60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Fri Aug 22, 2014 8:16 am Post subject: Fuse box template - 3D printing |
Does any have a template and measurements for an 8 fuse box? Not including mont.
Does anyone have a template and measurements for screw terminal fuse box?
My goal is to mount an 8 fuse, fuse box from a '61 into a 6 fuse, fuse box mount, for an early '59. I have access to a 3-D printer and would like to create a mount that the 8 fuse, fuse box could mount or snap into a 6 fuse, fuse box (minus the fuses obviously). Essentially creating a plastic mount.
I don't have a mount clip that I could weld in, or I would, and I cannot drill holes in the 8 fuse, fuse box to mount into the '59. Furthermore, I'm not keen on doubling up on the 6 fuse box.
Anyone have technical drawings, templates of the two different fuse boxes? _________________ 77 Westy - Cape Cod Sage
LLAP |
Clara Samba Member
Posted: Fri Aug 22, 2014 8:51 pm Post subject: |
How about one of these:
it has eight fuses and mounts to the same mount as the 6 fuse fuse box.
At least I think it does.
This fuse box was used for part of 1960 |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sat Aug 23, 2014 4:59 am Post subject: |
Clara wrote: |
That's what I need!!! _________________ 77 Westy - Cape Cod Sage
LLAP |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Sat Aug 23, 2014 5:24 am Post subject: |
Dan, you should have asked me on Thursday. I have some blown out units you could borrow for measurement. The problem will be sourcing and mounting the spring copper contacts, I would think. Let me know exactly what you need and I'll add it to the pile of parts from the all aircooled gathering swap. Or should I send it straight to you bro with the printer? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Sat Aug 23, 2014 6:53 am Post subject: |
j.pickens wrote: |
Dan, you should have asked me on Thursday. I have some blown out units you could borrow for measurement. The problem will be sourcing and mounting the spring copper contacts, I would think. Let me know exactly what you need and I'll add it to the pile of parts from the all aircooled gathering swap. Or should I send it straight to you bro with the printer? |
Thanks John! Yeah I didn't remember till after we left SPVC HQ about the fuse box.
I might fab a bracket with a piece of scrap sheet metal... But the chance to try and 3D print a bracket is more exciting! _________________ 77 Westy - Cape Cod Sage
LLAP |
