MacDude Samba Member
Joined: July 26, 2014 Posts: 101 Location: Bonny Doon
Posted: Mon Oct 27, 2014 4:19 pm Post subject: Westy Leak - not skylight |
So it seems that now that we actually got some rain in California, some part of the roof is leaking. I'm hoping someone has seen this before.
My Westy is parked in the driveway and it is slightly sloped so the nose is a bit higher than the back. Hi may have something to do with the place the water is coming out, but the leak is there nevertheless.
As you can see in the pictures, there is a small seam that is where the water comes out and drips right down next to the rear hatch.
Anyone have an idea how the water is getting in there? Plugging it up there with caulk or whatnot, would mean that the water would still be getting into the roof...
Thanks! _________________ '84 Wolfsburg Westfalia
'90 White Multivan (currently not running) |
HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
Home Team Van Samba Member
Joined: January 02, 2008 Posts: 465 Location: wilmington, nc
Posted: Tue Oct 28, 2014 4:36 am Post subject: |
Some silicone around that grommet where the wires go into the hatch solved the problem for me. _________________ _________________________________
82 Diesel Westy |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Posted: Tue Oct 28, 2014 4:39 pm Post subject: |
Home Team Van wrote: |
Some silicone around that grommet where the wires go into the hatch solved the problem for me. |
After experimenting with a water jug... That looks like the fix to me too. I'll reseal the two grommets and see if that does it. I would love to replace them, but I doubt that would be worth it. _________________ '84 Wolfsburg Westfalia
Posted: Sun Nov 02, 2014 9:50 am Post subject: |
MacDude wrote: |
After experimenting with a water jug... That looks like the fix to me too. I'll reseal the two grommets and see if that does it. I would love to replace them, but I doubt that would be worth it. |
Well I was wrong. I cloaked up that broken seal for the wiring and the recent rains totally soaked the rear. I am thinking it is something up front having to do with the drainage of the cargo area. So I'm going to remove that and see how the previous owner sealed it when he put in a small solar panel up there.
Luckily I had removed the pad above the engine already. The side panelling is not so happy. _________________ '84 Wolfsburg Westfalia
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Sun Nov 02, 2014 11:19 am Post subject: |
you may need to re-caulk/silicone all the roof bolts. i haven't tracked mine down yet, but i suspect the luggage rack area, which has the largest number of holes in it.
where the the pop-top meets the luggage rack seems a pretty easy water entry spot. is the front of your tent damp? _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
rickf46 Samba Member
Joined: March 01, 2013 Posts: 6 Location: New Hampshire
Posted: Sun Nov 02, 2014 5:39 pm Post subject: |
I had a similar problem and was baffled. (Easy to do) A lot of water entered after heavy rains. Most of it ended up in the camper. It only happened at home.
My driveway is fairly slanted. When parked, my Westy is nose high. I plugged the back two drain holes on the luggage box thinking that water drained onto the roof and then flowed back past the awning.
The problem has gone away. Admittedly, this was not a deep exploration. Maybe I was lucky, but it makes sense to me. |
1vw4x4 Banned
Posted: Sun Nov 02, 2014 8:41 pm Post subject: |
In that same area there is a body seam. One on each side.
I've seen water leaking right thru these seams. Obviously hard to find but at this stage everyone should clean out the gutter above the rear hatch and seal this area just in case. |
Posted: Mon Nov 10, 2014 2:23 pm Post subject: |
Just an update. I've taken off the luggage carrier and I'm going to reseal the various entry points.
I waxed it while I was under there. _________________ '84 Wolfsburg Westfalia
termuehlen Samba Member
Joined: May 02, 2012 Posts: 993 Location: Redwood City
Posted: Mon Nov 10, 2014 4:36 pm Post subject: |
You should look at the three "snaps" for the rear hatch screen located along the top of the rear hatch opening. You can see one of them right next to the location of the leak in your picture...
These "snaps" have a post that extends through the body, the top of which is right in the "rain channel" at the back of the van. If they are not sealed well, water flows right through the post hole and will exit where your drip is. (Sometimes the water will even flow through the "snap" post hole and drip off of the snap itself. |
dixoncj Samba Member
Joined: June 17, 2004 Posts: 1083 Location: Charleston, SC
Posted: Mon Nov 10, 2014 5:10 pm Post subject: |
Mine leaked at several of the bolt entry points for the pop top lifting arm hardware - and for the locking mechanism. Go over each of those with some marine grade silicone on the outside. |
Posted: Tue Nov 11, 2014 9:43 am Post subject: |
Arg! I dropped a gallon or so of water into the luggage rack..... Still got leaks. I don't think it is the snaps in the back as the water from the luggage rack drained around the sides and into the gutter. Seems that something still isn't fully sealed up front.
Looks like removing the head liner is next. (Along with a tarp over the whole thing for the rain tomorrow)
I guess I'll also zap the welds for the snaps inside the rear gutter as well.
Posted: Tue Nov 11, 2014 9:52 am Post subject: |
1vw4x4 wrote: |
The body seam below the gutter doesn't get the water I'm testing with. I pour some water in the luggage rack and it mostly goes sideways to the gutters and down to the back of the cart (my driveway is slightly sloped).
I'll caulk the snaps, but again, the rear channel for the hatch isn't getting very wet with the testing I'm doing. _________________ '84 Wolfsburg Westfalia
Posted: Tue Nov 11, 2014 1:19 pm Post subject: |
I think that I figured out what might be happening. My tests were not always using enough water...
If the rain is light or I slowly pour water into the luggage area, the water flows out the side of the luggage rack and into the gutter.
Thusly:
However, if it is a heavy rain or i basically dump water into the luggage rack, it comes out the side *and* out the back of the luggage rack...
..right into the gasket around the poptop. where it flows all the way to the back, inside the poptop, but outside the tent.
So, it looks like it is potentially going into the bolt holes for the poptop hinge, which i had adjusted when I put in the gas lifters.
So I can seal/caulk the hinges, but I'm thinking if I were to seal the back of the luggage rack the water would be forced out the sides and the problem would go away.
FWIW- Right now, in addition to getting back to the hinges, the water can get the tent wet, but it really depends on how meticulous I am when I drop the top and roll the tent. If I seal the back of the luggage rack it would not be able to get to the tent...
comments? advice? _________________ '84 Wolfsburg Westfalia
Posted: Tue Nov 11, 2014 6:10 pm Post subject: |
great testing. thanks for posting that. i've suspected the front of my tent gets wet like that as well. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Posted: Wed Nov 12, 2014 9:46 am Post subject: |
Another data point. I turned my westy around so the nose is now pointing slightly down...
Now when I dump water into the luggage rack the water still drains through the back/rear side. The seal along the front is good enough that is retains the water up there, which is probably good from a wind resistance standpoint, but traps the water. Slight upward pressure on the front releases it (the seal isn't *that* tight).
So when I put in the seal in the rear I need to make sure I leave space on the side for the water to escape. I don't want it up there forever.
I won't be be able to work on it much today due to work and rain is coming... _________________ '84 Wolfsburg Westfalia
