jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Oct 21, 2014 7:52 am Post subject: 1979 heater dump tube hoses - substitute found |
I cannot find the proper paper hose that connects the heater control valve to the heat dump tubes for a 1979 exhaust/heater system.
These should be black paper tubes, similar to the ones that connect the heater blower fan to the heat exchangers in the engine compartment, except where those are 50 mm ID, the dump tube hoses are 55 mm.
Does anyone have a source? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Tue Oct 21, 2014 8:17 am Post subject: |
Tried your FLAPS? There isn't anything very special about the hoses and for the most part they do very little. |
Sage79 Samba Member
Joined: September 13, 2008 Posts: 433 Location: Holland MI
Posted: Tue Oct 21, 2014 8:30 am Post subject: |
I got a standard FLAPS size, which is a bit small, and enlarged them slightly with a HF exhaust pipe enlarger tool to slide on. _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
jtauxe Samba Member
Posted: Tue Oct 21, 2014 8:37 am Post subject: |
Yes, I was going to try the FLAPS today. We'll see... _________________ John
http://vw.tauxe.net
SGKent Samba Member
Posted: Tue Oct 21, 2014 10:38 am Post subject: |
2 1/4 is about 57mm. The temperature coming out of the heat exchangers melted some plastic ducting sold as a replacement bellows. Use silicone / fiberglass. or aluminum if you can. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Boesen Samba Member
jtauxe Samba Member
Posted: Tue Oct 21, 2014 11:17 am Post subject: |
SGKent wrote: |
2 1/4 is about 57mm. The temperature coming out of the heat exchangers melted some plastic ducting sold as a replacement bellows. Use silicone / fiberglass. or aluminum if you can. |
I generally agree, Steve. I am sort of amazed that VW put a paper hose here... seems like inviting trouble. Perhaps VW did not actually have a paper hose in this location originally...? I will use metal if I can find it.
Boesen wrote: |
I bought one of these http://www.busdepot.com/211261236
Plenty long to be able to divide into two for each dump tube. Used a hose clamp to attach on both ends. |
And that is a large enough diameter? I ask, 'cause the 50-mm stuff I got (very similar) tore because it was not big enough. _________________ John
http://vw.tauxe.net
Boesen Samba Member
Posted: Tue Oct 21, 2014 11:44 am Post subject: |
[quote="jtauxe"]
SGKent wrote: |
Boesen wrote: |
And that is a large enough diameter? I ask, 'cause the 50-mm stuff I got (very similar) tore because it was not big enough. |
Yes it is bigger than the standard 50 mm. If you still have the heater fan above engine it's the passenger side hose. Try the round end not the odd shaped end. It fits... the old Bus depot website years ago had the measurements for the hose. Call them if you still have doubts. Worked great for me. _________________ 1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa |
germansupplyscott Samba Member
Posted: Tue Oct 21, 2014 12:00 pm Post subject: |
those hoses are near impossible to match. i believe they are 52mm ID. nothing readily available fits, either a bit too big or too small. 2"/50mm hose will not fit. 55mm is far too big. 50mm with a slit works.
the original hose was not paper, it was aluminum. i have some scraps removed from old pipes, for reference, but have never seen this hose available anywhere. _________________ SL |
SGKent Samba Member
Posted: Tue Oct 21, 2014 12:29 pm Post subject: |
http://www.socalautoparts.com/product_info.php/aft...um-p-12369
The actual part number is N90042801 or N 900 428 01 . VWHeritage says online they can get them from Classic Parts but the part number does not come up in Classic Parts.
Also from another thread
Karl wrote: |
The dump pipes were 78 and 79. They are #41 below and are NLA from VW. The connecting hoses, #39, are part number N 900 428 01 and the dimensions are 52x2,5x270 [all mm]. And this dealer shows 1 in stock:
GRAHAM AUTOMOTIVE
SIOUX FALLS, SD 57105
1 (605) 336-3655
jtauxe Samba Member
Posted: Tue Oct 21, 2014 3:26 pm Post subject: |
Aluminum tubes sounds a lot safer. I can't imagine the paper holding up well, and I sure as heck do not want a fire under there!
The best I could do at the FLAPS was a hose from NAPA, #819-1126, for just over $5. They call it a preheater hose.
It's 2" (50.8 mm) diameter, 18" (457 mm) long flexible accordion type hose.
I am hoping that I can squeeze it on. If not, I will get them to stretch it out a bit with an exhaust pipe flanger. Flanger? -- You know what I mean.
Interestingly, it turns out that Russ Wolfe mentioned this hose in the Type 3 forum:
http://www.thesamba.com/vw/forum/viewtopic.php?t=174651
EDIT:
Worked like a charm. These are just the right size, so that with a little twisting they go on snug.
I recommend using the whole unstretched 18 inches for each side, so that as the ends fray (e.g. through repeated servicing) they can be trimmed off.
EDIT EDIT:
Well, oddly enough, it worked like a charm on one side, but on the other side, it was just a little too tight, and I had to slit the ends to get them to fit over the pipes. It may have been better to use an exhaust flanger, but this seemed to work OK.
At any rate... I have HEAT for the winter! _________________ John
http://vw.tauxe.net
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Tue Oct 21, 2014 6:14 pm Post subject: |
Colin made some tubes for his Road Warrior bus, maybe check and see what he used?
www.airschooled.com |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1265 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Fri Sep 22, 2017 10:45 am Post subject: Re: 1979 heater dump tube hoses - substitute found |
Original VW Classic Parts through VW Heritage has these. N-900-428-01. You have to go into the OVWCP site, though, since the number won't register on the VWH search. My experience is that they don't last long. Maybe I stretched them out too much, trying to get two for one. |
Tcash Samba Member
Posted: Fri Sep 22, 2017 11:35 am Post subject: Re: 1979 heater dump tube hoses - substitute found |
stanhelp wrote: |
What is the OVWCP site?
Thank you
Tcash |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Sep 22, 2017 12:22 pm Post subject: Re: 1979 heater dump tube hoses - substitute found |
Your local FLAPS has these. They are usuallly next to the spools of fallopian tubing. |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Fri Sep 22, 2017 4:07 pm Post subject: Re: 1979 heater dump tube hoses - substitute found |
I used the paper hoses. They have been on my 78 bus for three years without any problems. I cut three slits at the ends and slid them over the pipe and gear clamped the paper hosing on.
