floor vent covers
freekazoid
freekazoid is offline
PostPosted: Wed Apr 18, 2007 3:40 am    Post subject: floor vent covers Reply with quote
Does anybody know where I can get some front floor vent covers for my '70? I don't suppose the beetle ones are the same are they?
70 140
70 140 is offline
PostPosted: Wed Apr 18, 2007 6:13 am    Post subject: Reply with quote
Find someone parting a car out. They should come with the cable and levers as well - to open and close the vents.
Gary
Person of Interest
Gary is offline
PostPosted: Wed Apr 18, 2007 6:23 am    Post subject: Reply with quote
70 floor vents don't have cables. They are operated by hand with a direct lever on the vent.
And no, they aren't the same as Beetle vents. IIRC, the cable vents started in 1973.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
Ghiaddict
Ghiaddict is offline
PostPosted: Thu Apr 19, 2007 6:40 am    Post subject: Reply with quote
A point of clarification:
1969 & 1970 floor vents do originally have cables, with the
operating lever mounted high up on the corner underdash kick panels.
1972-1974 floor vents have the cable to the heater control knobs/levers.
Karmann Ghia & Beetle parts available.
Convertible tops installed.
Achilles3588
Achilles3588 is offline
PostPosted: Thu Apr 19, 2007 7:09 am    Post subject: Reply with quote
bfy obsolete parts might also have them, used IIRC.
Larry V.~
'91 Syncro Doka 1.9L TDI 'AFN'
Gary
Person of Interest
Gary is offline
PostPosted: Thu Apr 19, 2007 8:30 am    Post subject: Reply with quote
Are you sure about 1969? IIRC, a 69 I parted out had the hand lever operated vents. I even remember seeing a friend's 70 with them. Perhaps it was a retrofit?
Ghiaddict
PostPosted: Thu Apr 19, 2007 8:39 am    Post subject: Reply with quote
Yes, I'm sure.
But sometimes you see the cables eliminated
by a PO and they just install a knob at the floor vents,
or they swap out the plastic covers to some with handles/knobs.
Here's a pic, 1969 KG convertible, underdash levers, cables
properly hidden behind kick panel carpeting:
ghiajake
ghiajake is offline
PostPosted: Mon Oct 13, 2014 6:01 pm    Post subject: Reply with quote
I had a hard time figuring where the cables/levers routed, so thought I would share. Neither end of the cable is adjustable, so you need to "dry fit" it before it's hidden behind carpet.
