metropoj Samba Member
Posted: Fri Sep 05, 2014 6:43 am Post subject: Used Spare Fuel Pump Storage. |
I did some Preventative maintenance and installed a new Digifant pump. I was hoping to keep my old one around as a spare on the road but if I leave it as is dry I suspect it will quickly become useless.
Does anyone keep their old pumps as spares, buy a cheap new one, fill them with oil or ????
Looking for proven methods.
Cheers. |
insyncro Banned
Posted: Fri Sep 05, 2014 7:14 am Post subject: |
I definite run some lube through them if they are going to just sit. |
danfromsyr Samba Member
Posted: Fri Sep 05, 2014 7:23 am Post subject: |
when NEW pumps can be had for $40 why would I carry a used one?
carry a spare NEW one if you expect yours to fail
but really the odds are slim anyways.. and then you'd be carrying a gassy or oily pump in your 'kit' for years. _________________
Abscate wrote: |
insyncro Banned
Posted: Fri Sep 05, 2014 7:30 am Post subject: |
"New" pumps have lube in them...at least the ones I have here in stock, not the $40 ones. |
Posted: Fri Sep 05, 2014 7:38 am Post subject: |
I'm running a #P37 fuel pump from Rock auto, $30
http://www.rockauto.com/dbphp/x,catalog,166,partnum,P37,d,PERFORMANCE_ELECTRIC_P37.html
there is another part number I need to look up that has the larger intake port..
Ahh it's the P38 listing it's compatibility as VW Vanagon.. has the larger intake port for $45
http://www.rockauto.com/dbphp/x,catalog,166,partnum,P38,d,PERFORMANCE_ELECTRIC_P38.html
how about these?
insyncro wrote: |
I agree with Jon.
Great post.
Here is what I have to add:
This is a fuel pump from a Benz that I purchased NEW on eBay for $39 + shipping. Here is a link from the same company but this pump is direct fit for a few dollars more. Still under $50.
http://tinyurl.com/vanagon-fuel-pump
It had a fitting for a banjo which I removed.
3/8" FI hose fits right over the end.
You can reduce it down anywhere from the pump to the engine compartment. I use Goodyear FI hose with the blue Vitron inner sleeve, also available by the foot on eBay for around $4 a foot.
dylan |
Abscate wrote: |
Posted: Fri Sep 05, 2014 11:08 am Post subject: |
Yes they look fantastic as an option and I think that's the ticket going forward.
I just feel bad throwing one out that ended up being almost brand new
When I went through the bills from the PO and found that he did replace it about 5 years ago and has approx 3k miles on it tops ... |
Merian Samba Member
Posted: Fri Sep 05, 2014 11:41 am Post subject: |
fill a paint can with kerosene - drop it in and seal the lid |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Fri Sep 05, 2014 12:11 pm Post subject: pump |
We just take the old but good pump, put oil in it then take the caps off the new one put on old pump put all in a ziplock put in the new box and store in the back of the van. If you don't need it I'm sure someone with you will need it. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Fri Sep 05, 2014 5:41 pm Post subject: |
metropoj wrote: |
3k miles, sheeze! I'd spray it full of WD40, shake it around, drain it out, put the caps on the ports that came on your new one (or get some), put it in a ziplock bag and throw it in the van. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
Posted: Fri Sep 05, 2014 7:41 pm Post subject: |
I run ATF through them then cap them up.
I absolutely carry a known good OEM fuel pump and would do so over a new $30 one any day. The OEM one fits right in in a pinch, and I don't have to worry about cutting and crimping connections when I need a pump on the side of the road.
I have never used the spare pump I carry with me, but have given away 5-6 of them over the years to people who's pumps failed leaving them where they were, and I just happened to have that part with me! : )
I buy good used ones here, clean them up, lube and store them properly and they tend to come in handy as a common failure part.
Heck, I just lent one out last week!
I also PAINT them, because the reason the cases corrode through (Almost every one I've seen fail has been do to the case corroding through) is because of the galvanic contact with the steel holder and their constant exposure to road salt.
A coat of paint and they won't corrode, seemingly ever.
I also now line the fuel pump mounts with a layer of Ultra High Molecular Polyethylene tape just so there isn't that metal to metal contact. It certainly doesn't hurt! _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry." |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Sat Sep 06, 2014 4:01 pm Post subject: |
be aware there are 2 kind of connectors depending of the brand of the fuel pumps..
make sure that the spare has the same connectors as the one you use.. |
zeohsix Samba Member
Joined: August 31, 2012 Posts: 501 Location: United States
Posted: Sat Sep 06, 2014 6:44 pm Post subject: |
Marvell Mystery oil is what we used to use to store our USAC midget fuel injection pumps in the off season, its great stuff! _________________ I'm Cheap! I'll build that Syncro Westy myself and save money but, my labor is "FREE" especially if I ever go to sell it! One thing is I will know the quality of the parts and labor that went into the build and rest better when I'm actually driving said Westy down the road! |
