vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Sat Sep 27, 2014 6:57 am Post subject: |
another user had photos w/tape measure sizing that he sent me. I had a friend generate PDF's that should be (almost - see note below) size appropriate with cut overlap marks
I have not created them yet but will report when I do. The PDFs seem to print out to scale. Keep in mind that these are tracings so you want to cut inside the lines.
The PDF's can't be loaded up here so you can find them here - http://www.andrewvanis.com/Vanagon/radiator_baffles/
note -
Andrew,
Please find attached six PDF files.
1, 2 and 4, 5 were created as full bleed 8.5x11 sheets. Just print these out of Acrobat with no scaling or fit to page and match up the cut lines you will see around the mid point of the baffle.
3 and 6 were created for poster print if you choose to take that route.
Now, be aware that these are photos of someones sketches. A camera lens will add some distortion to the image. It would have been better if they were scans, but it is what it is. I think it should get you close enough and then you can just do some test fits and fine tune from there. Perhaps even make your first run out of cardboard and then trace the final fit cardboard on to the actual material.
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
insyncro Banned
Posted: Sat Sep 27, 2014 7:06 am Post subject: |
Yes they are needed, especially if you have working AC. |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Mon Apr 06, 2015 8:50 am Post subject: |
Any advice on the hardware used to install the baffles? My originals are non existent, and I am changing the radiator this week and plan on adding the baffles I purchased from GW some time ago. Are they installed before mounting the rad or after? |
insyncro Banned
Posted: Mon Apr 06, 2015 9:02 am Post subject: |
unibagel wrote: |
Are the baffles even needed? |
Yes, and if you have AC, these help a lot. |
artacoma Samba Member
Joined: January 11, 2014 Posts: 121 Location: Victoria BC Canada
Posted: Mon Apr 06, 2015 10:56 am Post subject: |
I just installed mine after the rad was in and it went fine , I had to use the pics in the bentley to orient them right , my existing fasteners were still hanging on the van but the baffles were long gone. |
Posted: Mon Apr 06, 2015 11:03 am Post subject: |
IIRC correctly, the fasteners are a mix of screws and plastic push-pins. can anyone confirm/clarify? (and possibly provide pictures?) _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Merian Samba Member
Posted: Mon Apr 06, 2015 11:12 am Post subject: |
what does the online parts diagram site show? |
Posted: Mon Apr 06, 2015 11:15 am Post subject: |
Thanks for replying Artacoma. I will check and see itf they are still on there. |
Posted: Mon Apr 06, 2015 11:16 am Post subject: |
Merian wrote: |
What's a good link for a good online parts diagram site?, thx _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Mon Apr 06, 2015 11:57 am Post subject: |
The bottom screws into a couple of stand offs on the bottom of the rad , the sides screw thru the front facsia with speed nut type thingys |
Merian Samba Member
Posted: Mon Apr 06, 2015 12:35 pm Post subject: |
vanis13 wrote: |
Merian wrote: |
What's a good link for a good online parts diagram site?, thx |
I think I'm too old to remember - might be called vagacat or something
why VW Classic doesn't put a parts diagram set online I dunno |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Mon Apr 06, 2015 9:35 pm Post subject: |
I've got a set of gw baffles. Seem like low cost and high quality. I've chosen to purchase because other items are a better investment of my time to fab than these. Unfortunately I'm too dense to figure out how to install the side pieces with my new rad and oversized condenser.
Please post pictures of the side pieces installed and fastening points. I'm baffled. Oh my. I swear that wasn't planned. I really am baffled. Shit. I can't stop. Slap me. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Sat Apr 11, 2015 12:25 pm Post subject: |
Got a new version of the templates. These were scanned so no photo lens issues like in post above.
Full size PDF are at http://www.andrewvanis.com/Vanagon/radiator_baffles/
** The passenger side is the same but a mirror of these Side images but doesn’t have the hole
These are in 1/8 inch scale. Each dark line is 1 inch
PDFs are at - http://www.andrewvanis.com/Vanagon/radiator_baffles/
Print them with “scaling = none” in the printer dialogue box. They should print in actual scale. (put a ruler to it to confirm)
Cut a bit of the paper where they overlap, line up/overlap, and cut out.
Full size PDF are at http://www.andrewvanis.com/Vanagon/radiator_baffles/[/b] _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat Jun 06, 2015 9:47 pm Post subject: |
cut mine on a laser cutter from the templates above. install was easy peasy. since I have a aftermarket condenser I'd leave off the front cutouts for next time.
?Waldo? Samba Member
Posted: Sun Jun 07, 2015 6:08 am Post subject: |
Thank you so much. Very useful. Especially the DWGs.
I few years back I made a set by tracing onto an election sign (after the election).
During a recent election there was a local proposition whose signs were largely black. I grabbed one of those for my next set. |
spiros Samba Member
Posted: Sat Jul 20, 2019 10:42 am Post subject: Re: Radiator baffle DIY – what is latest material and template? |
It's an old post, but maybe someone would know about it. Being on my way to print these templates and also looking around, i see in websites that sell some kind of T3 radiator baffles , that they specify that the ones they sell will not fit on diesel models. So having a diesel model myself, i wonder what is the case with the templates. Do they fit only petrol, or will they fit diesel cars too? |
spiros Samba Member
Posted: Mon Jul 22, 2019 10:32 am Post subject: Re: Radiator baffle DIY – what is latest material and template? |
Ok, just to report,
I cut the baffles from these templates and they fit my T3, which has a body from a petrol model. I made a couple of twists, but in general these templates where quite helpful. thanks vanis13 |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
