MonkeySee Samba Member
Posted: Thu Oct 02, 2014 7:14 am Post subject: DP Front Engine Tin |
Since the Bays didn't come with an upright DP motor with the oil cooler exit in
the front engine tin what is everyone using for this front tin?
I'm putting a DP in my '70 Westy and not sure what to use here or whether to
cut a hole in my original tin for the oil cooler exit. |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Thu Oct 02, 2014 7:26 am Post subject: |
Cutting the hole in your present tin is best value, 71 front tins are available but kinda spendy when you can find them. But they are around. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Thu Oct 02, 2014 2:02 pm Post subject: |
1971 was the only year that had the hole. As said, best bet would be to cut your own hole in a 1968-1970 tin. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
jakokombi Samba Member
Joined: August 15, 2010 Posts: 777 Location: Milwaukee
Posted: Thu Oct 02, 2014 3:38 pm Post subject: |
aeromech wrote: |
1971 was the only year that had the hole. As said, best bet would be to cut your own hole in a 1968-1970 tin. |
Or weld shoulders on a Beetle tin. _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
wcfvw69 Samba Purist
Posted: Thu Oct 02, 2014 3:43 pm Post subject: |
jakokombi wrote: |
aeromech wrote: |
Or weld shoulders on a Beetle tin. |
I almost did exactly this. As mentioned, the 71 dual port front bus tin is one year only. I searched for it recently and found 1-2 but didn't want to drop a $100 on it. My 70 front tin already had the hole cut it in so I just used it. As mentioned, you could find a dual port front tin from a bug and drill out several spot welds on your bus tin then spot weld it to the bug tin. It looks like they just added an extra metal shoulder on bug front tins anyway. _________________ Contact me at [email protected]
The Samba member since 2004.
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Fri Oct 03, 2014 12:06 am Post subject: |
Recently took care of this myself. I found a 1971-specific, doghouse tin here in the classifieds. Not sure what the hole is pictured below, but I ended up plugging it.
Here's a before/after. Gap finally closed up correctly. It was a good exercise since I got around to replacing my fuel vent lines and filler hose too.
_________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
