68 double cab rubber gate bumpers
westy66
westy66 is offline
PostPosted: Tue Sep 02, 2014 7:16 pm    Post subject: 68 double cab rubber gate bumpers Reply with quote
I have new Gerson gates on my DC (no holes) and my crusty gates are long gone shipped to Puerto Rico.
Would someone be willing to tame some measurements, pictures so I can drill some holes. Gulp!
T hx!
Bob
'66 Westfalia SO44
'68 Double Cab
'68 Eriba Puck
'03 EuroVan Weekender
Lionhart94010
Lionhart94010 is offline
PostPosted: Tue Sep 02, 2014 8:28 pm    Post subject: Reply with quote
Are you talking about tail light holes?
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 72 KG GT;0) 12 JSW TDI
Other owned VWs 59, 68 1500s, 69 & 71 Bugs; 72 & 73 S-Bugs; 67 Westy, 67 Deluxe, Other 71 DC
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
Brian
Brian is offline
PostPosted: Tue Sep 02, 2014 8:29 pm    Post subject: Reply with quote
Negative, there are little rubber bumpers that stop the gates from smacking the body. My holes were filled on the rear gate and would love to hear some measurements.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Lionhart94010
PostPosted: Tue Sep 02, 2014 8:46 pm    Post subject: Reply with quote
Two inches down to touch the top of the rubber from under the ledge ruler at an angle, other measurements look like they would be a bit more complicated to get exact without taking them off
Brian
Brian is offline
PostPosted: Tue Sep 02, 2014 8:50 pm    Post subject: Reply with quote
This is a split but is the best picture:
Looks like the tail gate bumpers just miss the tail lights.
Here on the doppelkabine, you can see you need the rubbers to line up with the door, and its probably equidistant on the other side. And since there is no treasure chest, I imagine there is a bumper that meets the gate bumper on both sides.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Lionhart94010
PostPosted: Tue Sep 02, 2014 9:01 pm    Post subject: Reply with quote
The white DC is missing both corresponding side gate bumpers that should be mounted on the body, side gate bumper rests on a body bumper of the same size
Brian
Brian is offline
PostPosted: Tue Sep 02, 2014 9:22 pm    Post subject: Reply with quote
The two dots should be it. The body guy probably filled in your holes, so you're good to put your holes anywhere.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
busdaddy
busdaddy is offline
PostPosted: Tue Sep 02, 2014 10:12 pm    Post subject: Reply with quote
No front stops on the body, only the rears:
I'll try and get some measurements tomorrow, I'm guessing the Klassicfab gates don't have the cutouts in the inner reinforcements to clear the nuts? That would provide clues where to drill.
They all line up just to one side of a body seam or opening where the metal has some backing nearby.
Lionhart94010
PostPosted: Tue Sep 02, 2014 10:41 pm    Post subject: Reply with quote
Mine is a 71 and has front stops too... it is 1/2" from the seam for the bottom one and 1/4" for the top one(that is the outside diameter of bumper closest to the seams)
Side Gate, back top bumper is aprox 11 1/8" from the forward edge of the rear seem, the bottom one is 1 1/2" forwards of the rectangular marker light (outside diameters of rubber bumpers)
Side Gate rear top gate bumpers are aprox 12" from edge (outside diameters of bumper)
The outside top diameters of bumper of the rear gates rest about 1/2" away from the deck lid opening edge when open the upper 10mm bolts all seem to just go through the double sheet metal in the gates, I would not be surprised if the factory had a jig that was setup from the insides of the gates to make sure the bolts went through the double sheet metal
FYI also double bumpers for the rear cab door-
Im sure BD will provide better info to help you guys ;0)
the outside top diameters of bumper of the rear gates rest about 1/2" away from the deck lid opening edge
westy66
westy66 is offline
PostPosted: Wed Sep 03, 2014 4:25 am    Post subject: Reply with quote
Great response guys. This will be a good resource. One more thing, can someone get a picture of the inside of a gate. I believe some of the bumpers were held on by a nut visible on the inside of the gate.
'66 Westfalia SO44
'68 Double Cab
'68 Eriba Puck
Brian
Brian is offline
PostPosted: Wed Sep 03, 2014 11:09 am    Post subject: Reply with quote
here are my rear sides.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Lionhart94010
PostPosted: Wed Sep 03, 2014 1:06 pm    Post subject: Reply with quote
71 DC Passenger side Rear Gate
71 DC Passenger side, side gate, rear bumper
71 DC Passenger side, side gate, Front bumpers
No inside bolt hole visible..
westy66
westy66 is offline
PostPosted: Wed Sep 03, 2014 1:41 pm    Post subject: Reply with quote
Wow, perfect. Thanks for taking the time.
'66 Westfalia SO44
'68 Double Cab
'68 Eriba Puck
Kurt Burton Photo
Kurt Burton Photo is offline
PostPosted: Sun Feb 28, 2016 4:34 pm    Post subject: Re: 68 double cab rubber gate bumpers Reply with quote
Hi:
I'm trying to find instructions on how to install the side (2 piece) windows in the back seat (one
is in the 3rd door) of my 68 double cab.
I can't find any instructions on line.
Can you please offer me some help or direction?
Thank You,
[email protected]
