scottf1887 Samba Member
Joined: March 14, 2014 Posts: 139 Location: Tejas Baby!!
Posted: Thu Jan 31, 2019 11:03 am Post subject: Ringset for 83mm KS pistons? |
I'm in a bind and hoping someone can help out. I have a very nice set of KS 83mm pistons and cylinders. I need rings and can't find a set anywhere. John at air-cooled.net has the deves rings, but not in stock. I wanted to see if anyone had a set, or knew where to find rings. The top two rings are 1.5mm and the bottom is 4mm. Most ring sets are 2mm thick top rings which don't work on these. Thanks for the help! |
Posted: Thu Jan 31, 2019 12:34 pm Post subject: Re: Ringset for 83mm KS pistons? |
Nevermind...BugCity in CT came through! Not easy rings to find though |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Thu Jan 31, 2019 5:53 pm Post subject: Re: Ringset for 83mm KS pistons? |
Check with "Total Seal" they can usually find or make a ring to fit.
I checked the TS web sight...
http://015ef8d.netsolhost.com/SearchByApplication.aspx
click on Volkswagen [not VW big bore] and go to "40hp overbore"
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
gregson1 Samba Member
Posted: Fri Feb 01, 2019 9:28 pm Post subject: Re: Ringset for 83mm KS pistons? |
If all else fails, you can call Deves directly and have them make you set. I've done this twice and didn't pay much more than I would have buying them from Aircooled.net. |
