duderanchero Samba Member
Joined: October 25, 2008 Posts: 166 Location: el paso, tx
Posted: Wed Oct 01, 2014 3:45 pm Post subject: Both front shocks popped out |
Hit a pothole at night, after which the drive was noticeably bouncier. Drove it home, found that both front shocks had busted through the lower mounting bolts (bolts were nowhere to be found, shocks were protruding visibly beyond lower control arm).
What pre-existing condition might have allowed this to happen?
Since I bought the van, there's been a fair amount of rattling looseness in the front passenger side suspension. The driver side was okay until now.
Thanks for any advice, links, anecdotes, predilections, transubstantiations, and permutations! _________________ '91 carat stick |
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
spacecadet Samba Member
Joined: June 02, 2012 Posts: 158 Location: San Francisco
Posted: Wed Oct 01, 2014 3:54 pm Post subject: |
Original OEM Shocks? Ever swapped or changed?
If someone in the past had replaced the shocks and didn't put back the metal bushing that those lower shock bolts use to keep from bouncing around inside the lower control arm. The excessive play could lead to metal fatigue and eventually your situation.
Maybe someone can show a photo of this assembly? _________________ Daily Drivers Only
1990 Volvo 740 Turbo(Sold)
1986 Mercedes 300 Coupe (Sold)
1954 Volvo PV544 (Sold)
1990 Dodge D250 Cummins (Totaled)
1990 Vanagon GL 2.1 Automatic (Sold)
1968 Ford F250(Current) |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 660 Location: Lancaster PA
Posted: Wed Oct 01, 2014 4:06 pm Post subject: |
Torque specs for those bolts is pretty high and they require the tapered spacer. _________________ wv2yb0252gg092706 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
the joker Samba Member
Posted: Wed Oct 01, 2014 4:34 pm Post subject: |
You must learn every new and odd noise
It will head off a lot of headaches / $$$$
My son (15) is slowly learning the normal Humm of the engine
and the difference between road noise and problem's [/quote] |
Joined: January 03, 2010 Posts: 297 Location: Amesbury, MA
Posted: Wed Oct 01, 2014 4:59 pm Post subject: |
Sounds and smells should be payed attention to.. _________________ 2001 eurovn weekender 207k fresh batteries |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Wed Oct 01, 2014 5:52 pm Post subject: |
Interesting timing. I have been chasing an annoying heavy rattle on my van for months. Periodically, I'd get worried enough to jack it up and examine everything with a flashlight and yank on things. Nothing. Had it aligned last month after putting in a new steering rack and tie rods for unrelated reasons (leak). Asked the tech to see if he could find anything while under it. Nope.
Finally, I decided my shocks must have failed internally and were the source. They did not wobble on the mounts and did not appear to be missing the rubber bushings.
In removing the front right shock I found the rattle. The lower mount is missing the little grommet like reducer that makes for a tight fit on the shock bolt. The shock bolt showed some wear from moving slightly.
So, I guess I'm defending him a bit if this was going to be my fate someday and I think you are exactly right in what happened with him. There was no way to know unless you finally got to the point I did and replaced the shocks suspecting the rattle was internal to them.
So to the OP - check and see if you are missing the metal grommets on the lower shock mounts. Should be one for each end of the shock bolt. If both are missing then your bolts were trashed and that's likely what caused it.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
torchmonkey Samba Member
Posted: Wed Oct 01, 2014 7:14 pm Post subject: |
Are these required for pre 1985 vans? Yes I posted this question in two separate threads. Need answers ASAP. _________________ 1983 1/2 Westfalia |
Posted: Wed Oct 01, 2014 8:42 pm Post subject: |
Looks like spacecadet is today's winner--thank you! There are no grommets/spacers on either side. Each shock requires two?
dart330, thanks for the links--I'll keep the torque specs in mind when I reinstall.
IdahoDoug, I've looked/yanked around quite a bit under mine, too, trying to locate the rattle. I think I have an issue beyond the shock spacers, since both sides appear to have been missing those. _________________ '91 carat stick |
Posted: Wed Oct 01, 2014 11:55 pm Post subject: |
Just FYI, you won't see these easily unless you have removed the lower bolts. The bolt heads cover them up and press them against the shock's lower eye, essentially creating a tubular sandwich under tension that the big shock bolt rides in and is held from vibrating. Cool design. When they are all together and tightened up, you'd need good eyes and a bright flashlight to see the faint edge of the tensioning washer that I am missing.
My rattle was fairly loud and not the lighter sound of an exhaust heat sheild or brake rotor dust shield. It was bordering on a rapid fire clank.
In 20/20 hindsight after I found the issue it was obvious the steel and iron worn off from the two parts (steel bolt/cast iron hole in lower arm) was responsible for the pattern of bright red rust powder trickling out of the lower arm. Did you pull the lower bolts off completely to check? Find empty holes where the grommet should be? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Vanagon Nut Samba Member
Posted: Thu May 05, 2016 3:28 pm Post subject: Tapered ring front shock lower bolt (newer style lower arm) |
MayorMcCheese wrote: |
Torque specs for those bolts is pretty high and they require the tapered spacer. |
Given vehicle age, corrosion, does tapered ring at front shock lower bolt typically require replacement?
This is on an 88 westy, lower miles, likely original shocks. Before I remove the shocks, thought I'd ask first.
Neil _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Thu May 05, 2016 3:47 pm Post subject: Re: Tapered ring front shock lower bolt (newer style lower arm) |
Vanagon Nut wrote: |
Neil |
I never replaced mine.. They are heavy gauge and would likely out last the bolt.
If rusted, I'd replace them.
If in doubt, Van Cafe has them... and then store the old ones. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Thu May 05, 2016 4:02 pm Post subject: Re: Both front shocks popped out |
Thanks. Helpful to know. I have the sleeves on order but those parts will be at least several days away. Want to do shocks now. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Posted: Thu May 05, 2016 4:10 pm Post subject: Re: Both front shocks popped out |
Thanks. Helpful to know. I have the sleeves on order but those parts will be at least several days away. Want to do shocks now. |
They are easy to replace..
If you want to do the shocks now,.. go ahead... You can pop the bolt out again later, turn the lower shock body and pop out the sleeve.. once you have new ones in hand..
Or just leave the originals in place if, during new shock install, they look clean and there's no deformation from them having been left loose.. or some such. _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Posted: Thu May 05, 2016 4:51 pm Post subject: Re: Both front shocks popped out |
Yes f course. Thanks. Easy to do later. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
