oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Fri Oct 31, 2014 3:18 pm Post subject: Wire harness difference |
Is there a major difference between a Ghia rear harness and a T3?? I as only because I have a new Ghia harness here and my Fasty needs one. If there was a way to make it work, that would be great, lol. _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Oct 31, 2014 3:21 pm Post subject: |
I'm guessing that the lengths would be too short from an upright to a pancake engine. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
oxsign Samba Member
Posted: Fri Oct 31, 2014 4:10 pm Post subject: |
Thread the harness thru the firewall and try it. _________________ https://imgur.com/user/FisherSquareback/posts
oxsign Samba Member
Bobnotch Samba Member
Posted: Fri Oct 31, 2014 9:48 pm Post subject: |
oxsign wrote: |
Dumb question..... Would it wire up at the fuse block the same? |
I think so, but a quick of the wiring diagrams found in the tech section of this fine site (upper right corner of the page) will tell you for sure. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
grandpa pete Samba Member
Posted: Sat Nov 01, 2014 4:26 pm Post subject: |
Bobnotch wrote: |
oxsign wrote: |
I think so, but a quick of the wiring diagrams found in the tech section of this fine site (upper right corner of the page) will tell you for sure. |
quick search
quick look at
quick perusal
quick referral
quick view
quick review
_________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Nov 01, 2014 4:34 pm Post subject: |
grandpa pete wrote: |
Bobnotch wrote: |
oxsign wrote: |
quick search
quick look at
quick perusal
quick referral
quick view
quick review
Quick left to the solar plexus? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Nov 01, 2014 6:06 pm Post subject: |
Bobnotch wrote: |
oxsign wrote: |
quick search
quick look at
quick perusal
quick referral
quick view
quick review
I'll take "quick look at" for a 100 Monte. But any of those answers would have worked. And with the stupid cloud flares, just getting a post in is close enough. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Nov 01, 2014 9:10 pm Post subject: |
If your stock harness is trashed & has a lot of unnecessary FI wires I would jerk it all out and install the new Ghia harness. Use the '67 Type 3 wiring diagram for carburetors. If you have to extend a couple generator wires that is a small price for getting your car running! _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Sun Nov 02, 2014 7:59 am Post subject: |
Tram wrote: |
Bobnotch wrote: |
oxsign wrote: |
quick search
quick look at
quick perusal
quick referral
quick view
quick review
Quick left to the solar plexus? |
TOO funny !!!!
my wife came out of the kitchen to find out what so funny !!!
THANKS tram
You guys aren't used to her " Damn sarcastic Bostonian " _________________ 63 two fold rag
oxsign Samba Member
Posted: Sun Nov 02, 2014 8:44 am Post subject: |
Mike Fisher wrote: |
If your stock harness is trashed & has a lot of unnecessary FI wires I would jerk it all out and install the new Ghia harness. Use the '67 Type 3 wiring diagram for carburetors. If you have to extend a couple generator wires that is a small price for getting your car running! |
it has a bunch of splices from the PO and hacked from the removals of the FI. It's for that reason I was think of doing it. Thanks for the advise of looking at the '67 wiring diagram. The few wires that may need to be extended won't be a problem with some solder and heat shrink.
I searched before making this post (to the best wording I could) and didn't find any info on someone actually doing this. Sorry. _________________ 1971 Squareback, fully bagged, 1776.
Posted: Sun Nov 02, 2014 10:20 am Post subject: |
You have to tear out all the old wiring before you can lay out/install the new harness. Plug in the engine/tail lights first and work your way back to the fuse box/head lights? _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Sun Nov 02, 2014 7:25 pm Post subject: |
oxsign wrote: |
I searched before making this post (to the best wording I could) and didn't find any info on someone actually doing this. Sorry. |
If you have a late 71, then you can actually almost have it fit right. I only say that, as VW changed how they routed the wiring harness, which actually shortened it up some. My son and I used a bug harness in his 65 Roadster (topless Square). For it, we had to extend the left tail light wires, as they were too short. I believe you're going to run into something similar using the Ghia harness, due to the way it runs in the engine compartment, and has a connector point in it for the left tail light. What you might want to do, is use the t-3 wire set up to the starter (versus the ghia harness wire), as it's a more shorter and direct run (you won't have the added resistance of the long harness wire). That's entirely up to you though, but it might help in the long run. Remember, 71's use a 1 year only ignition switch, so anything you can do to help it live is a plus.
If, however you have an early 71 (built before April 71), then you're probably going to need to blast a hole in the wall under/behind the rear seat for the harness to go to the engine bay. I only say that, as the wiring harness runs on the outside of the body (behind the rear fender) on those cars. Another thing to keep in mind is that you're going to need to relocate the Voltage Regulator to the engine compartment, as that's where your wires are going to be for it.
Personally, I'd feed the harness into the car, and start from the fuse box and work my way back. That way IF you need to lengthen any wires, it won't be the entire harness getting lengthened.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
oxsign Samba Member
Posted: Sun Nov 02, 2014 9:42 pm Post subject: |
Bobnotch wrote: |
oxsign wrote: |
I hope this helps. |
That does help, thank you. The factory harness does run along the outside (behind the fender) on mine. So that would make it and earlier '71? Does that make a difference with the ignition as well? This harness shouldn't involve the ignition (I think) either way though. My plan is to start from the fuses back. I do agree that it would be easier to extend 2-3 wires vs the entire harness to the fuses. _________________ 1971 Squareback, fully bagged, 1776.
Posted: Mon Nov 03, 2014 12:59 pm Post subject: |
oxsign wrote: |
That does help, thank you. The factory harness does run along the outside (behind the fender) on mine. So that would make it and earlier '71? Does that make a difference with the ignition as well? This harness shouldn't involve the ignition (I think) either way though. My plan is to start from the fuses back. I do agree that it would be easier to extend 2-3 wires vs the entire harness to the fuses. |
Yes, you have an "early" 71. And yes, part of the wiring harness does involve the ignition switch wiring (power runs to the ignition switch first on 71 and later cars, rather than the headlight switch of the 70 and earlier cars).
Like I said before, the wiring harness of a Ghia runs inside the car, then enters the engine compartment. That means the harness will be shorter than the type 3 harness you're removing.
This might actually be a case where getting a 67 style type 3 rear wiring harness might make more sense, as the length and colors will be more correct. But, it'll be extra cost to do that. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
