kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Mon Oct 13, 2014 6:55 pm Post subject: Fitting Nose Panel Grill & Screen housing |
I bought new nose panel grill & screen housing (L & R) parts from KGP&R but they don't fit. The part numbers in their catalogue are:
805-067 60 74 RP Left - $165.98
805-068 60 74 RP Right - $165.98
Has anyone else had the same problem? Or is the problem on my car?
Here the part is shown over the aperture where it is supposed to fit. It is both too long and too high.
On the diagonal, the part is 35cm (13 and 5/8 inches) and it is 10.5cm (4.5") high.
But the aperture on the car is only 29cm (11.5") and 8.5cm (3.5") respectively. The area where the original part was taken off is visible here, and one would expect the replacement part to fit exactly in the same place
What is it that I don't get? _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
TheFop Samba Member
Joined: February 03, 2014 Posts: 302 Location: Auckland - New Zealand
Posted: Tue Oct 14, 2014 2:39 am Post subject: |
I believe the answer is at http://www.thesamba.com/vw/forum/viewtopic.php?t=578994&start=380 _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
Stock 69 LHD Karmann Ghia Coupe - Driver
67 New Zealand Spec Beetle - Being rebuilt
63 New Zealand Spec Beetle - Going Baja!
86 T25 Westfalia - Family Fun car |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Tue Oct 14, 2014 4:48 am Post subject: |
They shouldn't slide in the opening, I believe they are supposed to be welded on the inside. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
c21darrel Samba Member
Posted: Tue Oct 14, 2014 2:21 pm Post subject: |
jpjohns wrote: |
They shouldn't slide in the opening, I believe they are supposed to be welded on the inside. |
Yep.
The journey of life consists of long periods of mind-numbing boredom (sanding and scraping, for example) punctuated by short bursts of panic.
I had one of those panic moments yesterday. TheFop provided the answer. I was supposed to receive 2 pieces for each grill, but got only the one side. TJ at KGP&R is sorting it out as I write.
Case closed, thank you.
Moderator Edit: Incorporated here: http://www.thesamba.com/vw/forum/viewtopic.php?p=7407049#7407049 _________________ Festina lente - hasten slowly
