminum boss and on the nuts. I have one worse than that as a trophy. I learned the hard way. Double thrust cam bearings with careful checking of the gap between highest point on cam and the highest point on the oil pump case.
The drive tang wear you see.....is common....but its better or worse depending on exactly how far out of actual center the oil pump is versus the center of thee cam casting boss.
See...there is some manufacturing tolerance in the centerline location of the oil pump....and some casting variation in location of the cam centerline in the case and some tolerance in the oil pump bore location.
There is not much difference in any one of these items...but when you add them all up....the center line of the oil pump shaft is not exactly perfect with the center line of the cam. Most of the difference is in the oil pump bore location....if it were not we would have serious issues with timing gear lash....and not just a +/- 1,2,3 etc.
The wear spot is where the lead corner touches the wall of the slot. If the oil pump centerline were perfect with the cam...you would see nothing but a fine silver line of wear on the corner of the tang maybe .003-.005" wide.
I have seen a very few early 411 and 412 cases this well entered. But as the off center and unaligned shafts turn the tang flank rubs all the way along the wall of the slot in the cam like an eccentric love-joy coupling on a pump shaft.
You will see corresponding wear in the slot wall.
Ray |
Posted: Thu Aug 21, 2014 4:37 pm Post subject: |
That is an interesting solution on the part of those detail-obsessed Germans.; essentially a type of U-joint...
I will put the original 'clean' pump back in service then. The lash and clearances on it are tight, so it should continue to pump for at least the life of this rebuild.
Thanks SGKent & Ray. _________________ 1977 Westfalia --
Posted: Thu Aug 21, 2014 5:13 pm Post subject: |
Disassemble the pump and change out the o-ring. You can also press out the idler shaft and then grind it about 1/16 shorter. (Note that some shafts are already plenty short enough.) This will allow you to do a better staking job so the shaft is less apt to walk out and hit the cam. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu Aug 21, 2014 11:33 pm Post subject: |
We can we do to eliminate this wear, or is it not worth worrying about?
Do T1 pump/cam gear setups have this issue too? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
SGKent Samba Member
Posted: Thu Aug 21, 2014 11:46 pm Post subject: |
asiab3 wrote: |
Do T1 pump/cam gear setups have this issue too? |
it comes with the miles. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tcash Samba Member
Posted: Fri Aug 22, 2014 7:35 am Post subject: |
That's affirmative. |
Posted: Fri Aug 22, 2014 9:18 am Post subject: |
asiab3 wrote: |
We can we do to eliminate this wear, or is it not worth worrying about? |
Run something thinner than 20w50 so long as your engine will make acceptable oil pressure. This of course will not eliminate it, just reduce it. |
Posted: Fri Aug 22, 2014 9:48 am Post subject: |
Also....making sure you have proper/best oil pump to cam slot depth settings and proper end play control of your cam is key.....for even more important reasons than just tang wear.
A great and very cheap modification is to run a double thrust bearing set. It is insurance against failure and has better control over in/out oscillation of what tolerance there is....so less wear on the tang as well.
The double thrust bearing set used to be available from the type 4 store. In a pinch just buy two sets of single thrust bearings and make your own. Ray |
Posted: Fri Aug 22, 2014 10:08 am Post subject: |
After several hours spent grokking my oil pump, I have to wonder why no one (VW?) has thought to machine an internal circlip groove to retain the idler shaft. I know that requires machining (=$$$), but a circlip would be a much more reassuring way to retain the shaft, rather than peening or pinning. Properly implemented, I think a circlip would be much less likely to get loose and bounce around than a pin.
Geez I wish I had access to a basic machine shop... _________________ 1977 Westfalia --
Posted: Fri Aug 22, 2014 11:35 am Post subject: |
Pinning the shaft is actually perfect. To do this you need a good basic drill vise and a decent drill press. Dont try to do this with a hand drill
You need to set the pump up in the drill vise so that the shaft is clamped so it cannot squirm or move. Then put a small flat spot with a file in the correct location. Then centerpunch it....then turn the drill by hand until you start to get decent centered penetration.
Use a sharp high speed steel bit and a very good tapping oil for a lube.... Castrol moly dee or take some tapping fluid and mix with a dab of cv grease.....just like you would do when drilling chromoly or other hard steels.
All you need is about a 3/64" split tension pin. Then trim each end leaving them with about 1/16" stickjng out on each side and then distort each end so it cant work out. Ray |
SGKent Samba Member
Posted: Fri Aug 22, 2014 11:44 am Post subject: |
they can be pinned with a set screw and red loctite. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Aug 22, 2014 12:40 pm Post subject: |
SGKent wrote: |
they can be pinned with a set screw and red loctite. |
True.....but after seeing what a small piece of metal can do when introduced to that area of the engine (total destruction) and with the limited amount of aluminum in that boss area....I opted to pin mine.
It took about 5 minutes. Ray |
