Trouble finding specifics on Carb..( I searched)
Page: Previous  1, 2, 3
OB Bus
OB Bus is offline
PostPosted: Mon Nov 09, 2015 3:11 pm    Post subject: Reply with quote
busdaddy wrote:
khalimadeath wrote:
Im about ready to just buy a new damn carb lol.
Brand new likely won't be any improvement over your current one and probably just adds a whole new set of issues. Buy a rebuilt German carb from Volkzbitz, almost the same price but it actually works right out of the box. And team it up with the correct distributor, you'll wonder how you put up with the way it ran before.
It may not solve all of your problems, but it seems that your issue is the carb. Please consider Busdaddy's advice, get a rebuilt German Solex from Volkzbitz, and, if you still have problems, they won't be carb connected.
Larry in OB
The Great Deal Maker cannot make a deal and he pays off porn stars. But you love him.
69 Westfalia and 2002 Eurovan Camper. Yes, the dark side. 67 Single Cab is off to Arizona.
khalimadeath
khalimadeath is offline
Well there are brand new jets in it, I dont know what jets were where. I suppose a jet could be clogged, it ran fine before I parked it 6 months ago to do the brakes and suspension. How would I go about cleaning it? I dont know much about carbs, my roommate is the one who took it apart.
And no I dont have any other distributers, this is the one it came with.
Also how would I check to see if the jet is spraying?
OB Bus
OB Bus is offline
PostPosted: Mon Nov 09, 2015 3:14 pm    Post subject: Reply with quote
My last post and your last post hit at the same time.
Your roommate rebuilt the carb? **sigh**
Stop the bleeding and the frustration. [email protected]
Larry in OB
khalimadeath
PostPosted: Mon Nov 09, 2015 3:21 pm    Post subject: Reply with quote
Yea im a fuel injected guy, this is my first carbureted vehicle. I prefer wires and multimeters. I have rebuilt my lawn mower so I get it.. I just dont want to deal with it. Nor do I want to spend hundreds of $$$ on a different distributor or another carb even though I know it would save me the headache.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Nov 09, 2015 5:08 pm    Post subject: Reply with quote
I'll just say that with some research on going thru that carb, you can get go thru it yourself, blow out the jets and passages and insure all the jets are in the right place and everything else is correctly set.
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
Here's over 200 threads on that carb w/different themes. If you read thru them, you'll learn how that carb works, what goes where and how to dial it in. The fact that you said the carb worked before says there's nothing wrong with it other than someone needs to go back thru it.
Yes, buying a Volksbiz carb is a quick solution, but.. what happens the next time you need to play with that carb? If you want to throw $200 at it for ease vs. learning to fix it, that's your choice. Very Happy
Bill
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
busdaddy
busdaddy is offline
PostPosted: Mon Nov 09, 2015 5:37 pm    Post subject: Reply with quote
wcfvw69 wrote:
Yes, buying a Volkzbitz carb is a quick solution, but.. what happens the next time you need to play with that carb? If you want to throw $200 at it for ease vs. learning to fix it, that's your choice. Very Happy
Agreed, so much better to understand what's going on in there in the event you have to fix it, but the OP was threatening to buy a "new" carb, that's just $200 down the toilet, at least you know Tim's carb will work properly.
VolkzBitz Premium Member
VolkzBitz is offline
PostPosted: Mon Nov 09, 2015 8:47 pm    Post subject: Reply with quote
If its not your daily driver, send the carb to me and Ill check it out for you without doing a full restore like I normally do. This carb shouldn't be causing so many problems for you, they are generally a good reliable carb, but if your friend took it apart and put something back wrong, then it could be a simple job. I can always test it on my Ghia to make sure its good.
http://volkzbitz.com
Quality VW Solex carburetor restoration
[email protected]
1969 1600cc Karmann Ghia
1969 1641cc Beetle
1965 restored to stock 65 Beetle (sold)
1957 Oval (sold)
1957 Lowlight Karmann Ghia (sold)
1966 restored stock 1966 Beetle (sold)
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Nov 09, 2015 9:40 pm    Post subject: Reply with quote
I totally agree with you Bus Daddy! I'd buy Tim's rebuilt carbs ANYDAY over the new carbs sold today.
OP, what a terrific offer from Tim to check that carb out for you! Take him up on it! I'm sure it's something silly wrong with it. With Tim's experience, he'll have it purring quickly.
Bill
1970 Westfalia Bus
1967 Standard Bug
khalimadeath
PostPosted: Tue Nov 10, 2015 9:52 pm    Post subject: Reply with quote
Its my long term project, ive only been able to drive it once in the 2 years i've owned it :/. So Ill take it off, clean it and check the jets. If I dont have any luck ill take you up on your offer. Thanks!!
khalimadeath
PostPosted: Tue Feb 16, 2016 7:04 pm    Post subject: Re: Trouble finding specifics on Carb..( I searched) Reply with quote
SO! I pulled the carb, cleaned it drained the 6 M/O gas and reassembled. Re static timed. I also found a port on the intake manifold that was open, I went ahead and plugged it. Checked all the plug wires for correctness and put in fresh gas. Ran like a champ. Drove it around the block no problems. Its one way to kick my ass in gear to get it ready for camping!
Page 3 of 3
