Window rubber too big
Matt1972
Matt1972 is offline
PostPosted: Sat Oct 04, 2014 12:30 pm    Post subject: Window rubber too big Reply with quote
I got the window rubber from Jbugs for my 72 std. It is just a tad to big and does not fit on the windows tight - therefore the silver trim does not want to stay as well.....I tried some trim adhesive on the windshield with some success...the side window trim is bigger - hate to cut it and then try to seal....
suggestions?
this is more of a PIA than it should be!
boater
boater is offline
PostPosted: Sat Oct 04, 2014 1:24 pm    Post subject: Reply with quote
I remember when I did my 68 windshield, you have to inch the rubber together as you go along. By the time you get to the end, you should be fine.
