Disaster06 Samba Member
Joined: March 22, 2017 Posts: 543 Location: Huntington Beach, CA
Posted: Thu Mar 23, 2017 9:52 pm Post subject: Skate wheel roller pedal. Anyone try one? |
I have been looking at replacing my cheap empi roller pedal from the PO with a retro roller skate wheel pedal from shortys customs. Has anyone tried one of these?
They look awesome. I haven't pulled off the pedal assembly, but it seems fairly easy |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Fri Mar 24, 2017 7:32 am Post subject: Re: Skate wheel roller pedal. Anyone try one? |
I've used them for years. Mostly because the part of the foot pedal assembly that 'holds' the stock gas pedal set-up has corroded away. The cost analyst for buying a new foot pedal assembly for just getting a stock gas pedal wasn't worth it, imo. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Mar 24, 2017 10:16 am Post subject: Re: Skate wheel roller pedal. Anyone try one? |
I used one replaced with a skate wheel in the 80s long before Shorty's. As long as you maintain your cable health and the linkage on your carb they are nice and smooth. To me the smaller wheel and good bearing(s) transfers any nuances more directly through your foot (smaller contact patch). You can feel everything your engine's doing good and bad. _________________
EverettB wrote: |
FU#5 |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Fri Mar 24, 2017 7:21 pm Post subject: Re: Skate wheel roller pedal. Anyone try one? |
Yes, I have done it. You will probably need a longer shoulder bolt. You need a skateboard wheel at least as big as the original roller. You have to buy 4 and they are expensive, even on eBay. You will need skateboard bearings. You will need a spacer use a nut, drill it out and grind it down on the side. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Fri Mar 24, 2017 10:22 pm Post subject: Re: Skate wheel roller pedal. Anyone try one? |
You live in surfcity. Just hit up a skate shop and ask for an old wheel. Or find a skatepark and ask around. I'm sure someone will give you the parts for free. |
Posted: Thu Mar 30, 2017 9:36 pm Post subject: Re: Skate wheel roller pedal. Anyone try one? |
Thanks guys, I ended up picking up one from Shortys. Looking forward to trying it out. It was about $40 shipped and longboard wheels can get up there in price quick so I figured why not. |
