spiros Samba Member
Posted: Mon Jul 22, 2019 12:36 pm Post subject: Re: Radiator baffle DIY – what is latest material and template? |
Mm, these are different type of baffles. They do make sense though. Maybe i ll add these as well. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Jul 22, 2019 1:26 pm Post subject: Re: Radiator baffle DIY – what is latest material and template? |
Purpose of the grille baffles is less clear - may reduce some wind noise. |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Tue Feb 23, 2021 9:25 am Post subject: Re: Radiator baffle DIY – what is latest material and template? |
the link that Vanis13 shared is not working, I have previously copied his files so here is my dropbox:
https://www.dropbox.com/sh/jverdl3rbitnzuj/AAAizIU2DUijFPBIINtWf7mHa?dl=0 _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Prairie Maus Samba Member
Joined: September 26, 2020 Posts: 11 Location: Canada
Posted: Sat Jul 31, 2021 12:01 pm Post subject: Parts for rad baffle install |
madspaniard wrote: |
I have the GoWesty kit sitting in my garage for over a year waiting for me to pull the grilles. Does anybody have recommendations or a parts list that includes all the hardware needed? I'm still trying to figure out why hardware is not included in this kit. |
All you need is two plastic panel clips - Single head.
something like this
https://www.canadiantire.ca/en/pdp/dorman-help-int...#store=248
a couple screws and washers with the flat 'screw retainers' ?
these.. but metric version, unless you match SAE screws to the SAE clips..
https://www.lowes.ca/product/spring-nuts/hillman-1...lsrc=aw.ds
Mike and Maus |
AllRad Samba Member
Joined: December 04, 2016 Posts: 64 Location: Pacific Northwest
Posted: Mon Aug 02, 2021 10:09 am Post subject: Re: Radiator baffle DIY – what is latest material and template? |
Hello,
I have installed the GoWesty baffles. There are two side panels and a bottom one. They close off airflow all around the radiator. At the time, this seemed a little odd, because I figured the radiator heated air needs some egress. Otherwise the hot air can only mix turbulently with incoming fresh air. Anyways, I followed the instructions. I noticed no change to my temp gauge readings.
I decided to remove the bottom baffle to see what would happen. Again, no change.
Recently, I temporarily removed the spare tire and clamshell to see if the giant opening under the vehicle would help the heated air exit the system. But again, I see no change to my temp gauge readings.
I guess I'm just confused, what should happen with the addition of these baffles? My Vanagon came with no baffles, because the prior owner removed them. I'm not sure if the sock arrangement even has a bottom baffle...
Other baffling thoughts? |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Mon Aug 02, 2021 12:18 pm Post subject: Re: Radiator baffle DIY – what is latest material and template? |
Your temp gauge is in your engine compartment. It has to do with the circulation of coolant and temps in that area. It is funny how something as simple as a thermostat can fool you.. It works to even out the temp, sending coolant to the Rad when it needs to cool some. Hence, unless your engine gets quite warm, and sends all coolant (well, since plumbing doesn't actually work that way it never can send ALL) to the Rad, you may see little difference in the needle. Even so, with full flow of coolant to the Rad, you may still not notice a difference... Until the last moment before it is overwhelmed, and you overheat.
Don't play that game. Your odds are poor.
Baffles are there for the last little bit of saving grace. Keep them all in place if possible. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Aug 02, 2021 5:54 pm Post subject: Re: Radiator baffle DIY – what is latest material and template? |
This past year I had the opportunity to purchase some new baffles made from stainless steel. They are nifty and will give a future owner many many years of reliable service. _________________ Schau in das Buch |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
sanchius Samba Member
?Waldo? Samba Member
Posted: Fri Jul 01, 2022 9:17 am Post subject: Re: Radiator baffle DIY – what is latest material and template? |
The baffles around the radiator make a significant difference in the ability of the radiator to shed heat. A LOT of airflow will bypass the radiator if they are not in place. That's just another one of those things that doesn't matter until it does, and then you are dealing with a disaster. |
