jslew Samba Member
Joined: March 03, 2008 Posts: 55 Location: Trinidad, CO
Posted: Sat Sep 20, 2014 10:43 am Post subject: Oil Pressure Light after .3 switch wire touches exhaust |
I have an oil pressure gauge in my vanagon w sending unit & switch mounted to tin under push rods.
Was changing coolant, so pulled tin & left sender hanging. After draining coolant, disconnected .3 switch wire (to gauge cluster) to wipe coolant off and forgot to plug it back in.
Went driving & oil pressure light starts flickering - go home & find dangling .3 wire with just the connector resting on exhaust - plastic guard around connector had melted - no breaks in wire... no exposed wire. Plugged it back in. Went driving - oil pressure light still blinks.
I know i have good oil pressure, as my gauge still functions correctly (50psi above 3000rpm, 18psi at idle).
Changed out .3 wire all the way to connector in engine bay & went driving... still blinks.
Tested dynamic oil pressure system per bentley:
engine not running/ignition on - LED flashes - Yes.
engine <2000rpm/.3 wire grounded - LED flashes - Yes.
engine >2000rpm/.9 wire unhooked - LED flashes + buzzer - Yes.
Everything checks out.
Did .3 switch go bad? Can driving w/o .3 switch wire plugged in mess up the switch? _________________ Current Garage:
'67 Cal Look Bug
'70 Westy
'73 Baja
'74 Spec Ed Love Bug - my first car bought in '86!
'89 Vanagon GL
'92 Corrado SLC |
jslew Samba Member
Posted: Sat Sep 20, 2014 11:26 am Post subject: |
Nevermind... i pulled a .3 switch from a spare engine and that did the trick.
I mean seriously... i drove the van for 5 mins without the wire plugged in and it fails??? WTF!
So don't look at your oil switches funny or they'll fail! _________________ Current Garage:
'67 Cal Look Bug
'70 Westy
'73 Baja
'89 Vanagon GL
'92 Corrado SLC |
?Waldo? Samba Member
Posted: Sat Sep 20, 2014 11:31 am Post subject: |
Actually the oil pressure switches are typically robust and running with the wire disconnected should not affect them. I think you just ran into an astronomically improbably coincidence. |
jslew Samba Member
Posted: Sat Sep 20, 2014 11:38 am Post subject: |
Andrew A. Libby wrote: |
That would pretty much sum up my luck! Murphy & me are very tight! _________________ Current Garage:
'67 Cal Look Bug
'70 Westy
'73 Baja
'89 Vanagon GL
'92 Corrado SLC |
