clutch adjustment concerns
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Sep 08, 2014 8:13 am    Post subject: clutch adjustment concerns Reply with quote
I am running a kep 1700 pound p/p and a copper head disk in my 70 bus. Also did a hd cross shaft with bronze bushings.
I fear something is going on. In order to even get any clutch action, I need to adjust the clutch so the cross shaft arm has about zero play. Its almost like I can't get enough throw on the cross shaft.
I am running a 71 bell, so it does have a guide sleeve.
I have it adjusted to work, but just barely. New cable (which will stretch). No ring on the p/p just like it should be.
Any thoughts? The pedal is right off the floor now, and will grind a tiny bit putting it in reverse. The pedal freeplay feels awful, but I don't want to over adjust it either...
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Scavenger
Scavenger is offline
PostPosted: Tue Sep 09, 2014 7:09 am    Post subject: Reply with quote
Just a thought but, it could be a problem with the pilot bearing in the glandnut. That would cause the input shaft to continue rotation.
W1K1
W1K1 is offline
PostPosted: Tue Sep 09, 2014 7:32 am    Post subject: Reply with quote
I had the same thing happen this spring with a 1 year old engine with all new clutch assembly, I pulled the engine thinking there was a leak and the clutch was slipping, chattering, or something was broke. Everything was normal looking. I chose to change the KEP P/P and it was back to normal.
I'm guessing there is problems with the KEP plates collapsing or not maintaining spring pressure again.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
mcmscott
mcmscott is offline
PostPosted: Tue Sep 09, 2014 8:14 am    Post subject: Reply with quote
The next time you have it open get that disk out of there, and put in a stock daiken disk. Your syncro rings will thank you if they already haven't been damaged yet
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Sep 09, 2014 8:29 am    Post subject: Reply with quote
Great....600 miles and this is the thanks I get? Awesome....
They were ez break in miles too.
So, what is a good setup for 200+ horse?
The clutch feels numb, like stepping on a water baloon. Was good for the first 3 400 miles, then I broke a (brand new) clutch cable.
Would a cable that was longer cause this? I had a replacement cable, but it was unmarked. The ends were a bit different. In desperation, I used it
Jake Raby wrote:
Brian wrote:
mcmscott
mcmscott is offline
PostPosted: Tue Sep 09, 2014 9:52 am    Post subject: Reply with quote
You don't have 200 hp, and a heavy (mass) disk will kill syncro rings. Also sounds like your diaphram on the pressure plate is hurt from over throwing it.
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Sep 09, 2014 10:06 am    Post subject: Reply with quote
mcmscott wrote:
You don't have 200 hp.....
Bored, stroked and re worked subaru 2.5.....sorry buddy, but I have well over 200 horse
Jake Raby wrote:
Brian wrote:
mcmscott
mcmscott is offline
PostPosted: Tue Sep 09, 2014 11:13 am    Post subject: Reply with quote
Forgive me, I thought you were refering to the 1904 that you question about. I use alot of subys in buggys. Show some pics of this conversion, I'd like to see it.
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Sep 09, 2014 12:09 pm    Post subject: Reply with quote
Fair enough, and good memory!
So show me some clutchs first!
So, what I am describing is a symptom of a failed p/p then? Just seems odd that it happened after the cable broke. I guess I will double check my cable length. As I said, it was an unmarked cable
Jake Raby wrote:
Brian wrote:
mcmscott
mcmscott is offline
PostPosted: Tue Sep 09, 2014 12:23 pm    Post subject: Reply with quote
With a 2.5 suby you need a 9" stage 3 and a 6 puck disk and to convert to hydraulic slave cylinder. The stock lever on the bottom of the pedal will break with this heavy of a clutch
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
mcmscott
mcmscott is offline
PostPosted: Tue Sep 09, 2014 10:22 pm    Post subject: Reply with quote
So where are the pics? I did a suby in a 914 not long ago with CB's ecu. Would like to see some pics of an early bay with a radiator in it and what not
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Sep 10, 2014 12:00 pm    Post subject: Reply with quote
Here is the build
http://www.thesamba.com/vw/forum/viewtopic.php?t=561788
The radiator(s) is now under the bus. Couldn't keep cool at 50 or above due to airflow. And nothing for nothing, I call bullshit on bus in bay rads. They work...if you don't go past 50, or enjoy running at the brink of meltdown
Jake Raby wrote:
Brian wrote:
mcmscott
mcmscott is offline
PostPosted: Wed Sep 10, 2014 12:39 pm    Post subject: Reply with quote
Didn't get a chance to read all of it, and I am not a bay window person, but sweet!
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Sep 10, 2014 5:22 pm    Post subject: Reply with quote
thanks!
so today, I got another clutch cable. it was about the length of the one that broke.
the one I put in was about 1/4 of an inch longer. I don't understand why being longer would have made the clutch feel like crap, but it did
put in the correct cable, and all is well. very odd, as you would figure the additional length should have been taken up by the wingnut.
now you guys have me concerned about the kennedy p/p. should I look into another alternative? or was there a rash of bad ones some time back?
Jake Raby wrote:
Brian wrote:
modok
modok is offline
PostPosted: Wed Sep 10, 2014 5:27 pm    Post subject: Reply with quote
There isn't much choice besides kennedy today. Just have to hope you got a good one, and make sure not to have it adjusted tighter than needed (sposedly over-traveling it can warp the spring)
You might have had a stretchy cable. some of this stuff is just poor quality Shocked
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Sep 10, 2014 6:27 pm    Post subject: Reply with quote
*sigh*
I have had more issues with the vw components than the Subaru swap as a whole. now think about that for a minute.
and, this is the first vw I have built that has not leaked 1 drip of oil. sad, sad, sad.....
the clutch seems to be adjusted ok. I have no idea why it would/could over extend the t/o bearing. no longer arms etc were used. I have about 1/8-3/16 of play at the arm now. clutch feels good and grabs mid to 3/4 of the way up, not just off the floor like it was
Jake Raby wrote:
Brian wrote:
