ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Sun Oct 19, 2014 11:02 pm Post subject: Alternatives to BN-4 heater for a US spec 1973 Thing |
One of the previous owners of my US spec 1973 Thing did a very good job when they removed the BN-4 gas heater system from my vehicle, it appears the only items remaining are the windscreen defrost bits.
I've been searching for a replacement, complete, BN-4 gas heater system for the vehicle, it has been a challenge . . .
If I am able to locate a complete BN-4 system, assuming all of the bits work, over time, it will be a challenge to replace any items that may fail.
I have been looking for alternatives to the BN-4, and it appears that the 'best bet' in terms of being able to locate replacement bits is to go with either a Eberspächer or Webasto diesel cab heater, as used in diesel tractor trailer trucks.
In principle, the diesel cab heaters work the same as the BN-4, the primary difference being the fuel source.
I have narrowed my choices down to two diesel cab heaters, the Eberspächer Airtronic D2 or the Webasto AirTop 2000. Both operate, in principle, the same as the Eberspächer BN-4.
It appears that based on the dimensions of both units that they should fit under the front hood of my Thing. I would have to perform a 'field expedient measure' to route the heat to the windshield as well as interior. In terms of hook up of either units, it would be similar to the BN-4. I would mount the device control for the unit to the dash panel to the right of the speedometer. The wiring to the battery I could route along the right side of the car. I would need to determine how to route the exhaust from the unit. As for the diesel fuel tank, it appears I could mount it in the front of the vehicle where the side curtains are stored.
I have searched TheSamba forums to see if anyone has installed a diesel cab heater into a Thing with no results. The results returned are for folks who have installed them into diesel Vanagons.
So, before I spend the bread on a diesel cab heater and all related bits . . .
- Has anyone attempted to install a diesel cab heater into their Thing?
- If so, what steps were taken to install the diesel cab heater?
Once I have the time to finish the brake work on my vehicle, I intend for it to be my daily driver. With winter approaching, it would be nice to have heat in it . . .
If not, well, I guess I will have to re-enact what it was like it was for the cars 'Daddy' in Eastern Europe between the winters of 1941 to 1945 . . . |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Mon Oct 20, 2014 11:12 am Post subject: |
I have a gas heater with a few odds and ends in a box somewhere, I couldn't tell you why as I have a '74. If you are interested I could dig it out. It's been around for years, and I've thought about using it myself as I am going Type 4 and possibly giving up the heater boxes, but I think in the end if I go gas heater I'd much prefer something modern.
Anyhow, other than just being interested myself in what you do here, and how you do it, I've a few other thoughts.
Have you considered using heater boxes? It would be an exhaust and ductwork, but it sounds like you're already spending money and fabbing ducts.
Why diesel? I am not very familiar with current cab heaters but was under the impression most could be had in a gas version, though I'm sure not many are sold. Have you looked into a gas model and decided against it, or just not thought of it? It would be a lot simpler at the gas station. |
analogmax Samba Member
Joined: September 27, 2006 Posts: 161 Location: Chandler, Arizona
Solomon Grundy Samba Member
Joined: December 26, 2004 Posts: 747 Location: Silicon Valley
Posted: Mon Oct 20, 2014 8:53 pm Post subject: |
I like these heater ideas but I am wondering why you chose diesel heaters?
My old heater works half the time and I have another one for spare parts. TTS has indicated that Shawn at Shamrock Racing in New Mexico can rebuild, fix and test the old BN4 heaters. Has anyone used these folks? _________________ "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Dr. Seuss
VW 181 Archive: https://sites.google.com/site/jeffgilleland/vw_archive
| _______
| |_______| '73 Thing "481"
| _\_\_|_/_/_
| |O||_4_||O|
http://vwthingregistry.com
https://doublecabshaka.wordpress.com |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Tue Oct 21, 2014 9:23 am Post subject: |
Bill-
The Airtronic B2 or B5 run on gasoline (benzin), while the D series run on diesel.
The B's are hard to find in the US, but they are vastly superior to the old BN2's and BN4's. They are also very expensive.
The Airtronic:
Your best bet would be to find a good, working BN4 from a Thing (rather than from a Bus) which includes the duct-work, controls, etc. That would be a direct fit, with no modifications or fabrication.
Re: European winters of '41-'45, do you own the U.S. Army Operation and Repair Manual for Kubelwagen?
Interesting read.
Good luck, Mondshine |
Posted: Wed Oct 22, 2014 8:33 pm Post subject: |
mondshine wrote: |
Re: European winters of '41-'45, do you own the U.S. Army Operation and Repair Manual for Kubelwagen? |
Well, I do have a copy that I made one day after work not long after I started working at the National Archives in Washington, DC, oh, so, many years ago.
It appears that the US Center for Military History has it available as a PDF . . .
http://usacac.army.mil/cac2/cgsc/carl/wwIItms/TME9_803_1944.pdf |
Posted: Wed Oct 22, 2014 8:37 pm Post subject: |
iltis74 wrote: |
I was thinking about using heater boxes, but after reviewing the parts fiche on the K-mann CD, as well as all of the mod's that would need to be made, the diesel cab heater looked like the way to go.
As Gary mentioned, the diesel cab heaters work on the same principle as the BN-4, the difference being the fuel and about 40 plus years 'newer.' |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Oct 23, 2014 6:34 am Post subject: |
My only concern with running a diesel heater would be the fact I would have to have 2 fuel tanks in the car now for 2 different fuels..... |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
saddlesore1 Samba Member
carsdlt Samba Member
Joined: May 02, 2012 Posts: 317 Location: So. OC, Calif.
Posted: Thu Oct 23, 2014 10:31 pm Post subject: |
X2 _________________ Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own." |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sun Nov 02, 2014 8:39 am Post subject: |
I did not have a gas heater in my 73 so I just added the 74 heater boxes drilled 2 holes in the rear for the heater tubes added a bus heater blower fan a 74 heater floor tube and installed heater cables you don't have to install the cables you can wire the boxes open and you can just let the tubes lay on the floor. I have drove in 20 degree weather and drove in 4 winters I drive this thing everyday even in the winter and stay comfortable. I checked the temp coming out of the vent yesterday and it was 176 degrees hot enough for me
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Sun Nov 02, 2014 2:16 pm Post subject: |
A 12 volt electric heater might be another option to consider.
http://dcthermal.com There are several options for ducting and ducts.
To do the job right, if you have a 70 amp alternator (like the Bosch style) you could mount a second battery under the driver side rear seat and include an RV-style battery isolator to make sure that running the heater doesn't leave you stranded. Even with all the goodies it would cost half as much and install much more easily than a modern gas or diesel heater. |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Wed Nov 19, 2014 9:26 am Post subject: |
This is the temp of the heat coming out the vent in the front on my 73 thing with 74 heater boxes and with a bus blower . I have this heat all the time at idle or full running . It was 20 degrees outside when I took this
GI Joe Samba Member
Posted: Wed Nov 19, 2014 11:53 am Post subject: |
that temp was taken at idle here is a couple of pictures I have drove this Thing for 4 winters so far
