vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Thu Sep 11, 2014 6:07 am Post subject: Radiator baffle DIY – what is latest material and template? |
Got the radiator out and wondering what to use to replace my deteriorated radiator baffles.
Would prefer to make my own rather than wait for shipping. I've seen some topics on this periodically but no luck in the search.
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Syncro Jael Samba Member
Posted: Thu Sep 11, 2014 6:18 am Post subject: |
I purchased these recently, from GoWesty, getting ready to install new radiator, fan, hoses. These are very well manufactured and should last as long as I am needing them. The material used is much better than stock. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Sep 11, 2014 6:28 am Post subject: |
This is the time of year for my favorite material -- election signs from losing candidates.
The signs I use are made of a plastic material that is formed like corrugated cardboard -- very easy to work with yet quite durable even in the wet.
I may still have some patterns that you can print on your printer and tape together - PM me if you want a copy. |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Fri Sep 12, 2014 7:36 am Post subject: |
I used FRP (fiberglass reinforced panels). They are normally used to cover the walls of commercial kitchens, bathrooms, showers, etc. Pretty durable and easy to work with. You don't need much, but Home Depot / Lowe's sells 4X8 sheets. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
LandSailor Samba Member
Joined: October 30, 2009 Posts: 315 Location: Las Vegas, NV
Posted: Fri Sep 12, 2014 10:58 am Post subject: |
Coroplast is the name of the sign material. It will last for years and handles water superbly. (I have a piece of it as a temporary wall in our shower to test the custom shower setup I installed.) The melting point is 324°F/162°C and the performance range is -17°F to 160°F.
However, I have the GoWesty setup and aside from the fact that they don't include (nor sell) the screws and connectors, it's excellent. The only downside to the Coroplast (and this is just a WAG) is that it's not as "sturdy" as the TPE in the GoWesty set. |
Merian Samba Member
Posted: Fri Sep 12, 2014 11:47 am Post subject: |
do I need to find a black sign or will the white show thru the grill? |
?Waldo? Samba Member
Posted: Fri Sep 12, 2014 12:28 pm Post subject: |
The color will show through the grill some if viewed from the correct angle but it is not particularly noticeable. I made some out of yellow/black election signs some 6 or 8 years ago. Very easy and still look perfect today. If I have them off again some day I may spray them with some black paint made for adhering to plastic. |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Fri Sep 12, 2014 5:58 pm Post subject: |
Are your originals still there, just in bad shape?
I made a set of replacements using fiberglass mat, but instead of resin I used black POR-15, using the remnants of my originals for molds.
Put down a layer of Saran wrap to separate the mold, then laid up 2 layers of thin mat.
The POR-15 remains flexible, as opposed to resin, and is super-easy to work with. Been running these for about 10 years now, no issues.
As a bonus, the finished product looks kind of like carbon-fiber. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Fri Sep 12, 2014 6:03 pm Post subject: |
By the time you "wait for shipping" and the amount of time it takes to do it right... you could be done with the new GW baffles for $39.95. What is your time worth and why reinvent the wheel?
http://www.gowesty.com/ec_search_results.php?search_phrase=Baffles
No affiliation... just a very satisfied GW Baffel customer _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Fri Sep 12, 2014 6:12 pm Post subject: |
Some folks enjoy the thrill of the chase, and will want to make these up from a recycled product. Good for you.
I went with the pre made Go Westy ones, and then spent the time trying to recreate and replace the panels that were once affixed to the rear of my grill.
The Go Westy ones are spot on, and seem to be made from a recycled rubberized compound that installs quickly.nice product. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Posted: Fri Sep 12, 2014 6:50 pm Post subject: |
Yeah, the GW ones look good.
1) Want to get the radiator in this w/e and 2) for me there is a high level of satisfaction on a DIY project using things I already have.
Optimist view - Think of all the greenhouse gasses I am saving not shipping and not throwing out the coroplast I already have. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Gregicon Samba Member
Joined: June 16, 2014 Posts: 11 Location: Seacoast NH
Posted: Fri Sep 12, 2014 7:15 pm Post subject: |
ThankYouJerry wrote: |
No affiliation... just a very satisfied GW Baffel customer |
X2 - installed my GW baffles today! Easy, permanent, removable if needed...def worth the $40 |
Posted: Fri Sep 12, 2014 7:40 pm Post subject: |
vanis13 wrote: |
Optimist view - Think of all the greenhouse gasses I am saving not shipping and not throwing out the coroplast I already have. |
The GW baffles are made from recycled materials and if you want to save greenhouse gasses you wouldn't be driving a (fossil fuel powered) Vanagon
All in good fun. Do as you will. _________________ 1990 Multivan - "Ohana"
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Sat Sep 13, 2014 4:23 am Post subject: |
Are the baffles even needed? |
Posted: Sat Sep 13, 2014 5:17 am Post subject: |
unibagel wrote: |
'Need' is subjective. I ran for three years without them without an issue; with a WBX and then with a Zetec.
My desire to add them was based in some sound reduction activities I was partaking. For $30 it was a no brainer for me.
I wanted to channel air where it should go, and eliminate it from where it was not needed, hence possibly reduce the sound from air passing over the front of our bricks.
Have no scientific evidence of the reduction - I did not run the decibel meter prior to installation. But after a few hundred miles I do believe that the installation of these, plus the re-creation of the pieces that once affixed to the back of the early style grill has made an effect on the front end noise from airflow.
I will someday pull them off and compare decibel levels, but not today - going camping. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Posted: Sat Sep 13, 2014 6:53 am Post subject: |
They will make a significant difference in the amount of air that goes through the radiator and consequently how well the radiator can cool. They aren't needed until they are. That one time when you overheat while climbing a 7% freeway grade in 115 degree ambient temps might make the deflectors seem really worthwhile. |
madspaniard Samba Member
Posted: Sat Sep 13, 2014 9:33 am Post subject: |
I have the GoWesty kit sitting in my garage for over a year waiting for me to pull the grilles. Does anybody have recommendations or a parts list that includes all the hardware needed? I'm still trying to figure out why hardware is not included in this kit. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Sat Sep 13, 2014 10:34 am Post subject: |
Andrew A. Libby wrote: |
...That one time when you overheat while climbing a 7% freeway grade in 115 degree ambient temps might make the deflectors seem really worthwhile. |
I-17
Yeah, I figure some German engineer (who knew a lot more about it than me or anyone here) thought they were necessary. |
greggearhead Samba Member
Joined: June 20, 2004 Posts: 563 Location: Colorado Springs, CO
Posted: Sat Sep 13, 2014 10:55 am Post subject: |
It's not exactly the same thing, but older B-chassis VW & Audi models have cardboard type material that always degrades and goes away.
On my Fox Wagon, I built some new ones from Masonite because I had a free chunk of time, some masonite, and Foxes are known for being marginally cooled when you start pushing them.
I made sure to spray paint both sides for better water resistance. Should last several years or more.
_________________ 1972 Porsche 911E
1973 VW 412
1984 VW Doka
1991 Vanagon Syncro Westy
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html |
Altoona Samba Member
Posted: Sat Sep 13, 2014 1:29 pm Post subject: |
madspaniard wrote: |
I have the GoWesty kit sitting in my garage for over a year waiting for me to pull the grilles. Does anybody have recommendations or a parts list that includes all the hardware needed? I'm still trying to figure out why hardware is not included in this kit. |
I just reused the original stuff, worked well for me. Those plastic plug things that fasten the upper tabs are pretty specialized looking, I wonder if they are available or what could be used as a replacement if yours are missing? |
