Fenderless 65
Page: Previous  1, 2
VOLKSWAGNUT Premium Member
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Tue Nov 18, 2014 2:58 pm    Post subject: Reply with quote
MMW wrote:
I know I'm ahead of myself here but if I cut for an 8" beam extender will I be able to leave the little shelf where the brake reservoir is & the stock gas tank location?
I am hoping to have it all figured out if I ever get the time to do it. Most of my searching has come up with "just cut until it fits" or most pics seem to have almost all of the front just cut off.
Nope... some of its gotta go.. really the cut and fits method is the best because not everybody does it the same way..
An 8 inch beam extender places the steering box just behind the hood.
My steering box (link pin beam) actually barely touches the hood side lip
Plus the steering linkage is moved forward too... so a good amount of the reservoir shelf is eliminated. It really depends on how you plan to extend the steering shaft too.
The fuel tank area can stay...
So that will give you a pretty good idea.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
rgdedge
rgdedge is offline
PostPosted: Tue Nov 18, 2014 5:12 pm    Post subject: Reply with quote
Measure from the beam forward 8 1/2 inches and up about 2 inches for an 8 inch extension. Then trim as needed.
Tim
()o\|/o()
MMW
MMW is offline
PostPosted: Fri Nov 28, 2014 6:33 am    Post subject: Reply with quote
Got a little bit of time yesterday & was able to disassemble the used beam I bought. It was very packed full of old grease so the leaves/bearings etc. seem really good other than needing a thorough cleaning & re-greasing. Cut off the bump stops also.
I picked up a pair of empi adjusters to put in. Going to try & index them so I'll have 1" up & 3" down adjustment from stock location. The instructions say they give you 4" of adjustment so I'll check that before I weld them in. The reason I want 1" up is if I do go with a beam extension I would then be to low & will be able to raise it up. Right now I'm at 6.5" from the ground. I'd like to be at 3.5' which is about as low as I want to go & be able to drive it. The front tires are 165/15 so I need to decide if I'm going to stick with them or go smaller.
Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Sun Dec 07, 2014 9:16 am    Post subject: Reply with quote
Great looking car, I sure hope you put a beam extender in it and loose the rear apron. It will look killer, Just my .02
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
MMW
MMW is offline
PostPosted: Fri Jan 30, 2015 9:25 am    Post subject: Reply with quote
Wish I had time to work on this but at least my new back wheels arrived today.
15x10 chrome 5 stars. Made by US wheel, bought from Summit racing. Now that I have wheels I can get my tires. Going to put 295/50-15 on them.
Mic
1959 356 coupe
MMW
MMW is offline
PostPosted: Fri Jan 30, 2015 9:29 am    Post subject: Reply with quote
If I had any time at all I would have already done an extender. My worst fear is getting it apart & being so busy it sits in pcs. I'm just waiting until I'm sure I have the time. At least now it can be driven, well once winter is done. My other car has a few things to get done & that comes first.
Mic
1959 356 coupe
MMW
MMW is offline
PostPosted: Thu Feb 05, 2015 2:33 pm    Post subject: Reply with quote
New rear tires arrived today.
Mic
1959 356 coupe
MMW
MMW is offline
PostPosted: Tue Jun 23, 2015 9:06 am    Post subject: Reply with quote
Does this look like one outer spline drop from stock? The pic is a little exaggerated but still plenty of negative camber. I did go one outer spline from where it was but maybe it was already lowered before? I didn't think it was though. The rubber bump stop is almost touching the metal stop when sitting. I did have to jack the spring plate to get it over the lower stop but not a lot. Just curious as to others opinions.
Edit - Quick measurement it's close to 3.5* negative camber.
I will probably go up about 1 to 1.5" from here. Shooting for 1.5* negative.
Still not on the road but it is on it's wheels. No cutting yet but did get the adjustable front end in & wheels & tires on.
Mic
1959 356 coupe
MMW
MMW is offline
PostPosted: Sun Jun 28, 2015 4:21 am    Post subject: Reply with quote
I've been trying to fix numerous small things on this & get it to where I want it. Self imposed deadline of July 12 to make a club show. Minor wiring, door stops, tidying up, tighten up everything that is loose, etc. Found the wiper motor disconnected. Connected it & it runs fast. Car was converted to 12v but I guess no one did the wipers. Sad Now I need to figure that out. Don't think it's a SWF motor but gotta look harder.
Finally got it sitting right after three attempts. First went one outer spline drop. To much camber. Down 4 inners & up four outers from there. Still to much camber plus 1/4" off side to side. Last was down 2/3 inners & up 2/3 outers which is good & fixed the 1/4" difference so now it sits even with a bout 1.5* neg. camber. I want it lower but don't like the broken axle look. It'll stay where it is.
Rear apron was removed. After numerous tape jobs I finally decided on the spot & sliced it off. What a difference, should of done it the day I bought it.
Nerve wracking cutting on nice paint.
Removed this wing
Mic
1959 356 coupe
MMW
MMW is offline
PostPosted: Sat Jul 25, 2015 6:14 am    Post subject: Reply with quote
Question on engine tin. Since the apron is gone & vents were added to the deck lid, how much tin do I need? It looks like the lowers are missing but the small ones in between the cylinders are there. The two tubes on the shroud have also been plugged plus the manifold heat risers are blocked off. Should I find some lowers to put on?
My son is having a blast driving it around & is really doing well learning how to drive a stick. The other day he had trouble backing out of the garage to turn around. Kept stalling it, I reminded him about the e-brake. Embarassed At least it wasn't in public.
Mic
1959 356 coupe
PostPosted: Sat Jul 25, 2015 8:01 am    Post subject: Reply with quote
Think of it like this.. Most Dune Buggy's run around with the basic tin.. so that being posted.. .. your will most likely have PLENTY of fresh air available.
You may want to consider running the lower sled tins and/or industrial style HEAD tins though...as they do help exhaust the hot air rearward and more efficiently around the head and cylinders..
Easy enough to make... Wink
Here: http://www.thesamba.com/vw/forum/search.php?search..._chars=200
aka Ken {o\!/o}
MMW
MMW is offline
PostPosted: Wed Jul 29, 2015 9:01 am    Post subject: Reply with quote
A 009 mechanical distributor should be set at 28-32*. Does it matter what engine, carb, dist combo you have or it always gets set at this?
Mic
1959 356 coupe
MMW
MMW is offline
PostPosted: Sun Sep 09, 2018 3:50 pm    Post subject: Re: Fenderless 65 Reply with quote
Holy crap, just looked at my last post. It was 3 years ago. Where has the time gone?
Haven't done much to this expect drive it a little bit and let my son use it. He put more miles than me on it. Thing runs great.
Put a "new" shifter in it this past week. Out with the stocker and in with the "cooler". Can't take credit for the knob or shaft because it came extra with the car. I just had to add an empi quick shift kit and bend the shaft to fit better. Knob is a camshaft from a motorcycle.
Mic
1959 356 coupe
mikec4193
mikec4193 is offline
PostPosted: Mon Sep 10, 2018 9:37 am    Post subject: Re: Fenderless 65 Reply with quote
Glad someone is enjoying your hot rod...these vehicles have never been fond of sitting for long periods of time....
I hope your son likes driving it too...
MikeC
Dad bought his first Beetle on Dec 17, 1953.
Page: Previous  1, 2
Page 2 of 2
