WestyPop Samba Member
Joined: February 08, 2005 Posts: 1732 Location: SoCal
Posted: Fri Aug 17, 2018 2:45 pm Post subject: Re: Insulation / sound deadening thread FAQ |
vwwestyman wrote: |
While I generally like driving my '78 with TDI motor, it is kind of noisy.
So I've been thinking of ways to quiet it down!
FYI: '82-? Vanagon diesels (at least the Westfalia models) had a better oem mat/carpet inside the cab laying over the engine area than did the gassers. They were much more effective at killing the diesel's clacking song while heading down the road, and can be trimmed to fit a baywindow. _________________ Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others) |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Aug 17, 2018 3:23 pm Post subject: Re: Insulation / sound deadening thread FAQ |
WestyPop wrote: |
vwwestyman wrote: |
FYI: '82-? Vanagon diesels (at least the Westfalia models) had a better oem mat/carpet inside the cab laying over the engine area than did the gassers. They were much more effective at killing the diesel's clacking song while heading down the road, and can be trimmed to fit a baywindow. |
I have seen some good-looking-if-expensive floor mat material out there that is supposed to kill sound too, which I was thinking about if this project doesn't do all I want it to do.
Any idea what the Vanagon mats were made of? _________________ Dave Cook
1973 Wild Westerner
My Thing |
oc92 Samba Member
Posted: Mon Jan 28, 2019 4:01 pm Post subject: Re: Insulation / sound deadening thread FAQ |
... what about the wooden rear seat on Westy? Would it make sense to put some sound deadening on the inside of the wood panels as well? Or do the Dynamat type products only work for sound resonating on metal panels? _________________ " ... he walked the pavement of the city- a beggar and a king. Has it been otherwise with any man?" WOLFE
72 bus
70 bug
96 mx5 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Mon Jan 28, 2019 4:03 pm Post subject: Re: Insulation / sound deadening thread FAQ |
oc92 wrote: |
... what about the wooden rear seat on Westy? Would it make sense to put some sound deadening on the inside of the wood panels as well? Or do the Dynamat type products only work for sound resonating on metal panels? |
Your latter thoughts are correct- Westy wood doesn’t transmit vibrations like metal.
A few blankets over the engine go a long way too
www.airschooled.com |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Mon Jan 28, 2019 10:55 pm Post subject: Re: Insulation / sound deadening thread FAQ |
asiab3 wrote: |
oc92 wrote: |
Robbie |
That’s just irresponsible. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
oc92 Samba Member
Posted: Tue Jan 29, 2019 6:26 am Post subject: Re: Insulation / sound deadening thread FAQ |
no its cool... I already did the engine with spray foam _________________ " ... he walked the pavement of the city- a beggar and a king. Has it been otherwise with any man?" WOLFE
72 bus
70 bug
96 mx5 |
Posted: Tue Jan 29, 2019 8:59 am Post subject: Re: Insulation / sound deadening thread FAQ |
It will be a while before I can drive and see the difference, but I ordered a roll of this to try insulating the Westy with.
My main goal is to quiet down the diesel engine noise, but I think I'll try insulating with it in other places as I have panels off for whatever reason.
While I have the engine out, I plan to basically cut it in such a way as to fill all the open spaces in the fuel tank area, hoping to absorb as much noise as possible.
I chose it as it's not supposed to soak up water. I was looking at hydrophobic melamine foam, but pointed at this because it'll be more durable than the foam.
https://www.yahoosoundproofing.com/americamat.html _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Feb 08, 2019 11:36 am Post subject: Re: Insulation / sound deadening thread FAQ |
vwwestyman wrote: |
https://www.yahoosoundproofing.com/americamat.html |
The giant roll of insulation I ordered arrived last week but I haven't had ability to do anything about it due to either time or being too damn cold out!
I ordered a bit of this stuff:
https://www.amazon.com/gp/product/B0725ZHDPS/ref=p...&psc=1
I plan to install it next to the metal where ever I install that insulation mat, to prevent the mat from trapping water next to the metal. It should still be able to drain on out. _________________ Dave Cook
1973 Wild Westerner
My Thing |
dirigible Samba Member
Joined: September 28, 2009 Posts: 208 Location: Sudbury, ON Canada
Posted: Wed Mar 13, 2019 11:47 am Post subject: Re: Insulation / sound deadening thread FAQ |
I've removed all the panels and OEM sound damping/insulation from the cavities, and I'm trying to determine what to refill them with. Here's what I've learned from this thread:
1. Don't use batting, because it absorbs moisture. (Agreed.)
2. Don't use FatMat-type solutions because it makes a mess. (Agreed.)
Are there any options I'm missing? I was happy with the noise-level of the OEM batting... I just want to achieve the same in the least destructive way possible. _________________ '71 Campmobile. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Thu Mar 14, 2019 8:33 am Post subject: Re: Insulation / sound deadening thread FAQ |
My '60 bus had Dynamat Extreme applied to the area under the rear bench/bed. I was looking for something under my rear bench/bed seat one day and noticed a few bulges in the Dynamat. I pushed on it and it felt spongy. I made a slice in the Dynamat and out came some liquid! It wasn't water as it was -7C that day. It it ended up being the de-greaser I used a few month earlier to clean the engine compartment. I've since removed the Dynamt. What a pain that was! There was some surface rust starting in the areas where the de-greaser was trapped under the Dynamat. The cargo floor and most of the interior walls was covered in some sort of black glue/tar goop. To remove that I had to use a heat gun, propane torch, plastic scraper and minerial spirits. Many, many hours was spent removing that goop....
I was surprised the floor wasn't more rusty as most of the drain holes were covered over with the goop. Being from California must of helped.
Be careful what you choose for insulation and sound deadener... _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Love77 Samba Member
Joined: September 25, 2019 Posts: 18 Location: Philadelphia
Posted: Thu Nov 21, 2019 10:06 am Post subject: Re: Insulation / sound deadening thread FAQ |
I've seen on some other postings that people have put Butyl Automotive Sound Deadener Mat (like this https://www.amazon.com/gp/product/B0751CBXBT/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1) under their front seats to dampen sound noise from the wheel wells.
The question I have is since this is also where my AUX battery set up is, do people just install the components over the mat? _________________ LoviBus: 1990 Vanagon Westy 2.5 Subie |
Posted: Thu Nov 21, 2019 10:23 am Post subject: Re: Insulation / sound deadening thread FAQ |
Looks like you're working with a Vanagon. Our Buses don't have the batteries up front under the seats, they're in the back with the engine.
I don't know why you couldn't use that stuff under the battery, though I know the compartments are pretty tight, so you'd want to be careful to not lift it up too much and cause fitment issues. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sat Jun 06, 2020 5:36 pm Post subject: Re: Insulation / sound deadening thread FAQ |
Has anyone tried putting flooring underlay over the engine bay area? This stuff advertises being "dense, closed cell foam" which sounds similar to mass loaded vinyl. I have some cork underlay kicking around I could try as well.
https://www.homedepot.ca/product/roberts-black-jac...od-floors/
It's not loud when I'm driving, but the constant engine noise really gets to me after a couple hours of highway speeds. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
