andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Tue Nov 11, 2014 9:36 am Post subject: |
theastronaut wrote: |
andy198712 wrote: |
nice, did you remove the guides or get the shop to do it? same for install? just i'm planning to push mine back or remove so i can port my guide boss somewhat like yours.
thanks for the pics! |
I took them out per Modok's instructions in another thread, used a 3/8-16 tap on the chamber side and stuck a bolt in. Drilled the other end to take pressure off the walls then they tapped out easily. I'll get new ones and let the machine shop put them when they clean up the valve job. |
thanks for that _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Tue Nov 11, 2014 8:02 pm Post subject: |
A really quick/probably not very accurate measurement of the chambers comes up with 40cc, good for 10.2 CR with the current .035" deck. Heads were milled .180". But I'll probably have to notch the pistons, so that'll drop some. I need a more accurate way to measure CC's than the ridiculously stubborn 60cc syringe I have. I have $75 worth of Summit bucks coming soon so its a good time to finally buy a real buret.
Need one of these.
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Tue Nov 11, 2014 11:03 pm Post subject: |
Aww, come on! Waay too fancy! I think you'll be surprised how accurate it is. The only difference is you'll be able to say you have 10.23:1 compression instead of 10.2.
Edit: after seeing your sig line, I'll retract my statement. |
Posted: Thu Jan 01, 2015 1:38 pm Post subject: |
bugguy1967 wrote: |
The one I have sticks no matter what type of fluid I use. It locks down and I had to use pliars to squeeze any fluid out. Sometimes it instantly unlocks and blows fluid everywhere. It's nowhere near accurate when it won't work smoothly. Cheap tools suck!! _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Thu Jan 01, 2015 1:42 pm Post subject: |
I finished the heads. Will drop them off to have a valve job don't this week.
Also ported the main webs between the cylinder openings.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Fri May 22, 2015 6:52 pm Post subject: |
Ok, I'm not known for getting anything done quickly... So the bottom end is assembled and I have the heads back from having a valve job done. I just set it up with clay to check the piston to valve clearance. There is no clearance; the valve barely touches the piston top, just enough to cut through the clay but not enough to make a hard spot when turning the crank.
The piston tops are about .248-.250" thick, it should be ok to cut .100" deep notches? It'll have a 7500 rpm redline; is .100" clearance a good number to shoot for?
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
modok Samba Member
Posted: Fri May 22, 2015 7:05 pm Post subject: |
You could go .150" deep and be fine!
Usually give the exhaust valve 2x clearance as intake. Actual valve lift will lag behind at high rpm. |
Posted: Fri May 22, 2015 7:57 pm Post subject: |
Been looking around, .080" for intake and .110" for exhaust? _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
modok Samba Member
Posted: Fri May 22, 2015 8:11 pm Post subject: |
Yeah, should be about right. |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Fri May 22, 2015 8:43 pm Post subject: |
Did you end up getting the burette to measure your head CCs?
I'd aim for about 2mm (80 thou) on both valves. The intake is heavier and thus more likely to float and kiss the piston. 1mm would be OK if you were sure there was no possibility of float, even if you miss a gear change on the strip. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat May 23, 2015 4:16 am Post subject: |
Just a note on syringe and accuracy: it is hard to read the syringe , resolution of 1 cc strains the eyes. I found an easy solution, I fill the syringe to about 100 cc, then weigh it on a paint scale. Set to zero, and you have way better accuracy, excepting the usual crap with air bubbles and leakage around the lip, plate flex,etc.. |
Posted: Sat May 23, 2015 4:30 am Post subject: |
Actually, if you weigh it and using water it will be very accurate. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
mark tucker Samba Member
Posted: Sat May 23, 2015 10:39 am Post subject: |
Need one of these.
[/quote] I have 2 sets of those, but I dont think you can bolt them on the vw case...
I go .060 intake and .080~.100 exhaust remember the ex is going tward the piston& the piston is going tward the exhaust.the intake is chasing the piston. be sure the cam is degreed correctly before cutting to be positive about the clearance.and head gaskets if you use them. |
Posted: Sun May 24, 2015 1:14 am Post subject: |
yeah, forgot to say it, water, and if you want to get fancy with a drop of food coloring. |
Posted: Sun May 24, 2015 6:45 pm Post subject: |
Good advice all around. I'll be notching the pistons tomorrow, don't want to wait for a machine shop to do it. None of the FLAPS had any sort of valves with 8mm stems in stock, I guess I'll use one of the old exhaust valves to make a cutter. If I don't run into any snags I should be able to get the heads on for good and start checking the rocker geometry this week. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Sun May 24, 2015 6:48 pm Post subject: |
Since the 36 DRLA's will be on the small side, how would IDA's with 37mm venturis work out? I have a pair with manifolds already, just need to finish assembling them. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Sun May 24, 2015 7:11 pm Post subject: |
You can get 34mm vents for the IDAs. I'm no IDA expert, but I think 37s would be big for a 1700. Your engine would qualify as 70's Cal look being a 1700 with IDAs. _________________ 1965 Beetle sedan
Click to view image |
Posted: Sun Jun 14, 2015 10:33 am Post subject: |
I might try the IDA's just to see.
I notched the piston tops myself, .060" on the intake and .035" on the exhaust. Went over the edges with a scotch brite pad on a 2" grinder to round them over a little. Also remeasured the chambers and came up with 42, 43, 44, and 44cc. Going to match the chambers today and get the heads bolted on for good. It'll end up at around 9.2-9.3 compression (it's 9.4 not figuring in the notches). Lower than I wanted but it should be high enough to work ok with the 86b.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
raymon covey Samba Member
Posted: Sun Jun 14, 2015 12:11 pm Post subject: |
Your notches should have been the opposite. The exhaust always gets closer to the piston than the intake. Piston is moving away from intake and chases exhaust valve. |
Posted: Sun Jun 14, 2015 12:24 pm Post subject: |
raymon covey wrote: |
There was already .055" clearance on the exhaust, I notched it .035" for .090" total. The intake has .060" total clearance. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
