CanStan Samba Member
Joined: October 16, 2005 Posts: 1036 Location: Calgary, AB
Posted: Sat Jan 12, 2019 12:24 pm Post subject: Re: What to 3d print? |
I’d love to see the catch for the folding Westy table reproduced. Unless it’s already available somewhere and I just haven’t seen it. I’d say 9/10 I see are cracked and broken. I’m not sure if the flex it needs to have would be an issue?
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Thu Jan 24, 2019 12:41 am Post subject: Re: What to 3d print? |
Hey dudes,
I would like to work with someone who has design and 3d printing abilities to make a torsion leaf assembly jig.
See the outline of the torsion leaf assembly here?
I think a small donut with the internal cutout of that leaf profile would be Most Excellent when installing torsion leaves into the front beam. I was messing around with zip ties and torsion arms today trying to get new leaves into my old beam, and a jig with that outline would have saved me a few hours of work.
Willing to pay…
www.airschooled.com |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Thu Jan 24, 2019 12:53 am Post subject: Re: What to 3d print? |
asiab3 wrote: |
Hey dudes,
Willing to pay…
Robbie |
Seems maybe you could fab such a thing from sheet Lexan as a one off pretty easy. Ray is our materials scientist, he would know if it would stand up to the grease. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Thu Jan 24, 2019 1:07 am Post subject: Re: What to 3d print? |
TomWesty wrote: |
Seems maybe you could fab such a thing from sheet Lexan as a one off pretty easy. Ray is our materials scientist, he would know if it would stand up to the grease. |
It doesn't matter if it stands up to the grease. Once the leaves are installed, they're secured to the beam and secured in the torsion arms. No amount of soft plastic will affect the suspension one way or the other. I want this part 3d printed because I know most of the raw materials that go into cheap printing will flex enough to be ignored once they're trapped in the torsion tubes.
I have six zip ties in my beam as we speak… The picture below is one of nineteen failed installation attempts due to misalignment…
Robbie
Posted: Thu Jan 24, 2019 1:23 am Post subject: Re: What to 3d print? |
asiab3 wrote: |
TomWesty wrote: |
Robbie
Gotcha. I was thinking it would be removed, not trapped. Makes sense. Cheap, but not too cheap is the aim I guess. Great idea. I still think you could fab them from sheet lexan with a scroll saw pretty quickly. Or mold them from polyethylene maybe. _________________ If you haven't bled on them, you haven't worked on them.
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Tue Feb 05, 2019 9:30 am Post subject: Re: What to 3d print? |
Seems simple enough. I'm taking a 3D printing CE class and need a project. Got some measurements of what you want?
asiab3 wrote: |
Hey dudes,
Willing to pay…
Robbie |
_________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1728 Location: Maine
Posted: Tue Feb 05, 2019 10:08 am Post subject: Re: What to 3d print? |
the part need to be modeled first in a 3d software thats the more difficult part, i 3d print professionally. i wonder if this woudnt be better off as a cast metal part though? it could be made in aluminum easily, but again the part woudl need to have tooling made to produce it. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
Hoody Samba Member
Posted: Tue Feb 05, 2019 10:43 am Post subject: Re: What to 3d print? |
Correct me if I am wrong but would it not be easier and more precise to have that part C&Ced? |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Feb 05, 2019 11:48 am Post subject: Re: What to 3d print? |
You guys are missing it. He wants something that is cheap and can be left on the springs after assembly. The springs would need to be able to move freely once installed and under the stress of the vehicle, so no aluminum allowed, sorry. This also means that the jig doesn't have to be super precise either, if the material is a little flexible that's almost ideal, make it a little tight to hold the springs well during install then the springs can rip through it under compression later. Their soul purpose is to hold the springs together during install. Id think a 1" thick 3d printed cube with that cutout could work ideal. One on each end of the spring pack. It's just making sure the elasticity of the block is correct. It should have a little movement (maybe a mil to allow for a tight fit) then shear after that in order to make sure the spring rate is not effected once the front suspension has returned to service. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Tue Feb 05, 2019 1:06 pm Post subject: Re: What to 3d print? |
Spike0180 wrote: |
You guys are missing it. He wants something that is cheap and can be left on the springs after assembly. The springs would need to be able to move freely once installed and under the stress of the vehicle, so no aluminum allowed, sorry. This also means that the jig doesn't have to be super precise either, if the material is a little flexible that's almost ideal, make it a little tight to hold the springs well during install then the springs can rip through it under compression later. Their soul purpose is to hold the springs together during install. Id think a 1" thick 3d printed cube with that cutout could work ideal. One on each end of the spring pack. It's just making sure the elasticity of the block is correct. It should have a little movement (maybe a mil to allow for a tight fit) then shear after that in order to make sure the spring rate is not effected once the front suspension has returned to service. |
Exactly! I would like it to be flexible enough to not impact the leaf springs in any way. Plus, they have to be expendable. Two or four would be needed for every leaf pack installation, depending on the condition of the existing leaves. They would also have to be small enough to slip through the bronze/plastic bushing assemblies that sit about 6" inside the beam tubes. A hefty zip tie is BARELY small enough to fit by, when zipped around the leaves.
So I think the 3d-printed tool would be perfect, and I'll try my hands on creating a model some time this week.
Posted: Tue Feb 05, 2019 8:37 pm Post subject: Re: What to 3d print? |
ahh i totally missed that , yeah definitely no aluminum for sure! these can be printed with a thin shell to so they disintegrate after install, hmm cool idea!! _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
advCo Samba Member
Joined: May 27, 2017 Posts: 373 Location: Houston, TX
Posted: Wed Feb 06, 2019 12:34 pm Post subject: Re: What to 3d print? |
asiab3 wrote: |
Robbie |
Looks like it would take about 15 minutes to model with the dimensions. I'd be interested in helping out as I can see this being something I may need while rebuilding my beam. Depending on the thickness they could be printed relatively quickly.
I wanted to note for future reference, that I use a company called Shapeways
https://www.shapeways.com/ to outsource some 3D printing that my machine is too small for.
The cool thing about them, you can upload your model and choose your material. They can print in steel, aluminum, plated metals, plastic, sandstone, etc. which really opens the door to using 3D printing for automotive applications. _________________ "He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'68/'70 Ghia Coupe Project
'70 Westy Project - Champagne I Wannabe
A bunch of vintage Japanese motorcycles
"Much ingenuity with a little money is vastly more profitable and amusing than much money without ingenuity." -A. Bennett |
andrewtf Samba Member
Joined: August 10, 2011 Posts: 602 Location: Illinois
Posted: Wed Feb 06, 2019 5:54 pm Post subject: Re: What to 3d print? |
Pm sent to Asia3b.... and
If someone sends (or posts) the dimensions, I can model and 3D print this pretty easily. We could pop out a dozen or more so someone who wants one could get one (or four).
(I work in an architecture office) _________________ '75 Riviera - 'BIG EMMA' (Pan American highway trip paused for a make over)
'77 Riviera - Murphy' (being reborn.... slowly)
'63 Austin Healey |
SGKent Samba Member
Posted: Sat Feb 16, 2019 1:21 pm Post subject: Re: What to 3d print? |
it is a lot easier to put the torsion arm back on if both front wheels are off the ground. I've never had a problem sliding the arm back on that way. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Sun Feb 17, 2019 2:06 pm Post subject: Re: What to 3d print? |
ooh! can you post the specifications for that? like a part image with dimensions? _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
Posted: Sun Feb 17, 2019 3:06 pm Post subject: Re: What to 3d print? |
or can you send me one good clip to copy? _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
Hoody Samba Member
Posted: Sun Feb 17, 2019 9:34 pm Post subject: Re: What to 3d print? |
