Mscdman Samba Member
Joined: June 12, 2014 Posts: 562 Location: Denver, CO
Posted: Fri Nov 07, 2014 5:23 pm Post subject: Question on Creating & Attaching Rear Parcel Tray |
I have an earlier post on the parcel tray, but this one is on the order in which the tray pieces are assembled. I have the following parts:
1) Thin foam padding (I think 1/8 inch thick - I need to re-measure)
2) Vinyl material to match CV side cover panels
3) Cardboard
A few questions:
1) What is the order these are put together? Specifically, does the foam get glued to the metal parcel tray, then the cardboard on top of that then the vinyl? |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Fri Nov 07, 2014 7:24 pm Post subject: Re: Question on Creating & Attaching Rear Parcel Tray |
Mscdman wrote: |
3) Cardboard
A few questions:
I've just completed my own parcel tray with some advice from an automotive upholsterer. He said I should assemble the parcel tray as follows:
Tray (cardboard) first
Followed by foam padding lightly glued down on the cardboard
Vinyl comes last, folded and glued down over the edges but lightly glued down on to the foam
Installation in the car comes last. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Sat Nov 08, 2014 7:29 am Post subject: |
So the cardboard gets glued to the metal parcel tray? |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sat Nov 08, 2014 9:57 am Post subject: |
Mscdman wrote: |
If the vinyl is folded over the edge of the metal and glued, then I wouldn't think that you would have to glue the cardboard to the metal.
Aren't there some slight shapes stamped into the metal parcel tray to strengthen it?
If I'm not mistaken, the cardboard is simply there to make a completely flat surface before padding.
This has probably been mentioned already, but vinyl in general will reflect on the back window - the lighter in color and the smoother the vinyl, the more it will reflect.
Carpet would be less likely to reflect, but seeing as the vinyl would look more like an extension of the top of the back seat (at least when it's in the up position) I can see why you might prefer that look to carpet. |
