What to do - Type 4 - engine tin missing
Henrik_K
Henrik_K is offline
PostPosted: Sun Sep 28, 2014 10:57 am    Post subject: What to do - Type 4 - engine tin missing Reply with quote
Just bought a type 4 1800 - engine. With bad or missing engine tins.
It seems a little hard to locate some tins in good shape. I reade about the upright conversion - and thought that could some of my challenges.
Would you recommned that I stay on the original tins or?
Any good pics outthere that shows the complete engine tins?
Rgds, Henrik
Wasted youth
Wasted youth is offline
PostPosted: Sun Sep 28, 2014 11:37 am    Post subject: Reply with quote
Henrik,
I like the Type 4, so my opinion is slightly biased. You can find several pictures of the tins you are missing using the Photo Gallery and also the Classifieds, but getting the actual name or correct part number for each piece can be confusing.
It has been my experience that the two most difficult pieces to locate for the Type 4 are the bottom two that go below the pushrod tubes, but not impossible to find. Regardless, both the Type 1 upright and the Type 4 pancake need all their tin, so converting to the Type 1 might not solve all of your problems anyway.
There is literally a bus full of tin at the VW junkyard where I go.
Also try these vendors of used parts:
Busted Bus: http://bustedbus.com/
Interstate VW: http://interstateusedparts.com/
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
Wildthings
Wildthings is offline
PostPosted: Sun Sep 28, 2014 11:52 am    Post subject: Reply with quote
If you go with an upright cooling system you will become dependent on a heavily loaded fan belt. One of the things I like about the T4 is that the fan is going to keep turning so long as the crank does. Yes there is still a belt to drive the alternator, but it is very lightly loaded and will last for a couple hundred thousand miles with very infrequent adjustments, and when and if it does fail you can still drive a hundred or more miles without the alternator until you can get a new belt.
SGKent Premium Member
SGKent is offline
PostPosted: Sun Sep 28, 2014 12:23 pm    Post subject: Reply with quote
Humbly said - if that is as used engine you may have a lot more going on in that engine than just missing tins. Borrow a bore scope and look inside the cylinders to see what they look like. Check the valves with the rockers off to be sure they are even. Drain the oil and check for bits of metal. Do not tighten the oil strainer bolt more than 9 ft lbs or it will break.
If it is a new engine who is the engine builder?
Tins can be bought easily out of classifieds. For every engine that becomes scrap there is a tin set left over. You should be able to buy a whole set cheaper than piece by piece.
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
Tcash
Tcash is offline
PostPosted: Sun Sep 28, 2014 5:52 pm    Post subject: Reply with quote
Thanks to jersylooker
Engine
sonofamitch
sonofamitch is offline
PostPosted: Sun Sep 28, 2014 5:58 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=503859
'77 Westy 2.0L FI
http://www.thesamba.com/vw/forum/viewtopic.php?t=568454&highlight=
Henrik_K
Henrik_K is offline
PostPosted: Mon Jan 05, 2015 5:19 am    Post subject: Reply with quote
Hi Tcash - I can't seem to find the correspondin item number list to the picture from Jerseylooker. Can you help?
Rgds, Henrik
aerosurfer
aerosurfer is offline
PostPosted: Mon Jan 05, 2015 6:53 am    Post subject: Reply with quote
First off what is your current or planned exhaust setup?
The picture above is tin specific to the stock 75-78 exhaust system.
If you are going with the 72-74 style heater boxes and trapezoid shaped exhaust flanges part numbers 9, 20, 21, 27, 32, and 01 will be different.
Also not pictured will be the heat riser tubes from the forward side of the heater boxes, and the riser from the engine bay to the right side heater box. those parts are specific to the exhaust style.
This is a better thread describing the differences... http://www.thesamba.com/vw/forum/viewtopic.php?t=292923
Once you know what exhaust, then you can proceed to figure out which pieces you need
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
SGKent is offline
PostPosted: Mon Jan 05, 2015 8:11 am    Post subject: Reply with quote
the parts won't be listed in classifieds under VW part numbers. I have never seen a NOS set come up. Most pieces are bent a little, dirty, and have cracks in them.
My suggestion is make a decision what year engine you are going to run and then continue this thread trying to find each piece or a set. Also if you change carbs or FI that may change what you need/can use too.
1971 (sold)
1977
Tcash
Tcash is offline
PostPosted: Mon Jan 05, 2015 9:32 am    Post subject: Reply with quote
Rgds, Henrik
I matched the numbers to the numbers on the parts diagram, to reference the parts description name.
As suggested post the exhaust used and the year of your engine and someone can help you acquire the correct tin.
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-1.html
Good Luck
Tcash
Henrik_K
Henrik_K is offline
PostPosted: Mon Jan 12, 2015 5:44 am    Post subject: Reply with quote
Finally managed to take some pics of my engine tin.
There's also a pic of the heater boxes I plan to use...
Reg. Carbs - I plan to run two 32-34 carbs.
These I'm not really where belong to...
williamM
williamM is offline
PostPosted: Mon Jan 12, 2015 7:28 am    Post subject: Reply with quote
looks like 73. Do you have the big fan casting?
almost easier to identify what you have vers what you need.
Looks like you have front tin w- warm air hole for preheat, but no tube for that. see an oil cooler piece there, bottom tins, under cylinder tins- top cylinder tins-
your off to a good start.
I will try and get some pics of your missing parts. but off to work now.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Henrik_K
Henrik_K is offline
PostPosted: Mon Jan 12, 2015 7:37 am    Post subject: Reply with quote
Yes I have the fanhousing without any cracks...
I've got hold of two 32-34 carbs with linkage...
