Manfreds78bay Samba Member
Posted: Mon Oct 20, 2014 2:43 pm Post subject: Thermostat Challenge |
Has anyone come up with a better solution to the standard VW thermostat? I would figure by now someone would come up with a neat-o way using tech-nalo-ogy and the interwebs to create something simpler and cheaper.
If you have, please sell it to me.
If not, I will accept this challenge. _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Oct 20, 2014 2:49 pm Post subject: |
I challenge you...
I have seen these types of bellows used in steam heat condensate drain controls. They were made by Vapor Corporation in Chicago. But that equipment dated to the late 1960's, and I don't know if Vapor is still in business. They might answer the phone in Mandarin, for all I know. |
merlinj79 Samba Member
Posted: Mon Oct 20, 2014 3:19 pm Post subject: |
You could install a solenoid to power the flaps closed. Several options for how to control it...
Simple: Manual on/off switch, turn the solenoid on from the cab to close the flaps for a cold start, and then turn it off when it's warmed up.
Less Simple: Same setup but with a safety timer that de-powers the solenoid after 5-10 minutes (depending on where you live and driving habits).
Not-so-Simple: Install an electronic thermostat in the engine compartment to control the solenoid. Challenge here would be locating and adjusting it just right to mimic the bellows performance.
I don't think you need to control the flaps to any intermediate position...I think they're mostly either all open or all shut, given the design of the bellows (fluid phase change) I don't think they linger half-open for long. _________________ Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff |
Brian Samba Moderator
Posted: Mon Oct 20, 2014 3:28 pm Post subject: |
car-puter. have a thermocoupler on each cylinder and have an electronic solenoid control the flaps on each side with a failsafe that alerts you when temps get too high. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Mon Oct 20, 2014 10:03 pm Post subject: |
How about a bellows and a rod or cable connecting to some flaps. Should run a hundred thousand miles quite easily between fairly inexpensive repair jobs. No wiring, vacuum hoses, dashpots, actuators or sensors of any kind needed. |
Air Cooleds Only Samba Member
Joined: October 18, 2009 Posts: 157 Location: Prescott, AZ
Posted: Mon Oct 20, 2014 10:07 pm Post subject: |
Wildthings wrote: |
To easy! _________________ Air Cooleds Only |
Wildthings wrote: |
Posted: Tue Oct 21, 2014 12:31 am Post subject: |
Wildthings wrote: |
Mine did not last a hundred thousand miles. Not even close. 100 dollars isn't worth it. I want something cheaper.
The thermostat is too fragile and too expensive. If it wasn't everyone would have a working cooling system.
The wire only has to move 2 inches. The hardest part is figuring out how open and close with the engine temperature.
I've never tested one. Is it truly either on or off? _________________ 1978 2.0L FI Campmobile
Posted: Tue Oct 21, 2014 12:45 am Post subject: |
I find that my flaps are halfway open quite often when the weather is cooler. Go down a long grade at near freezing and the flaps will pretty much close the whole way.
During the '70's there were dozens of different temperature controlled vacuum valves on various cars. One of them would surely have about the correct operating characteristics for the T4 engine thermostat when combined with a properly sized dashpot. |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Tue Oct 21, 2014 3:41 am Post subject: |
Use a cheaper and more available type 1 t stat. Its a little cooler operating temp but the one im using seems more robust than the 3 stock ones I have come across in the last few years. Just need to swap to a different union nut to mount the cable _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Tue Oct 21, 2014 4:37 am Post subject: |
Manfreds78bay wrote: |
I've never tested one. Is it truly either on or off? |
I tested my old one before reinstalling it on my 2.0 1977 engine, using a heat gun blower. I noticed it was a variable position, depending on how long I had the heat gun on it. Mine was not all the way open or all the way closed, but it regulated instead. Regulation was not perfect or sensitive, but that seemed attributed to the tension it was working against on the cable, spring loaded flaps and hinge points. |
Posted: Tue Oct 21, 2014 7:47 am Post subject: |
OK, so it needs to be variable...
Temp sensor on the engine, stepper-motor driving the flaps controlled by a PLC (programmable Logic controller).
Or instead of a PLC, a good science project would be to make your own custom digital controller. You could do it with radio shack parts but would probably want to locate it outside the engine compartment for durability reasons. _________________ Rick
"Pumpkin II"
CA Smog Stuff |
Posted: Tue Oct 21, 2014 7:50 am Post subject: |
yea that's the real trick here, then and the genius of the bellows. It's able to self regulate based on the engine temp.
I'm looking at the new Mexican style thermostats. Looks like they are just a solid metal spring that elongates as it heats up. Nothing is going to leak and cause the failure. But what I just read about them says they are hard to find.
I want something easy to make that we can all get our hands on at Home Depot or something similar.
I was also thinking electrical that could attach to head temp sensor. AS the heads heat and cool the flaps open and close. _________________ 1978 2.0L FI Campmobile
Last edited by Manfreds78bay on Tue Oct 21, 2014 7:53 am; edited 1 time in total |
Posted: Tue Oct 21, 2014 7:52 am Post subject: |
merlinj79 wrote: |
Or instead of a PLC, a good science project would be to make your own custom digital controller. You could do it with radio shack parts but would probably want to locate it outside the engine compartment for durability reasons. |
That sounds interesting and a good start. _________________ 1978 2.0L FI Campmobile
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Oct 21, 2014 10:52 am Post subject: |
Don't bother trying to reinvent the wheel. Go with the following and it will be the last one you buy.
http://www.thesamba.com/vw/classifieds/detail.php?id=1036746 _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Tue Oct 21, 2014 10:58 am Post subject: |
Hey I don't want to at all. so are you saying if this thing fails for whatever reason besides a bad install...it will be covered under warranty. _________________ 1978 2.0L FI Campmobile
Posted: Tue Oct 21, 2014 11:07 am Post subject: |
Hey I don't want to at all. so are you saying if this thing fails for whatever reason besides a bad install...it will be covered under warranty. |
According to the seller Volk. Yes. He does great work. The material he uses for the t stats is better than the original OEM and will handle the heat cycling much better over the long term.
You can pick up new cable at bicycle shop for cheap. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Tue Oct 21, 2014 11:10 am Post subject: |
Wildthings wrote: |
Man....I cant imagine who would undertake an, engineering feat like that....
Ray |
Posted: Tue Oct 21, 2014 11:31 am Post subject: |
raygreenwood wrote: |
Wildthings wrote: |
Ray |
I know make fun all you like. But maybe I got a bad one. but from reading other posts and my own experiences...these things suck. Am I in the minority? _________________ 1978 2.0L FI Campmobile
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 537 Location: Talbott, TN
Posted: Tue Oct 21, 2014 5:51 pm Post subject: Type 4 Thermostat |
I got one of the NOS Thermostats from Bus Depot for the Beatle, since they were NLA for the Bus, and it failed really quick (6 months maybe), so I got one of the new Awesome Powdercoat ones, made specifically for the type 4 bus motors, and it has been working perfectly for the past 18 months, and they offer a 2 year warranty on them. I agree with a previous poster, their quality is excellent, so hope it lasts......
I can also share that just watching the flaps from a cold start and engine idling in 75-80 deg. ambient temperatures, it takes about 12 minutes for the flaps to go from full closed to full open, and it is a very gradual open (no abrupt movements. |
