Working on the drive shafts
Charlie57
Charlie57 is offline
PostPosted: Mon Oct 27, 2014 8:05 pm    Post subject: Working on the drive shafts Reply with quote
How do you know when it time to replace the joints/bearings? Here are some photos of the joints I am working on.
[img]https://www.thesamba.com/vw/gallery/pix/1272951.jpg
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=1272949[/img]
[img][/img]
SGKent Premium Member
SGKent is offline
PostPosted: Mon Oct 27, 2014 9:10 pm    Post subject: Reply with quote
huw blued and pitted are the ball bearings inside?
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
old DKP driver
old DKP driver is offline
PostPosted: Mon Oct 27, 2014 9:25 pm    Post subject: when to replace cv joints Reply with quote
That race is pitted and that means that joint needs to be replaced as it
is only a matter of time before it fails.
The balls will also soon to be bad if not already.
V.W.owner since 1967
Wildthings
Wildthings is offline
PostPosted: Tue Oct 28, 2014 12:20 am    Post subject: Reply with quote
You might be able to swap the axles side to side and get good life out of the joints still. Even just swapping them end for end on the same side may cause them to run in a new area of the races. All depends on your finances and vehicle needs.
crownline
crownline is offline
PostPosted: Tue Oct 28, 2014 4:41 am    Post subject: Reply with quote
Wow that's alot of dirt and grit you cleaned out of those bearings Shocked Laughing
1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL]
madmike
madmike is offline
PostPosted: Tue Oct 28, 2014 5:26 am    Post subject: Reply with quote
You can hear them knocking on hard/sharp turns,it's the un-weighted side that knocks Rolling Eyes My local parts store had one in stock(complete axle) for about $80 out the door and no core charge Cool had to re-tighten the bolts once Rolling Eyes and I even used Loctite !!!
65 Baja
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag bug 1915 or 2276 'Turbo'
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's
Tcash
Tcash is offline
PostPosted: Tue Oct 28, 2014 9:36 am    Post subject: Re: Working on the drive shafts Reply with quote
Fixed it
[quote="Charlie57"]How do you know when it time to replace the joints/bearings? Here are some photos of the joints I am working on.
kreemoweet
kreemoweet is offline
PostPosted: Tue Oct 28, 2014 10:32 am    Post subject: Reply with quote
If that's an original VW/Lobro joint, you are well advised to grease it up and run it until it actually starts making
obvious bad noises or otherwise making trouble. I ran a joint that looked far worse than that for over 15 years
without the slightest problem. Sometimes pitting like that is just a result of neglect/abuse by PO's and does not affect
the joint operation.
'67 bug: seized by the authorities
aopisa
aopisa is offline
PostPosted: Tue Oct 28, 2014 10:49 am    Post subject: Reply with quote
Yes, but I would do as Wildthings suggested and swap them left for right so you can introduce new wear surfaces for the bearings. How to the bearings look?
1977 Westy 2.0L FI
Leap into the boundless and make it your home! ---Chuang-Tzu
Please let me know if you do not receive this message...
Wildthings
PostPosted: Tue Oct 28, 2014 12:01 pm    Post subject: Reply with quote
A lot of the original joints got damaged in the few 5000-30,000 miles as the factory grease job was lacking. Once they started making noise they got dissembled and lube and then have run for years with very little additional wear. I wouldn't be surprised to find that that is not what happened with the joint(s) shown.
aeromech
aeromech is offline
PostPosted: Tue Oct 28, 2014 1:27 pm    Post subject: Reply with quote
They look nice and clean. I'd put them back together, grease them good, and roll with it. They will still be better than any Chinese replacement shafts you get at the parts store.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Charlie57
PostPosted: Tue Oct 28, 2014 2:43 pm    Post subject: Reply with quote
The ball bearing seem to look fine. I do not want to spend more money then I need on this build but I don't want to take these apart 5,000 miles from now either. There is definitely some wear on the other rings. I found the complete kit from Airheads for $60 each. Is there anything good or bad about them?
aeromech
aeromech is offline
PostPosted: Tue Oct 28, 2014 3:03 pm    Post subject: Reply with quote
Complete kit? Is that a complete drive axle or just one CV?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
kreemoweet
PostPosted: Tue Oct 28, 2014 4:02 pm    Post subject: Reply with quote
Nothing wrong with having a spare axle (complete with joints) on hand, ready to pop in should the need arise. That way,
the downtime is minimal and you can rebuild the old axle at your leisure. Replacing an axle w/joints is not really a major job.
aeromech
aeromech is offline
PostPosted: Tue Oct 28, 2014 5:27 pm    Post subject: Reply with quote
Nothing wrong with having spares for each and every part on your bus. The thing is that any good drive axle/CV/boot assembly should last at least 60k miles. That's a long time in a bus.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
timvw7476
timvw7476 is offline
PostPosted: Tue Oct 28, 2014 6:24 pm    Post subject: Working on the driveshafts Reply with quote
if you are worried, you can get decent joints out of used-up
vanagons, they're newer & usually don't have the crap
hammered out of them-pik-n-pull sold them kinda' cheap at
one time, & you get to inspect/disassemble them before you buy.
aeromech
aeromech is offline
PostPosted: Wed Oct 29, 2014 10:09 am    Post subject: Reply with quote
I think this is the CV kit he's talking about
http://www.airheadparts.com/vintage-vw-parts/vanag...-251598101
You'll need 4
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
udidwht
udidwht is offline
PostPosted: Wed Oct 29, 2014 10:14 am    Post subject: Reply with quote
http://www.airheadparts.com/vintage-vw-parts/vanag...-251598201
$8.XX Shocked
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
NGK BP6ET plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
aeromech
aeromech is offline
PostPosted: Wed Oct 29, 2014 10:18 am    Post subject: Reply with quote
That's just a boot kit. He thinks he needs to replace the CV's themselves.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Oct 29, 2014 11:24 am    Post subject: Reply with quote
To me that is a classic example of a CV joint that was not properly re-packed likely after the boot had split. Dirt and water got in there and contaminated the lubricant. They should be repacked about every 30K miles and they will last for many thousands of miles.
That being said, I would still just repack all 4 of them, rotate the direction, and drive it. If it made some noise, I would replace that single joint and drive it some more. I would rather have a used German joint than anything to ever come out of a parts store.
The Germans always felt that if you keep the joint clean and well lubricated with nice fresh moly grease it should last forever.
