57 Single Cab repair from Austria
Page: Previous  1, 2, 3 ... 29, 30, 31 ... 39, 40, 41  Next
Huetti_1989
Huetti_1989 is offline
PostPosted: Mon Apr 27, 2020 8:35 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
@Bill come over, i have beer Very Happy
installed the Engine bay seal, good feeling to get forward...
-Christian
My 1957 semaphore Single Cab:
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1954 Deutsche Bundespost Barndoor:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34 Flipseat Westfalia:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
Huetti_1989
PostPosted: Wed Apr 29, 2020 5:32 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
continue the fillering...
-Christian
MY 1967 Sparsamba:
V-Dub Guy
V-Dub Guy is offline
PostPosted: Wed Apr 29, 2020 5:34 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
Looking good Christian!!! Keep at it!!
djfordmanjack
djfordmanjack is offline
PostPosted: Wed Apr 29, 2020 11:54 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
Christian, awesome work all over !
your engine data is misleading I think.
case casting date of 24th of February 3rd shift in 1955 totally fits the early post BD 55 production and og engine number. the stamping in the og place looks totally original to me.
Whats misleading is the 'Austausch' stamp below it and the number to the side of the gen stand. the 350268 would put it into late 1951 production, maybe used in a 52 BD and they possibly stamped that replacement # ?!?! who knows. the script type of the additional number looks very much like later og VW engine numbers. There is a whole lot of mistery going on around those factory or garage rebuilt 'Austausch' units. some had the og stamped numbers milled off, later engines have those circular arrows stamp indicating a replacement and again others still carry the og engine # like yours along with the squarish Austausch stamp.
anyways, nice motor !
62 Dickholmer, custom color Seeblau L360
Huetti_1989
PostPosted: Sun May 03, 2020 1:55 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
The engine is out of a 53 firetruck, maybe they bought an exchange engine in 55?
I also like this engine very much, i hope a good one to start driving.
Some more little steps the last days:
Found out that the ruber seals from the nos front brake zylinders are dead, so i replaced them.
Some more work on the brake lines, installed the flexible brake lines front and rear and the new brake switch.
Installed the steering absorber.
And the fresh painted front shifter rod and the shifter with a nos shifter plate, what a good feeling to shift that car the first time since i own it!!
The next goal would be driving it out from the shop to get the filler drying in the sun...
-Christian
MY 1967 Sparsamba:
Huetti_1989
PostPosted: Wed May 06, 2020 1:38 pm    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
I cleaned the vin and germany plate.
I had it a day in clr cleaner i bought over canada, then i go with 0000 steel over it and then with Carnauba wax.
-Christian
MY 1967 Sparsamba:
Eric&Barb
Eric&Barb is offline
PostPosted: Wed May 06, 2020 2:22 pm    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
Might consider taking the next step, zinc plating at home:
https://duckduckgo.com/?q=home+zinc+plating&t=canonical&ia=web
In Stereo, Where Available!
matthew henricks
matthew henricks is offline
PostPosted: Thu May 07, 2020 9:54 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
I second this. It is not hard and does not require anything special. Takes a little bit to get good results.
62DoKaGuy
62DoKaGuy is offline
PostPosted: Thu May 07, 2020 10:35 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
-Christian
Have you tried simple vinegar (Essig) and water? I did this with my brother-in-law's plates from his '59 single cab, with great results after cleaning up with same 0000 fine steel. I haven't tried CLR yet, but I'm interested to know if you've both and how they compare...wife had vinegar so I opted for that hahaha.
This looks gorgeous by the way. I like the lingering "used" look against the new paint. Wie früher gesagt, echt Hammer geile Arbeit! Sauguad.
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
Clatter
Clatter is offline
PostPosted: Thu May 07, 2020 10:57 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
Huetti_1989 wrote:
I really like this look.
Restored, but not over-restored.
A bit of orange-peel in the paint, just like factory,
and the tags pretty, but showing their age.
Nice point to draw the line. Cool
Bus Motor Build
What’s That Noise?!?
V-Dub Guy
PostPosted: Thu May 07, 2020 11:18 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
Mine looks similar. First I tried the old “coke” trick that didn’t work....then I tried extra strong vinegar and that worked well.
Before
After
Huetti_1989
PostPosted: Tue May 12, 2020 7:30 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
That matched 100% what i want to look like, thanks!
Thank you, i try that the next time!
I first read now about home zinc plating, i want to try that sometimes!
I send parts to a company for zinc plating times before for my Baywindow, at this Single Cab i don´t want it to shiny, because it was build as a cheap car for hard work on the farm here in austria.
V-Dub Guy wrote:
Mine looks similar. First I tried the old ?coke? trick that didn?t work....then I tried extra strong vinegar and that worked well.
looks good! next time i try vinegar!
some more work done:
Changed the broken cuffs on the nos brake cylinders.
Painted the new brakedrums and some little little parts i blasted this week.
Note: don´t let the fresh painted drum fall on the floor outside...
-Christian
MY 1967 Sparsamba:
chrisflstf
chrisflstf is offline
PostPosted: Tue May 12, 2020 8:11 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
For the brake drums that fell, like we say here - shit happens. Good job anyway!
Eric&Barb
PostPosted: Tue May 12, 2020 8:34 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
Looks good! Do not forget the metal brake line grommet.
Huetti_1989
PostPosted: Thu May 14, 2020 7:17 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
here we say the same Very Happy
yes, they are waiting anywhere in a box!
i found a nos Speedo cable, it looks a little bit different as the one that comes with the car but think it should work, length is the same.
-Christian
MY 1967 Sparsamba:
Huetti_1989
PostPosted: Sat May 30, 2020 2:49 pm    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
So the rear brake is now ready after the screw for the brakezylinder get broken at 55Nm, thats a lot for a 10.9 M8 i think. It was not easy to get the broken one out, but with a another screw i stopped at 45Nm.
ATE rear brake zylinders, this is what i want when i ordered the „good Quality“ stuff from the online vw shop, thaks PPS.
-Christian
MY 1967 Sparsamba:
Huetti_1989
PostPosted: Thu Jun 04, 2020 3:50 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
some work on the Starter, 4M make it a little bit to old i think, but worth a try.
-Christian
MY 1967 Sparsamba:
mandraks
mandraks is offline
PostPosted: Thu Jun 04, 2020 7:25 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
-Christian
Christian,
i can't tell from your picture, but ATE, and many OLDer VW mechanics recommend the use of ATE Blue Brake paste for the assembly of all brake cylinders.
see: https://www.ate.de/media/2317/technical_datasheet_brake_cylinder_paste.pdf
regards
Uli
farnhamassoc
farnhamassoc is offline
PostPosted: Thu Jun 04, 2020 7:33 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
I would almost drive that one as it was compared to this one.
Owned Countless VWs over the last 35 years.
Restored near 100 vws.
80 Rabbit diesel 1.9 TDI turbo 45mpg
06 Jetta TDI 45mpg
Restored several 11 window kombi and standard
Current inventory 66 delux hard top, so23
60 ragtop and 61 hard top bugs 54 hardtop bug
67 tin top so42 62 SO10 ruthmann bucket truck
nshaddox
nshaddox is offline
PostPosted: Thu Jun 04, 2020 8:00 am    Post subject: Re: 57 Single Cab repair from Austria Reply with quote
I've broken the same bolt before. Pretty sure that torque spec is on the known list of Bentley manual errata.
Neil
Page 30 of 41
