orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Sun Sep 21, 2014 7:49 am Post subject: VW symbol CADD drawings |
I took a few minutes this morning to draw the vw symbol in CADD. IF any of you guys are makers and have a 3D printer I can send you the STL file for you to print one. I tried to get as close to specs as possible.
mjenner Samba Member
Joined: November 29, 2008 Posts: 268 Location: essex,on,canada
Posted: Sun Sep 21, 2014 4:16 pm Post subject: |
better check your dimensions |
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Sun Sep 21, 2014 4:49 pm Post subject: |
x2 |
Posted: Sun Sep 21, 2014 5:00 pm Post subject: |
note that some dimensions are not on center lines as indicated by the OG drawing. Do you know how you know how to use CADD? DO you have a 3-D printer to print your own cool vw symbol. Return with real criticism when you have some prior knowledge. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Sep 21, 2014 6:03 pm Post subject: |
Left side of the "V" looks too thick.
But keep it up... having a model makes it possible to 3-D print stuff using it. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Mon Sep 22, 2014 10:31 am Post subject: |
KTPhil wrote: |
A 3D printer would actually be the slowest, most expensive and least desirable method of popping a few of these out.
Take it to any of several thousand graphic display houses around the US that have one of these or one of several other brands and they can do it from aluminum or plastic for cheap from CAD.
60,000 rpm aircooled router attachment with fiber optic vision system, pulls 2-g's on corner turns and can hold .0004" tolerance. Hundreds of cutter tools including a fiber optic Co2 laser.
http://www.youtube.com/watch?v=KC0tvvsib_Q
http://www.youtube.com/watch?v=zC9hGDswvJ4 Most of this is just simple cutting being demo'd but these can cut exquisite detail.
By the way...DiBond is a sandwich of aluminum and UHMW polyethylene in the center. Tough as nails. This can rout it like butter.
Ray |
sb001 Samba Member
Posted: Mon Sep 22, 2014 8:05 pm Post subject: |
I applaud the effort-
but yeah, it looks a bit "off." I agree the left stem of the V is too wide, also there should be no difference in angle between the V stems and the W stems- they are parallel. 54° vs 48° is not correct.
Just a bit of tweaking it should be fine. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
