iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Jun 18, 2017 8:04 am Post subject: Re: '59 Karmann Ghia 'Low Nose' topic |
Be aware that there are two different size scripts-------it got smaller in the early 60's.
pbaptist wrote: |
Size difference between early and late script.
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Quintus Samba Member
Joined: December 07, 2010 Posts: 173 Location: the Netherlands
Posted: Mon Jun 19, 2017 12:12 pm Post subject: Re: '59 Karmann Ghia 'Low Nose' topic |
Thanks, that helps!
I do have the larger script, so that should fit perfect.
Anyone ideas for my other questions?
Quintus wrote: |
- Also I purchased an original sidevieuw mirror, but the glass was trashed. Where can I get a new one? Or do I have to let one custom made?
- Another problem I have is with the doorlocks. These were also completely broken and were not safeble. Are those easy to get? Or are there other options to fill the hole without locks? |
Thanks _________________ 2005 VW Lupo
1970 Pontiac GTO
2008 VW Golf R32
1959 Karmann Ghia 'Low Nose' |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Mon Jun 19, 2017 7:05 pm Post subject: Re: '59 Karmann Ghia 'Low Nose' topic |
A local glass shop should be able to cut some 1/8" mirror to match the piece you have, try to get some tinted mirror is grey, clear mirror will be too bright. _________________ It's not about the window, it's about the people.
German Folks |
VeloMikey Samba Member
Posted: Tue Jun 20, 2017 6:59 am Post subject: Re: '59 Karmann Ghia 'Low Nose' topic |
Is the glass still in one piece? You can have it re-silvered. I had my rear view mirror done. Turned out perfect. Call Jan at A Moment In Time (620)399-8765 _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Posted: Sun Jun 25, 2017 4:47 am Post subject: Re: '59 Karmann Ghia 'Low Nose' topic |
Alright, thanks I will try a glass shop.
Unfortunately the glass is broken, so fixing is wouldn't be a option. _________________ 2005 VW Lupo
1970 Pontiac GTO
2008 VW Golf R32
