Hella H4 Headlights
Page: Previous  1, 2
nvmipis1
nvmipis1 is offline
PostPosted: Sun Jan 10, 2021 10:37 pm    Post subject: Re: Hella H4 Headlights Reply with quote
pitargue wrote:
I think you'd want to install an H4 bulb than that round one you have.
Maybe Im dense, but we're can I get one ? I've searched and this bulb is all I found that fits. Is there a link?
Tvättbjörn
Tvättbjörn is offline
PostPosted: Sun Jan 10, 2021 10:51 pm    Post subject: Re: Hella H4 Headlights Reply with quote
A H4 light bulb will not fit in the early reflector. The base of the bulb is different. However, there are H4 bulbs with bilux / early bulb bases out there, but I have not seen them for sale in the US. Just use what you have.
Also installing extreme bright marker light bulb ( like somebody said in your own first posting ) does not give you more light to see. Based on the location of the bulb it most likely only blind the incoming traffic a lot.
Bright lights does not mean you see more! A good lens pattern is needed to give you more driving light at night. In other words , a miss matched headlight or bad reflector or just a flat piece of window glass in front of the bulb does NOT help to get a good result.
You can use that wording " H4 Birne 12V mit Bilux Sockel P45T für Umrüstung " and do a search with it. You will find them overseas.
BTW; stay with your own first posting. Keeps everything together. There is lots of bad and danger advice in this one here from other member.
nvmipis1
nvmipis1 is offline
PostPosted: Sun Jan 10, 2021 11:04 pm    Post subject: Re: Hella H4 Headlights Reply with quote
Thank you, this helps me decide it I want to continue with these or just keep what I already have.
Is there a bulb that is higher in wattage to help with the brightness? This particular bulb ia 45w/40w .
nvmipis1
nvmipis1 is offline
PostPosted: Sun Jan 10, 2021 11:05 pm    Post subject: Re: Hella H4 Headlights Reply with quote
This is my set up
Tvättbjörn
PostPosted: Sun Jan 10, 2021 11:19 pm    Post subject: Re: Hella H4 Headlights Reply with quote
Not that I know of . Never seen higher wattage in that style of bulb. The bulb is correct for your headlight.
That is also a difference between sealed beam and Euro style headlights. Sealed beam reflector rarely go bad because it is a sealed unit. On Euro style headlights the reflector does go bad at some point, but when it is in good working order you have the best possible light when cruising down the Autobahn at 150mph Laughing Very Happy .
nvmipis1
nvmipis1 is offline
PostPosted: Sun Jan 10, 2021 11:25 pm    Post subject: Re: Hella H4 Headlights Reply with quote
Tvättbjörn wrote:
Not that I know of . The bulb is correct for your headlight.
A member mentioned this to me on an otber thread
"Your problem could be if you use H4s in Bilux headlights that the bulb is not in the correct position and therefore not in the focal point of the reflector.
You can get special Halogen Bulbs for the R2 socket, which would be better, than using H4s in the wrong socket"
I'm not entirely sure what the above means...🙄
Tvättbjörn
PostPosted: Sun Jan 10, 2021 11:40 pm    Post subject: Re: Hella H4 Headlights Reply with quote
Not sure what a R2 socket is. P45T is the style of bulb base. Like I said , there is plenty of bad advice out there. Everything is designed to work together, Anything thrown together can have a bad ending. Almost anything is possible, just like installing brake pads in the wrong caliper. Just because it is called "brake pad " it does not mean it works the way it meant too in the wrong caliper..
Update. Just did some research. R2 and P45 looks the same. Looks like it did get a new name for some stupid reason Rolling Eyes
nvmipis1
nvmipis1 is offline
PostPosted: Sun Jan 10, 2021 11:42 pm    Post subject: Re: Hella H4 Headlights Reply with quote
Not sure what a R2 socket is. Like I said , there is plenty of bad advice out there. Everything is designed to work together, Anything thrown together can have a bad ending. Almost anything is possible, just like installing brake pads in the wrong caliper. Just because it is called "brake pad " it does not mean it works the way it meant too in the wrong caliper..
Good point.
pitargue
pitargue is offline
PostPosted: Mon Jan 11, 2021 3:56 pm    Post subject: Re: Hella H4 Headlights Reply with quote
My bad. I thought a Hella flat H4 was installed as that is what the first post mentioned. Didn't realize that a different headlight was being discussed. My apologies.
Here's the flat H4's I took off from my notch. They take the H4 bulbs. (My car had sealed beams originally. I bought the flat Hella H4's locally from a craigslist ad.) These flat Hella H4's are exactly the same as the first post of this thread.
I wanted Marchals to match my driving lights. Unfortunately, they are for RHD's. (Notice the flute pattern). But since I very rarely drive at night, it'll do for the time being.
ataraxia
ataraxia is offline
PostPosted: Mon Jan 11, 2021 4:19 pm    Post subject: Re: Hella H4 Headlights Reply with quote
There are a lot of options with P45t base bulbs - you can get halogen bulbs, LED bulbs, brighter 'regular' filament bulbs - they all have pros and cons.
A brighter filament bulb will be brighter but not last anywhere near as long - 'a bulb twice as bright burns 1/2 as long'. The bulbs get VERY hot.
Halogens are going to be very bright but they're hard to focus using older reflectors - you might wind up with unusable flood lights for headlamps. I wasn't able to find a set of halogens that I could get good focused light out of them. The bulbs got VERY hot.
LED bulbs, unless aimed/oriented properly in the housing will be worse. LED bulbs are easy to mass produce and most of them don't work properly because they're not tested by the manufacturer - they just make them and leave the rest up to the user.
I am using LED bulbs with an adapter made to fit H4 (P43t) bulb to P45t - I can adjust the beam so that it doesn't blind other drivers. I get decent lighting out of it.
This picture shows the light from about 6' from the bench - in real world use - the beam cut off is a bit sharper and it doesn't blind oncoming traffic.
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jan 11, 2021 4:48 pm    Post subject: Re: Hella H4 Headlights Reply with quote
I'd make a black vinyl sticker to cover that area at lower left (which aims the beam to the upper right) to avoid glare to oncoming drivers (and likely a ticket).
You might even find them online since this is a common temporary fix for those driving in Europe.
Chupa7hingy
Chupa7hingy is offline
PostPosted: Tue Jan 12, 2021 10:55 pm    Post subject: Re: Hella H4 Headlights Reply with quote
Hella makes a halogen bulb for the old style. Found a pair of NOS Hellas and they take the "odd" P45 base. Amazon has them:
https://smile.amazon.com/gp/product/B078SJ592X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Run good in the old reflectors.
mdege
mdege is offline
PostPosted: Tue Jan 12, 2021 11:15 pm    Post subject: Re: Hella H4 Headlights Reply with quote
And these are the higher wattage ones. The P45t halogen come in different wattages only the 40/45W are street legal in the EU. But nobody notices usually.
- Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
Page: Previous  1, 2
Page 2 of 2
