ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Thu Mar 10, 2016 3:26 am Post subject: Re: The great insulation/ sound deadening thread... |
khalimadeath wrote: |
Ordered some reckhorn and will be installing soon, I am still trying to decide what to install on the celling and side walls. I am leaning towards ezcool. |
Where did you order from? And please let us know what your experience is in terms of sound deadenin.
Has anyone thought or tried using thinner foam and a layer of jute for the bottom bed and bench seat in a westy? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Thu Mar 10, 2016 8:06 am Post subject: Re: The great insulation/ sound deadening thread... |
I can highly recommend BXTII by RAAMaudio. I am not affiliated with them in any way. Their products are top notch.
My experience with their products can be found here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=373683&highlight=insulation
The product link is here:
http://www.raamaudio.com/ _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
khalimadeath Samba Member
Posted: Thu Mar 10, 2016 10:06 am Post subject: Re: The great insulation/ sound deadening thread... |
ivwshane wrote: |
Has anyone thought or tried using thinner foam and a layer of jute for the bottom bed and bench seat in a westy? |
I ordered through amazon. I also ended up going with reflectex for the walls and ceiling for insulation. I am taking photos and will report back once all my interior is reinstalled. |
Posted: Tue Mar 15, 2016 8:42 pm Post subject: Re: Insulation / sound deadening thread... |
Is there any consensus about the best strategic places to get the most bang for the buck in terms of getting a quieter interior without covering every square inch of a particular area? To me it would seem that the best places to put small strips of sound deadening material would be the engine hatch, underneath the bench, front and rear wheel wells, doors, and the nose.
Does anyone have any input? I'd like to improve my ride but I don't want to have to remove the full westy interior. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Tue Mar 15, 2016 9:01 pm Post subject: Re: Insulation / sound deadening thread... |
Doors and above engine would be good places to start, its never bad to take the interior out, you can get some deep cleaning done and then insulate and deaden everything while you are in there. Its not to difficult.
Someone didnt like my original threat tittle Give me some sticky love if your gonna change the name.
Also I installed reflectix and reckhorn in my bus today, the 21' roll from reckhorn was not enough. Get 2 if your doing the main floor and front. Ill post pics when I am all done, im taking progress pics. The 16'x25' reflectix was enough to cover above the driver under the headliner, walls above the rear wheel wells and the slider and opposing wall. |
Posted: Sat Mar 19, 2016 2:04 am Post subject: Re: Insulation / sound deadening thread... |
Are you doing a full coverage install or just patches? I'm looking at the rekhorn stuff as well, did you go with the 80mil or the 100mil roll? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Tue Mar 22, 2016 9:09 pm Post subject: Re: Insulation / sound deadening thread |
OK so after 2 rolls of reckhorn and almost 2 rolls of reflectex this is where I am at.
Sorry they aren't in order. WEAR gloves with the reckhorn, I got a couple nasty cuts from the edges of the reckhorn. (I guess I didnt learn the first time.) I also used foil Reflectex tape on all the seams and edges after it was laid down. It is gonna be a good 60ish lbs added in weight but it will be worth it to me. Ill report back when everything is finalized. |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Wed Mar 23, 2016 12:34 am Post subject: Re: Insulation / sound deadening thread |
FYI: All reports I've seen about reflectix is you get very little if there is no air gap. Essentially you just get like an R1 from the foil/bubble layer. Reflectix website states: "No Air Space = No Reflective Insulation Benefit".
I cut some foam pipe insulation to create a small air cavity before I put reflectix in.
_________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
Posted: Wed Mar 23, 2016 10:27 am Post subject: Re: Insulation / sound deadening thread |
There will be plenty of gap between the panels and the Relectix, The headliner does not sit flush against the celling. Its the wood headliner so there is about a 2 inch gap. An obvious gap between the rest of the panels. |
Posted: Wed Mar 23, 2016 10:37 am Post subject: Re: Insulation / sound deadening thread |
Cool. I thought perhaps it was smack against the roof with adhesive. Hope it works out for you. I live in mild Northern California so don't experience much temperature swings. I put the reflectix in just because I had the ceiling panel down.
Big Papi Samba Member
Posted: Thu Apr 21, 2016 10:00 am Post subject: Re: The great insulation/ sound deadening thread... |
Pinetops wrote: |
Reckhorn ABX
Reflectix velcro'd on
Home Depot Acoustical barrier (mass loaded vinyl)
How did you affix the MLV on to the other substrate materials? I have read that adhesives are not recommended because they can reactive with the MLV. _________________ 1978 ASI Riviera
TypeIV FI |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Curtquarquesso Samba Member
Joined: April 14, 2010 Posts: 63 Location: Orlando, FL
Posted: Mon Apr 25, 2016 3:42 pm Post subject: Re: Insulation / sound deadening thread |
What should I be using in the nose of my '78 Westy to replace the original fiberglass? Because of some rust holes in the front, I've disposed of the majority of the ruined, damp, nasty yellow fiberglass insulation.
I'm in Florida, so keeping warmth in isn't a priority.
I'd like it to be removable, and not require permanent adhesives or hole-drilling.
Some sound-deadening would also be nice, but I don't think that's an area that needs it that much. (could be wrong)
Suggestions?
Posted: Mon Apr 25, 2016 9:11 pm Post subject: Re: Insulation / sound deadening thread |
Wait! Did the front of the bus contain fiberglass from the factory? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Mon Apr 25, 2016 9:35 pm Post subject: Re: Insulation / sound deadening thread |
Curtquarquesso wrote: |
Suggestions?
Hmm I didnt realize there was fiberglass in there, id imagine sound deadening wouldn't do much there. I would get some new fresh fiberglass, assuming of course you have fixed the rust holes. If not I would just remove it all together so it doesn't hold moisture. |
moab762 Samba Member
Joined: October 09, 2014 Posts: 518 Location: El Segundo, CA
Posted: Mon Apr 25, 2016 9:42 pm Post subject: Re: Insulation / sound deadening thread |
I'd stick with fiberglass or rig up some EZ Cool. Lowes has some good sound deadening fiberglass. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon Apr 25, 2016 9:43 pm Post subject: Re: Insulation / sound deadening thread |
Hmmm, I'm not sure VW put fiberglass there. I've seen some kind of styrofoam stuck to the front of several unmolested buses, but never any fiberglass. Busdaddy?? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Mon Apr 25, 2016 9:47 pm Post subject: Re: Insulation / sound deadening thread |
asiab3 wrote: |
Hmmm, I'm not sure VW put fiberglass there. I've seen some kind of styrofoam stuck to the front of several unmolested buses, but never any fiberglass. Busdaddy?? |
Ya. That's a better question. Is it supposed to be there in the first place? Unless you just trying to do some sound deadening. In that case I would cover the entire area with a thin material and sound deaden behind it. Maybe a layer of EZ Cool and some insulation. |
Hoody Samba Member
Posted: Mon Apr 25, 2016 9:58 pm Post subject: Re: Insulation / sound deadening thread |
I will let you guys in on a little secret....Lobucrod is nothing more then LOW-E that someone has decided to buy in bulk and cut up into smaller pieces and re-market it at a MASSIVE mark up. I bought a roll of the stuff. I think it's a 5 feet tall. I don't even know by how many feet long it is. But it's enough to entirely do the interior of probably 5 Buses. If you can find a distributor locally which there probably is one....an entire roll is 100 bucks. The worst thing about getting a roll of this is that you need a Bus, a minivan, or a pick up truck to move it. It won't fit in a car. It's far superior to the bubble wrap stuff from Lowe's. There are lots of different types now. When
bought a roll there was just the double sided aluminum style. It's great stuff and very easy to work with. |
Posted: Mon Apr 25, 2016 10:10 pm Post subject: Re: Insulation / sound deadening thread |
ivwshane wrote: |
Wait! Did the front of the bus contain fiberglass from the factory? |
moab762 wrote: |
asiab3 wrote: |
moab762 wrote: |
Service records on the car from the original owner show that it was rust-proofed not long after he bought it overseas. When I was removing the soggy fiberglass insulation, it had to be separated from the gunky rust-proofing on the inside of the nose.
The fiberglass insulation was either installed at factory, removed for rust-proofing, then put back, or it was installed for the first time shortly after rust-proofing.
It has all the original (?) fiberglass insulation in it in sliding door, the trunk hatch, above the front head-liner, and some other places. The fiberglass matches, or is just very similar. I still have good large chunks of it I can document and share I believe. Who knows where it came from. I just made the assumption they came with some insulation.
If I'm going to be replacing the kick panels, would it make sense to stick my EZ Cool or Reflectix to my kick panels, and just put some larger chunks of insulation in the cavities? I don't want to stick anything to the nose just yet, as the nose may eventually receive some work, and I don't want any of it to get in the way. |
