jspbtown Samba Member
Posted: Fri Aug 29, 2014 10:35 am Post subject: Mexico engine? |
I am digging through some of my old stuff to sell and I came across an engine I forgot I had.
It is an "AJ" case and says something along the lines of "Product of Mexico" on the left side of the case.
These any good? |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Aug 29, 2014 11:17 am Post subject: |
I have built on Mexico cases. The only way to know if it is serviceable is tear into it and mic it. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Fri Aug 29, 2014 11:25 am Post subject: |
Same. I found a Mexican case. had to cut the bore.. Works great.
.02" over bore. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Posted: Fri Aug 29, 2014 12:43 pm Post subject: |
Quote: |
The only way to know if it is serviceable is tear into it and mic it. |
Yes...I understand what I have to do for the specific engine. My question was more general about the Mexico and AJ engines in general.
Known for reliability? No issues with the cases? etc etc. |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Fri Aug 29, 2014 1:38 pm Post subject: |
Does your case have a hole for a fuel pump? An AJ prefix should be a fuel-injected case, which were made of AS21 instead of AS41 and supposedly more durable. _________________ 1966 Karmann-Ghia convertible |
Posted: Fri Aug 29, 2014 2:13 pm Post subject: |
I hate having an old brain.....
Its NOT an "AJ" motor....is an "AF" motor (AF524825) so I am assuming late 1977 vintage. "Low Octane" version?
Sorry for the confusion...but my questions still stand. |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Fri Aug 29, 2014 2:26 pm Post subject: |
Short answer, yes. They came with a full set of case savers in 8mm. The metal the case is made of is good quality that holds up well. I used one of these cases to build the engine in my drag car. |
Posted: Fri Aug 29, 2014 9:23 pm Post subject: |
Great...thanks for the response.
Now the age old question...sell it as part of my VW liquidation or hold onto it in case the affliction returns..... |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Sat Aug 30, 2014 2:42 pm Post subject: |
tear it down and inspect as jfats said and save if all is good....engine cases are expensive now. |
MonkeySee Samba Member
Posted: Sat Sep 27, 2014 7:51 pm Post subject: |
I just picked up the same motor. One of my case halves has 8m on the side. Is this the case savers you're talking about? Also, where do I find the motor number? It's not by the Gen stand. (has fuel pump studs and block-off plate) |
