Mike C Samba Member
Joined: September 18, 2008 Posts: 303 Location: Albuquerque
Posted: Mon Jan 12, 2015 4:23 pm Post subject: Help identify this fuse holder |
So I got home from using the bus all day, opened the engine compartment to check on things and this had pop open:
http://i83.photobucket.com/albums/j283/gamefisher/IMG_0209_2_zps98fd4592.jpg
I'm embarrassed to say that all the years I've owned the bus I've never payed too much attention to the part. Shame, shame on me... Although I know that there was a fuse inside of it.
Also, what size fuse does it take?
The bus ran strong all day--no problems and as far as I know all electrical was working.
Thanks _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
[quote="1977_L63H_P27"]As mentioned before, it's a 9-passenger Deluxe. The true "station wagon" of buses. |
tubdub Samba Member
Posted: Mon Jan 12, 2015 4:27 pm Post subject: |
its a fuse holder for the reverse lights |
tubdub Samba Member
Posted: Mon Jan 12, 2015 4:28 pm Post subject: |
white fuse |
dillon70 Samba Member
Joined: October 20, 2008 Posts: 234 Location: Ventura, Ca.
Posted: Mon Jan 12, 2015 4:33 pm Post subject: |
He is correct. I had half a fuse holder and no reverse lights. I wondered the same thing. The power works off of your coil. _________________ 2001 ZO6 (450+hp)
1985 930 Turbo (400+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
1970 Chimney Pop Top (120 hp) SRFBUS1
1990 Vanagon (95 hp)
1985 Vanagon GL (85 hp)
1969 Tin Top 1 owner OG
Can I get any slower?
2015 CC R-Line (heavily mod'd)
Brian Samba Moderator
blackivory69 Samba Member
Joined: April 08, 2013 Posts: 309 Location: California
Posted: Mon Jan 12, 2015 4:34 pm Post subject: |
I believe that is the fuse holder that's connected to the tranny for the reverse/back up light. But somebody might have bypass it. You can turn on your ignition (do not start, just put it on the ON position) and put your gear in reverse. Your reverse light should turn on. If not, then you found your problem. I'm not sure about the size but I think it's the same VW fuse we use (Red or white). I will guess it the white (10 A????) _________________ 1970 Double Cab. Stock engine (1600 SP)
1973 Thing (Mexican Safari)
1970 Karmann Ghia Convertible
1969 Buggy |
Posted: Mon Jan 12, 2015 4:38 pm Post subject: |
I'm toooo slow. They beat me ^^^^ _________________ 1970 Double Cab. Stock engine (1600 SP)
1969 Buggy |
Mike C Samba Member
Posted: Mon Jan 12, 2015 4:45 pm Post subject: |
I have the OG manual. Never thought to look in there. No excuses...just being a lame bus owner today.
Thanks everyone for the help. I appreciate all the responses. _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
