palmertom Samba Member
Joined: September 23, 2004 Posts: 18 Location: Wautoma, Wisconsin // Chicago
Posted: Thu Oct 09, 2014 1:36 pm Post subject: Help ID these engine parts: 1972 VW Westy. |
Anyone know what these three parts are? 1972 VW Westy. Thanks!
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Thu Oct 09, 2014 1:55 pm Post subject: |
#1: Non VW bus high/low beam switch
#2: Electrical side of the ignition switch
#3: Altitude compensator or fuel pressure regulator _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
raygreenwood Samba Member
Posted: Thu Oct 09, 2014 1:59 pm Post subject: |
aeromech wrote: |
#3: Altitude compensator or fuel pressure regulator |
Not bad! But #3 is the adjustable vacuum switch that is part of the deceleration valve used on VW type 3 with automatic (possibly), VW 412 with automatic (for sure)....VW bus decel with automatic.....I dont know. Ray |
Posted: Thu Oct 09, 2014 2:27 pm Post subject: |
raygreenwood wrote: |
aeromech wrote: |
You've got me there Ray. I've never even touched a 412 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
busdaddy Samba Member
Posted: Thu Oct 09, 2014 2:54 pm Post subject: |
You're both wrong
It's used for the 4th gear vacuum advance cut off on a 72 bus _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1963 Location: Manitowoc, WI
Posted: Mon Apr 19, 2021 10:14 am Post subject: Re: Help ID these engine parts: 1972 VW Westy. |
Stick your head in the engine compartment and look up, it joins the 2 tank vent lines and connects to the canister. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Apr 19, 2021 10:21 am Post subject: Re: Help ID these engine parts: 1972 VW Westy. |
Ceckert64 wrote: |
I think this is from my 72 and I found it in a box of parts and I’m not sure what it is for. It is a very specific rubber connector/ joint on it. The rubber end has a plastic tube piece on the one side too
TIA |
https://www.thesamba.com/vw/forum/viewtopic.php?p=7743121#7743121 |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Mon Apr 19, 2021 3:29 pm Post subject: |
aeromech wrote: |
I have #3 in my 73 automatic. It hasn’t been hooked up in years. |
