metropoj Samba Member
Posted: Wed Sep 17, 2014 5:43 am Post subject: Need some help: Alt and Tranny Ground Wire Lengths. |
My buddy lent me his stash of 4GA wire and connectors / crimping tool for the day.
I won't be able to climb under the van to measure / install any connections so I'm hoping someone can tell me what lengths are needed for the following 2 connections:
1. Alternator to Starter lug.
2. Transmission to Ground.
Any others I should be concerned with ? I just replaced my battery to starter cable.
I haven't had a chance to peek around much under there but I thought i should take advantage of the wire offer while I can.
Thanks in advance. |
Terry Kay Banned
Posted: Wed Sep 17, 2014 7:36 am Post subject: |
Do some crawling to determine how much wire you'll need.
It isn't a big deal--take a tape down under with you and see what you can see.
The alternator wire is up top--no crawling required. _________________ T.K. |
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Wed Sep 17, 2014 11:27 am Post subject: Re: Need some help: Alt and Tranny Ground Wire Lengths. |
metropoj wrote: |
2. Transmission to Ground. |
1. I would suggest this to fix up all the associated alternator wiring: http://www.thesamba.com/vw/classifieds/detail.php?id=1648432 but the Alt-to-starter portion for my '85 4 speed measures 29.5" from eyelet tip to tip.
2. Couldn't get under to measure but looking at it is around 8". 10" would be lots. Again, on '85 4 speed.
Auto looks to be about the same size:
http://www.thesamba.com/vw/forum/viewtopic.php?t=548492
One thing some do is run a ground from a starter mound bolt to the chassis to get a direct ground on the starter, rather than through the transmission. I can't comment but for some samba gurus this is regular practice with a new van and eliminates bad grounds as a source for slow starting. _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
Posted: Wed Sep 17, 2014 1:00 pm Post subject: |
Thanks for sharing. I was just not in a position to climb under the van before I have to return the wiring. Cheers ! |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9800 Location: Mt Lemmon, AZ
Posted: Wed Sep 17, 2014 1:15 pm Post subject: Re: Need some help: Alt and Tranny Ground Wire Lengths. |
geo_tonz wrote: |
...One thing some do is run a ground from a starter mound bolt to the chassis to get a direct ground on the starter... |
Here's where I put that one (that's the right front corner of the engine bay):
Good time to check the ground from the engine to just under the coil. Mine was a braided cable that had turned green & powdery with age, replaced with a ready-made ground cable from the FLAPS.
Sorry, no idea on the lengths at this point in time. |
Posted: Thu Sep 18, 2014 7:14 am Post subject: |
Great, thanks. The PO had also done a similar cable there. |
