airkooledchris Samba Member
Joined: January 25, 2005 Posts: 2640 Location: Where the pacific ocean meets the redwood forest
Posted: Tue Sep 02, 2014 11:26 am Post subject: timing scale to cooling fan bolts clearance |
Is there a known cause for the cooling fan bolts to grind into the back of the timing scale?
Ive had to, previously, shim the cooling fan out away from the case on the center/top mounting bolt so it wouldn't grind up against the back of the timing scale.
My bus had AC on it, and after digging a bit I noticed that the thickness of the pulley behind the cooling fan was more than the spacer that usually sits here. I swapped in the spacer in place of the AC pulley and that seems to have bought me *just* enough space where it *might* not grind on the back of the timing scale - but it's so damned close im guessing it'll still end up shaving it a little.
I have one of those new metal timing scales so the first thing I did was check to see if they were both the same height - and they are. Both the new metal one and the replacement plastic one I had been running bumped into the cooling fan bolts at about the same point.
Perhaps the cooling fan housing itself can vary the height of that mounting point, enough where it sends the timing scale too deep towards the cooling fan?
Just wondering if others have had this same experience and what, if anything, they did about it. _________________
metahacker wrote: |
... i would say that, if it's an option, (edited) not listen to any forum pessimism.. |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Tue Sep 02, 2014 12:24 pm Post subject: |
Grab a hold of the fan and push and pull on it. If there is noticeable play the crank shaft end play needs to be adjusted.
Good Luck |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 45371 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Tue Sep 02, 2014 12:38 pm Post subject: |
Fan shrouds that have had air conditioner compressors mounted sometimes get loose on the studs and sag. _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Tue Sep 02, 2014 4:54 pm Post subject: |
Ive had the fan shroud off and it's been cleaned and remounted since then. (which should take care of the loose issue, since it's been taken apart and put back together - then mounted back to the motor?)
no noticeable play in the fan when you pull/push it.
I'll try and grab some photo's when I get a chance. I think I have a spare fan housing as well, and can try measuring the height of that top/center mounting point for the scale. _________________
metahacker wrote: |
aeromech Samba Member
Joined: January 24, 2006 Posts: 14403 Location: San Diego, California
Posted: Tue Sep 02, 2014 5:44 pm Post subject: |
I recently worked on a T4 and had the fan off along with the fan housing. Behind the fan lives the pulley for a/c and it acts as a shim. I purchased the aluminum timing scale from Bus Depot and aside from the fact that I had to enlarge the two mounting holes to accommodate the 6mm mounting bolts it seems to fit fine. Busdaddy, do you recognize the fan?
_________________ Licensed Airframe and Powerplant Mechanic
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Sep 03, 2014 9:58 am Post subject: |
Both cooling fans have the same mounting depth for that top/center bolt, so I don't think that's an issue.
Maybe ill just take the cutoff wheel on my dremel and shave down the long bolts on the cooling fan:
metahacker wrote: |
gleason Samba Member
Posted: Sun Apr 02, 2017 6:25 am Post subject: Re: timing scale to cooling fan bolts clearance |
Bringing and old post back to top. I have a CJ type 4 2.0 that we just rebuilt the top end on. I also am having an issue with the bolts for the fan such as he shows above and it hits my timing scale. If I shorten these to the back side of the nut, will that throw my balance off? It seems to be running very true using my eyecrometer, but I'm not able to time it accurately. Everything went back together as dissassemble, but that donor engine DIDN'T have a scale on it. Any input? Busdaddy? I might try to put a couple washers on the back of the scale to pull it away but would rather fix it right. Thanks |
Posted: Sun Apr 02, 2017 3:50 pm Post subject: Re: timing scale to cooling fan bolts clearance |
Can't say why this is happening, but you could either shim the scale out of use a Dremil and shorten all the bolts the same amount. I have found that when dealing with something like this, if you grind on all the bolts for the same length of time you will not effect the balance |
Posted: Sun Apr 02, 2017 4:06 pm Post subject: Re: timing scale to cooling fan bolts clearance |
I loctited 2 6mm washers (one on each side of scale) and installed it. No more rubbing! Thanks |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Mon Apr 03, 2017 4:17 am Post subject: Re: timing scale to cooling fan bolts clearance |
How dare you,fixing things the simple way,you go back and remove that fan replace the bolts with shorter ones and get that fan balanced.2 washer and 10 minuets work,you should have worked on it for a least 3 days and a $100 in parts.
;Nelson _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
