SL12572 Samba Member
Joined: April 13, 2011 Posts: 270 Location: Washington
Posted: Sun Sep 14, 2014 1:13 pm Post subject: Wiring harness access with Syncro fuel tank installed? |
Question for the Syncro gurus
I'm curious if the wiring for the ECU that runs from the inside of the van and along the lower frame rail to the engine compartment can be fully accessed with the fuel tank installed.
I'm doing some custom wiring for my Megasquirt ECU, but would like to install my fuel tank.
Thanks!
Scott |
Type17 Samba Member
Joined: April 24, 2012 Posts: 300 Location: Chicagoland
Posted: Sun Sep 14, 2014 1:38 pm Post subject: |
yep, you can remove and install the harness without removing the fuel tank. there's a good bit of access behind the drivers rear wheel if you move the charcoal canister and ac drier (if you have ac) out of the way. |
Posted: Sun Sep 14, 2014 5:52 pm Post subject: |
Great! Thank You! |
DAV!D Samba Member
Joined: September 10, 2013 Posts: 979 Location: EL CAMINO
Posted: Sun Sep 14, 2014 7:58 pm Post subject: |
You can remove it, but you will likely have to loosen the vacuum canister so it can be moved around when you try to get the ECU boot through that spot.
It's kind of a pita. _________________ 86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Fri Jun 12, 2020 3:37 am Post subject: Re: Wiring harness access with Syncro fuel tank installed? |
Thread resurrection!
I can't post a picture at the moment, but maybe I can describe it well enough to help.
90 Diesel Syncro, I've pulled and replaced the tank. The fuel sender is plugged in, but I have an extra cable with no home. It's a two-wire cable, tan / brown with black stripe. The fuel sender is tan / purple with black stripe.
Does this stand out to anyone? Any ideas? I will be able to post a pic in 8 hours.
Thanks! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Fri Jun 12, 2020 4:12 am Post subject: Re: Wiring harness access with Syncro fuel tank installed? |
That sounds like it is for the decoupler switch, not used on most Syncros.
The wiring for 3 locker switches is there whether the Syncro came with any lockers or not.
The Syncro fuel tank sender wiring and connector is part of the separate locker harness, with 3 of those two pin connector for the 3 possible locker switches and the fourth one for the fuel tank, purple wire.
Mark
Team WorldTour wrote: |
Thanks! |
Posted: Fri Jun 12, 2020 5:35 am Post subject: Re: Wiring harness access with Syncro fuel tank installed? |
Cool Mark, thanks for the quick response.
Mine is a two-knobber, and the closest I could figure was it was intended for the gasser's fuel pump.
As promised, here is a photo:
Click to view image
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Fri Jun 12, 2020 2:44 pm Post subject: Re: Wiring harness access with Syncro fuel tank installed? |
When I put the battery back in, I'll be sure to test that! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Fri Jun 12, 2020 4:04 pm Post subject: Re: Wiring harness access with Syncro fuel tank installed? |
You might need to install a bulb for the decoupler position if you want that to light up.
I think it is the missing bulb in this photo, controlled by the brown/black wire from the decoupler switch connector.
Mark |
Posted: Sat Jun 13, 2020 10:38 am Post subject: Re: Wiring harness access with Syncro fuel tank installed? |
Sweet, thanks for the tip. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
