rich caramadre Samba Member
Joined: August 22, 2014 Posts: 145 Location: United States
Posted: Tue Sep 09, 2014 6:31 pm Post subject: Car reassembly |
I have my car completely disassembled to go to paint. Everything is out. just the shell bolted onto the pan. Including wiring and steering column. My question is when it comes time to reassemble the car is there a perfered order? Example: do not install windows before headliner. That's a given. But are there other similar situations I may come across?
Any experienced advise welcome. Thanks, Rich |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Tue Sep 09, 2014 10:43 pm Post subject: |
Wiper motor before anything else behind the dash.
Fenders, running boards, fender bead, all installed loose, then final tighten.
Bumpers, same deal, and don't scratch!
Carpet and upholstery goes in after headliner.
Have fun- this IS the fun part!
_________________ Plate of shrimp |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Wed Sep 10, 2014 4:13 am Post subject: |
A real good idea is to invest in a roll or 2 of blue masking tape. I use it to protect painetd surfaces when installing things that can scratch - like window scrapers, inner door panels, etc.
Strong suggestion is to run a few extra wires from the front trunk to at least under the rear seat - a couple back to the engine is even better - use unique colors and just ties them off at each end. Makes adding gauges and such so much easier. Can be run down the passenger side if you want. _________________ D-Dubya Manx clone - 63 Short pan,1914.
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Wed Sep 10, 2014 5:55 am Post subject: |
The previous suggestions are spot on. I would add, some foam packing material to wrap around bumper ends, a big work bench/ table to lay out your parts. Anti seize or lube for all the fasteners as you assemble. Get a piece of paper for making a list to check off as you go. Keep the pictures coming & have fun. _________________ I think he meant "rare", as in "not well-done" |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Wed Sep 10, 2014 9:31 am Post subject: |
eyetzr wrote: |
a big work bench/ table to lay out your parts. |
AMEN! _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
GB2S Samba Member
Posted: Sat Sep 13, 2014 6:48 pm Post subject: |
What color is that car?
Thanks, Geoff _________________ 1963 Ragtop |
joemo5 Samba Member
Joined: August 13, 2009 Posts: 78 Location: Atoka, TN
Posted: Tue Dec 02, 2014 11:11 am Post subject: |
What a great thread....I CAN'T WAIT to get mine to that point! |
Posted: Wed Dec 03, 2014 12:00 am Post subject: |
GB2S wrote: |
Thanks, Geoff |
L469 Anthracite _________________ Plate of shrimp |
Der Speed Shack Samba Member
Joined: April 10, 2010 Posts: 164 Location: Fullerton, Ca 92832
Posted: Thu Dec 18, 2014 9:32 pm Post subject: |
And if you didn't do it before you painted it, tap/chase all your threads before reassembly so you don't snap the head off a bolt. Nothing will tighten your pucker string like drilling out a broken bolt on a freshly painted car |
